Welcome to the North American Subaru Impreza Owners Club Tuesday May 11, 2021
Old 11-09-2006, 03:50 PM   #1
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default 1991 leggy turbo hesitation
I have a 91ss 4eat that has hesitation above 3k rpm. I've done plugs, swapped wires, fuel filter, coil, knock sensor, you name it and I've probably messed with it. Anyone have similar issues? I have no cel. I'm gonna try to swap mafs this weekend.
damonmlime is offline   Reply With Quote
Old 11-11-2006, 03:53 PM   #2
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
changed the maf and the boost solenoid.
Old 11-15-2006, 12:50 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I don't really have an answer for you. These cars can be tempermental. You may want to search/post on www.bbs.legacycentral.org if you haven't already done so.
Legacy777 is offline   Reply With Quote
Old 11-15-2006, 01:19 PM   #4
shemoves
Member#: 80663
2005 STi
http://www.crcindustries.com/auto/co...x?PN=05110&S=N
Should work, like 5 bucks. Should be able to get it at AZ or Wal-mart. I've used it on both my Legacy and on the STi.
shemoves is offline   Reply With Quote
Old 11-17-2006, 04:49 PM   #5
head2wind
Member#: 128539
Default hesitation
Is the hesitation pre or post full warm? or is it in between the ECU going closed loop? this threshold would about 10-12 minutes after startup and drive away. My 93 4eat has this symptom and I think it is related to the O2 sensor. I have the ECU interface built that allows me to look at it real time via RS232 serial and a free Win32 application called SelectMonitor. Check the site http://www.vwrx.com/index.php?pg=selectmonitor. Code is based primarily from VRG3's (legacyCentral) work and effort. If you have questions, PM me and I might be able to help.
head2wind is offline   Reply With Quote
1991 Legacy Turbo Parts: VF11 Turbo, intake, injectors, etc RYNOMOTO Engine/Power/Exhaust 17 05-08-2010 03:52 PM
1991 leggy turbo dstan Pre-2002 Factory Turbo Powertrain 2 07-14-2009 09:11 PM
FS: 1992 Leg SS Turbo 5spd & 1991 Leg Turbo SS AT Phx,AZ JapCarRealGood Private Vehicle 'For Sale' Classifieds 15 12-21-2006 03:39 PM
FS: 1992 Leg SS Turbo 5spd & 1991 Leg Turbo SS AT Phx,AZ JapCarRealGood SWIC Private Classifieds 13 12-21-2006 02:52 PM
