Brakes & Suspension Forum sponsored by The Tire Rack |
01-27-2002, 11:05 PM | #1 |
Forever Scooby Newbie
Member#: 11172
Vehicle:2000 GC8 RS Coupe' FlatBlack&BlueRidge Pearl |
225's on stock 2000 RS wheels?
Is it safe if I run Dunlop D-60 225's on my wheels?
I was told not to by some schmo at Discount Tire. Thanks A Lot, ~Evan
01-28-2002, 12:22 AM | #2 |
Member#: 297
ya its ok. I have 225 50 16 Kumho victoracers on my stock WRX wheels and they are 6.5", yours are 7" wide. It will make the diameter of the wheel bigger throwing off your speedometer a little though.
p@ |
01-28-2002, 01:34 AM | #3 |
Member#: 1925
RMIC
Vehicle:01 A4 89 944s2 13 Speed 3R 99 Sprint |
The schmo at discount tire is right. This will not optimize handling. You I would go with 215/45 16 or if you care about wheel gap go 205/50 16 or even just stock size.
01-28-2002, 08:50 AM | #4 | |
Member#: 8972
E. Canada
Vehicle:2003 WRX Wagon Silver |
According to tire calculators, the 225/50/16 is as close an exact match to 205/55/16 as you are going to get. The diameter is so close that you will have negligible speedo error. On one of the manufacturers site (I think it was Yokohama) they list the rim size range for each tire, and the 16x7s were ok for their 225/50/16 tire. The only thing I would be concerned with is tire rub if your car is lowered at all. I don't think it's an issue at the stock height. If it is lowered, I would stick with stock or a 205/50/16 if you are looking for shorter sidewall. It will be slightly smaller in circumfrence, so your speedo will read a little high. Stu |
01-28-2002, 01:30 PM | #5 |
Member#: 1605
NESIC
Vehicle:1997 1.8L Brighton NESIC TrackH0z member#1 |
I have heard that putting too wide of a tire on a rim that is too small will decrease your grip. For example, if you put a tire that is 8" on a rim that is only 6" wide, this will cause the tire to simply bulge your contact patch and reduce grip.
Later, Seth E. |
01-28-2002, 01:59 PM | #6 | |
Member#: 11172
and I am at the stock ride height... thanks everyone. |
01-28-2002, 03:10 PM | #7 |
Member#: 1925
RMIC
It's too wide... Ru Fan is right; it will not be as grippy as a 215/45 or a 205/50
02-08-2002, 04:16 PM | #8 |
Member#: 2928
Has anybody here actually put on the 225/50/16 tires on their 2000-2001 RS? I'm currently getting ready to shop for replacement tires for my Cobb RS which came with 215/50/16 and my speedo is off a little the tire calculator shows why. the 225/50/16 have the exact same dimensions. I just want to hear from somebody with a stock suspension if they rub or not. I'm betting that they will not but first hand experiance always rules.
http://www.miata.net/garage/tirecalc.html |
02-08-2002, 04:40 PM | #9 |
Member#: 1676
NESIC
Vehicle:98RS w/ EJ257/Dom 2014 Tesla Model S P85 |
It depends on the tire and sectional width, but almost anything in a 225 _will_ rub on a 98-01 RS with a stock suspension... In fact I'm not aware of a tire that won't rub. I would also recommend not running a tire with a sectional width greater than 9.1" since it might not even clear the strut.
FWIW, I had 225/50 16s on my 16x7 MY98 rims and they were right at what I'd call the limit in terms of tire width for a 7" rim. I would _not_ feel safe putting a 225 wide tire on a 6.5" wide rim, but you could probably shoehorn it on there. |
02-08-2002, 06:29 PM | #10 |
Member#: 11172
Alright, but what if you ran 205/55's on front and 225/50's in the rear.
