12-02-2005, 11:45 PM | #1 |
Member#: 79498
SWIC
Vehicle:2020 XV |
Just went Stg 2, now flashing CEL
I just finished my installation of the up and down pipes I just got.....
I put everything back together, and before I flashed the Cobb Stg 2, the CEL was blinking. The AP didn't show any code, and I put the stock EGT probe back into the new up pipe, with some high temp sealant. I didn't want to mess around with the EGT CEL fix and didn't have a bolt to go into the up pipe anyways. I flashed the Stg 2 map, and the CEL was still illuminated, checked everything that I unplugged and they were all still plugged in, so I fired it up. The IAM was 12, which confirms that 12 is the starting point for Cobb maps, but as soon as I touched the throttle, it went to 0. CEL still flashing, and the car hunting for an idle, up and down. At this point I went inside to get my laptop and see if ecuExplorer could pick anything up, and the only thing I saw was that the fuel pump duty was 0% and I shut the car off, and turned the key on again and the fuel pump definately wasn't running like it usually does for a couple seconds after I take the ignition to "on." ***? The car is probably a gallon and a half down from full, and the front end was on ramps, did my fuel pump suddenly take a dump?
12-03-2005, 12:38 AM | #2 |
Member#: 79498
SWIC
Vehicle:2020 XV |
ok, so it's not the fuel pump, a drive around the block logging proved that. This is all the info I could pull with ecuExplorer, I never got on it, but nothing seemed wrong either. I've got an exhaust leak at the dp/mid pipe junction since one of the nuts seized and only came off with a whole lot of effort (and PB Blaster) taking the threads off the bolt at the same time, but that'll get fixed tomorrow.
RPM, Manifold Absolute Pressure (PSI), Air/Fuel Learning #1 (%), Air/Fuel Correction #1 (%), Coolant Temperature (°F), Rear O2 Sensor (V), Throttle Opening Angle (%), Mass Air Flow (g/s), Intake Air Temperature (°F), Ignition Timing (°BTDC), Vehicle Speed (MPH), Knock Correction (°BTDC), Fuel Injector #1 Duty (%), Fuel Tank Pressure (PSI), Manifold Relative Pressure (PSI), Tumble Valve Position Sensor Right (V), Primary Wastegate Duty Cycle (%), Fuel Pump Duty (%), Air/Fuel Correction #3 (%), Air/Fuel Sensor #1 (AFR), Test Mode Signal (On/Off), Idle Switch Signal (On/Off), Knock Signal #1 (On/Off), Rear O2 Rich Signal (On/Off), Rear Defogger Switch Signal (On/Off), Exhaust Gas Temperature (°F), Advance Multiplier (020168), CPC Valve Duty Ratio (%), Fuel Level Voltage (V), Idle Speed Control Valve Duty Ratio (%), Tumble Valve Position Sensor Left (V), Air/Fuel Sensor #1 Current (mA), Rear O2 Heater Voltage (V), Air/Fuel Sensor #1 Resistance (Ohms), Air/Fuel Sensor #1 Heater Current (Amps), Battery Voltage (V), Air Flow Sensor Voltage (V), Throttle Sensor Voltage (V), Fuel Temperature (°F) Code:
