07-14-2017, 06:14 PM | #1 |
Member#: 471023
04 wrx bulkhead wiring harness HELP!
So I am swapping the usdm ej205 with a JDM ej205 and the new motor has the wiring but doesn't have the bulkhead plug and needed help rewiring before buying another harness
07-14-2017, 11:34 PM | #2 |
Member#: 467128
Vehicle:1998 LGT w/EJ205 Green |
i think you're supposed to use the usdm wiring harness and intake manifold. im sure if im wrong someone will chime in lol
07-15-2017, 01:34 PM | #3 |
Member#: 387646
Which ECU are you gonna run? If your gonna run usdm then you can just use your usdm intake manifold and swap over a few other things to make it work(you can look it up if don't already know). If your running JDM, do you have avcs? if yes, then you will need to either get the plugs wired up or find a new harness. If it doesn't have avcs then I think the harness should be the same as the usdm one and you can just swap that harness over from your usdm motor. Or actually you could swap over your USDM harness even if it does have avcs and you could buy something like this http://www.iwireservices.com/product-page/avcs
07-19-2017, 07:09 PM | #4 |
Member#: 471023
It does have avcs but it has the jdm wiring harness my dad had an 02 and it was just a plug in play so we are stuck
