Welcome to the North American Subaru Impreza Owners Club Monday May 10, 2021
Old 09-12-2006, 09:41 PM   #1
newgensti
Member#: 48906
2004 STi
JBP
Default EJ20g Coil on Plugs
know where to get them? I might need a few still have to test mine.. Also what spark plugs should I run. car was running rough and now it stopped running and a few of the plugs were wet when I pulled them
newgensti is offline   Reply With Quote
Old 09-12-2006, 10:03 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
They are identical to SVX coils. Any good import junkyard will have them, or you can still source them new from the dealer...
Old 09-13-2006, 06:21 AM   #3
newgensti
Member#: 48906
2004 STi
JBP
sounds good. I know right where ones at at the local yard
Old 09-13-2006, 08:26 AM   #4
snowjob
Member#: 59357
2009 Forester XT
Default svx coils
Acutally Matt, I couldn't get my SVX coils to work on my 20g, I had to shave them down to get them to bolt up to the holes. Same coil, different shape.
snowjob is offline   Reply With Quote
Old 09-13-2006, 08:30 AM   #5
snowjob
Member#: 59357
2009 Forester XT
Default oops
sssss
Old 09-14-2006, 01:36 PM   #6
kingsubi
Member#: 19239
Mine worked perfectly....I used the front and rears and then spliced in the connectors. I have no issues with clearence?
Where you using ej20G heads?
kingsubi is offline   Reply With Quote
Old 09-15-2006, 05:16 AM   #7
Norcalrallyist
Member#: 15510
1993 MY94 WRX
i thought you could use 02 wrx wires. They have coil on plug
Norcalrallyist is offline   Reply With Quote
Old 09-15-2006, 11:07 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
The WRX coils have the ignitor built into them. You can use them, but it requires eliminating the independent ignitor from the citcuitry. It also requires some grinding off of material from the coil to make it fit the EJ20G head. Suberboy has done it, and you might hit him up to post here with details...
FS: STi spark plug wires for non-coil-on-plug turbo engines Necromancer VIC Private Classifieds 6 09-20-2009 12:35 PM
Ignition Coils - WRX / Sti coil on plug type - $30 each all four available Fongers Engine/Power/Exhaust 1 04-03-2008 08:47 PM
ej22t to EJ20G Coil On Plug legacymaximus Pre-2002 Factory Turbo Powertrain 29 04-13-2007 03:13 PM
coil on plug ???? pestysti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-24-2005 08:14 PM
Changing Coil on Plug to Coilpack... jarelee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-24-2003 04:33 AM