2025 8.996 0 -13.28 168.8 0.615 9.02 20.19 59 36 39 0 6.48 -0.08 -4.933 0.44 0 33.33 -0.78 14.7 1 0 0 1 1 1004 0 7.06 1.28 37.5 0.42 -0.125 3.16 25 0.7 14.24 2.12 0.82 64.4 2025 8.996 0 -11.72 168.8 0.625 9.02 20.03 59 36 39 0 6.48 -0.08 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 995 0 7.06 1.52 37.5 0.42 -0.125 3.58 26 1.1 14.32 2.1 0.82 64.4 2008 8.996 0 -11.72 168.8 0.64 9.02 20.04 59 36 39 0 6.43 -0.08 -5.078 0.44 0 33.33 -0.78 14.47 1 0 0 1 1 986 0 9.41 1.06 37.5 0.42 -0.375 3.5 26 1.1 14.24 2.1 0.82 64.4 2024 8.996 0 -10.94 168.8 0.645 9.02 19.86 59 36 39 0 6.48 -0.08 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 986 0 9.41 1.34 37.5 0.42 -0.375 0.26 25 1.1 14.24 2.12 0.82 64.4 2016 8.996 0 -10.16 168.8 0.65 9.02 20.05 59 36 39 0 6.45 -0.08 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 986 0 11.76 1.32 37.5 0.42 -0.125 3.58 26 1 14.32 2.1 0.82 64.4 2029 8.996 0 -7.81 170.6 0.625 9.02 20.13 59 36 39 0 6.49 -0.08 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 977 0 11.76 1.5 37.5 0.42 0 0.04 26 1 14.32 2.1 0.82 64.4 2006 8.996 0 -8.59 170.6 0.625 9.02 19.97 59 36 39 0 6.42 -0.08 -4.933 0.44 0 33.33 -0.78 14.47 1 0 0 1 1 968 0 13.73 1.1 37.5 0.42 -0.25 3.58 26 1.3 14.32 2.1 0.82 64.4 2009 8.996 0 -7.81 170.6 0.635 9.02 20.14 59 36 39 0 6.43 -0.08 -4.933 0.44 0 33.33 -0.78 14.36 1 0 0 1 1 968 0 13.33 1.28 37.5 0.42 -0.625 0.02 26 1 14.24 2.1 0.82 64.4 2016 8.996 0 -7.03 170.6 0.67 9.02 20.07 59 36 39 0 6.45 -0.08 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 959 0 16.08 1.52 37.5 0.42 -0.25 3.58 26 1 14.24 2.1 0.82 64.4 2021 8.996 0 -6.25 170.6 0.645 9.02 19.98 59 36 39 0 6.47 -0.084 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 959 0 16.08 1.22 37.5 0.42 -0.125 2.34 27 1.3 14.24 2.1 0.82 64.4 2006 8.996 0 -5.47 170.6 0.66 9.02 20.25 59 36 39 0 6.42 -0.084 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 950 0 17.65 1.24 37.5 0.42 -0.125 3.58 27 1 14.24 2.1 0.82 64.4 2007 8.996 0 -3.91 170.6 0.625 9.02 19.99 59 36 39 0 6.42 -0.084 -4.933 0.44 0 33.33 -0.78 14.59 1 0 0 1 1 950 0 17.65 1.26 37.5 0.42 -0.125 3.56 26 1 14.16 2.1 0.82 64.4 2029 8.996 0 -3.91 170.6 0.645 9.02 20.09 59 36 39 0 6.49 -0.084 -4.933 0.44 0 33.33 -0.78 14.47 1 0 0 1 1 950 0 19.22 1.36 37.5 0.42 -0.125 1.52 27 1.3 14.24 2.1 0.82 64.4 2017 12.043 0 -8.59 170.6 0.64 21.96 32.38 59 35 39 0 9.03 -0.084 -1.886 0.44 0 33.33 -0.78 13.67 1 0 0 1 1 950 0 81.96 1.32 37 0.42 -1.5 3.58 27 1.2 14.24 2.46 1.42 64.4 2064 14.945 0 1.56 170.6 0.31 36.47 37.23 59 25 39 0 12.33 -0.084 1.016 0.44 0 66.67 -0.78 14.7 1 0 0 0 1 950 0 0 1.42 37.5 0.42 -0.125 3.5 26 0.9 14.24 2.52 1.7 64.4 2091 15.671 0 -3.91 172.4 0.585 36.47 40.26 59 20 39 0 13.38 -0.084 1.886 0.44 0 66.67 -0.78 14.01 1 0 0 0 1 950 0 0 1.32 38.5 0.42 -1.625 3.5 27 1.5 14.24 2.58 1.7 64.4 2112 16.396 0 0 172.4 0.85 34.9 43.41 57.2 17 40 0 14.87 -0.087 2.467 0.44 0 100 -0.78 13.44 1 0 0 1 1 950 0 0 1.24 39.5 0.42 -3.25 3.58 27 1.5 14.16 2.62 1.66 64.4 2146 16.686 0 0 172.4 0.93 29.8 44.38 57.2 16 40 0 15.57 -0.087 2.757 0.44 0 100 -0.78 11.94 1 0 0 1 1 950 0 0 