I know it would problably play games with the cars tendency to oversteer, but I was wondering if that type of a setup would cause damage to the diffs. I understand that 205/55's and 225/50's are just about the same actual size, almost exact. I was thinking the differnces in size wouldn't be any more that of running different psi's between the front and rear. Any "insight" Thanks again, ~Evan |
02-08-2002, 07:39 PM | #11 |
Member#: 1676
NESIC
Actually, it's the rears that tend to rub (against the outside fender.) And yeah, the rotational diameter of the two tires is almost spot on the same. If you want to run 225s, this is what I would suggest (it's more or less what I've done)
1) Get a height adjustable suspension with stiffer springs. This will reduce body roll/suspension travel and help keep the rears from rubbing. 2) Be sure to use a rim at least 7" wide. You'll notice that the rim width tire manufacturers recommend for a 225 wide tire is between 7-8" 3) Make sure the particular tire you use doesn't have a sectional width greater than 9.1" tire widths and shapes vary greatly from manufacturer to manufacturer. You'll really notice this if you stack 4 225 wide Hoosiers up against 4 225 wide pirellis, for example. 4) Be prepared to possibly roll your fenders and adjust rear camber to help the tires keep from rubbing at the limits. If you're not willing to work to fit 225s, just get some 205s or 215s. A tire that fits is better than one that doesn't |
02-08-2002, 08:22 PM | #12 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
Listen to what Darshu says.
I'll add that mounting a 225/50R16 on a 16x7 wheel is totally okay. That's the stock size of tires and rims that come with Mk III Toyota Supras (86.5-93), including the Turbo version. There is absolutely no problem with such a combination. -Ray |
02-09-2002, 02:52 AM | #13 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
As others might have said - even at stock height, you will have more problem with your rears. Probably need a bit of negative camber along with stiffer strut/spring combo.
02-09-2002, 01:58 PM | #14 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
i've run 2 sets of 225/50-16s on my '99RS and am about to order a third.
it's very possible you'll have rear fender clearance issues, but if you remove the trim and roll the fender lip (I haven't) you'll be alright most of the time. stiffer suspension helps keep the tire off the fender quite a lot, do a search on my name if you wanna hear more about it. |
02-10-2002, 01:34 AM | #15 |
Member#: 5296
Vehicle:01 2.5RS Black |
what brand tires are you guys with a GC8 running on the stock rim??? i just did a test fit today with the dunlop sp5000 in 225/50/16... they were in constant contact with the rear strut and it would not of even moved if i let the car off the jack... i have stock height suspention. as for other 225/50/16.... they rub... tell a good brand that dosest rub on the MY01's and earlier. on the REX with stock rims they are fine.
02-10-2002, 12:57 PM | #16 | ||||
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
On the other hand, there are those who say contact patch size is king. Go to the SCCA Nationals and see how many people are running tires that are "too wide" for the wheels so they can stay in Stock class. People have found over the years that even though it might not match the tire manufacturer's recommendation, they get more grip in the corners with a wider tire, so they run that wider tire on their stock wheels. Quote:
Pat Olsen '97 Legacy 2.5GT sedan |
02-15-2002, 10:47 PM | #17 |
Member#: 14509
Vehicle:2002 WRX Silver |
Worked okay but some rubbing
I had RE730 225/50/16's on my '01 RS (stock suspension and wheels). If I really got on it in a turn, it would just barely rub the fender trim on the drivers side rear. Never got any rubbing on the passenger side or in the front. Stuck and handled way better than the RE92's (except I had to slow down a bit for right-handers).
Later on I got P1's and put on Dunlop 9000's in 215/45/17. No rubbing at all. 2 weeks later I totaled the car. :-( P1s and DMS Golds are in the mail for the new WRX that replaced it (but damn I miss the coupe). |
225's on stock 02 wrx wheel? | bigolrig | Tire & Wheel | 4 | 03-05-2009 11:12 PM |
FS: Stock 2000 RS wheels and Exhaust | Reflex-Arc | NWIC Private Classifieds | 5 | 04-01-2006 02:49 AM |
Pictures of Hankook R-S2s on stock WRX/RS wheels | Student Driver | Tire & Wheel | 6 | 05-09-2005 10:57 PM |
whats the offset on stock GC RS wheels (6 spoke)? | Jaredm83 | Tire & Wheel | 2 | 08-05-2004 01:22 AM |
On a stock 2000 RS, will adding 4 to 5 lbs per wheel feel much slower? | Gravel-Fun | Brakes, Steering & Suspension | 5 | 09-17-2002 01:00 AM |