1.52 40 0.42 -8 3.58 27 0.9 14.16 2.64 1.48 64.4 2153 15.816 0 0 172.4 0.97 18.43 40.81 57.2 17 40 0 14.69 -0.087 1.886 0.44 0 66.67 -0.78 11.37 1 0 0 1 1 950 0 0 1.42 39.5 0.42 -11.75 3.58 27 1.3 14.16 2.58 1.1 64.4 2161 10.447 0 -17.19 172.4 1 4.31 22.89 57.2 35 41 0 8.3 -0.087 -5.224 0.44 0 33.33 -0.78 11.14 1 0 0 1 1 959 0 0 1.26 37.5 0.42 -16 3.58 27 1.2 14.32 1.94 0.62 64.4 2160 4.933 0 -25 172.4 1.015 1.96 9 57.2 28 42 0 3.23 -0.091 -9.286 0.44 0 33.33 -0.78 11.14 1 0 0 1 1 977 0 0 1.36 37.5 0.42 -14.375 3.48 27 1.2 14.24 1.66 0.6 64.4 2124 4.208 0 -25 172.4 1 1.96 8.48 57.2 25 42 0 2.72 -0.091 -9.722 0.44 0 33.33 -0.78 11.14 1 0 0 1 1 977 0 0 1.54 37.5 0.42 -14.25 0.72 26 0.9 14.32 1.64 0.6 64.4 2125 4.063 0 -25 172.4 1 1.96 8.07 57.2 24 42 0 2.72 -0.091 -9.867 0.44 0 33.33 0 11.48 1 0 0 1 1 977 0 0 1.06 37 0.42 -9.375 3.58 27 1.5 14.32 1.6 0.6 64.4 Last edited by richde; 12-03-2005 at 01:00 AM. |
12-03-2005, 12:56 AM | #3 |
Member#: 50699
TXIC
Vehicle:2004 WRX Platinum Silver |
check your plugs/coils/ignition wiring.
12-03-2005, 01:02 AM | #4 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
12-03-2005, 01:07 AM | #5 |
Member#: 50699
TXIC
One of the reasons why the cel will flash without a code is due to a misfire. this is why i am telling you to check the ignition system. What were you using to check teh codes? Does it check "historic codes"?
12-03-2005, 01:11 AM | #6 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
12-03-2005, 01:26 AM | #7 |
Member#: 50699
TXIC
is this an AP that you flashed with?
12-03-2005, 01:28 AM | #8 |
Member#: 50699
TXIC
after rereading your first post answer this other question, are teh fans cycling low -> high -> off? if so, did you remember to take out the grounding plug and the one that goes on the green connector?
12-03-2005, 02:11 AM | #9 |
Member#: 58337
Vehicle:2k2 Impreza WRX WRB |
when you plug the 2 green connectors togethor it sends the car into "test mode" that will cause the CEL to flash and the radiator fans to cycle on and off. disconnect those plugs and it should be back to normal
12-03-2005, 02:45 AM | #10 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
I think he has found the plug he left in by now, eh?
12-03-2005, 10:38 AM | #11 |
Member#: 79498
SWIC
Vehicle:2020 XV |
Wow thanks, you guys made my weekend. I did leave the plugs connected. Guess I got stupid after the install, I'll never forget that one again.
Went Stg. 2 today, just a CEL question... | lettucemanatee | AccessPort | 6 | 05-12-2010 07:00 PM |
installed stg 2 : flashing CEL | woosleycoon84 | AccessPort | 9 | 05-15-2007 10:24 PM |
Just went stage 2, now car is jerky and I can hear flutter when it spools | pseudosport | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 22 | 02-28-2007 02:15 PM |
Just went Stg. 2. wowsers! | trbo-4 | AccessPort | 12 | 04-04-2006 11:52 AM |
Just went stg 2 sti utec and knocking like crazy | RATEDVIDEO | Engine Management & Tuning | 8 | 12-19-2005 05:32 PM |
