Welcome to the North American Subaru Impreza Owners Club Thursday May 13, 2021
Old 08-08-2018, 06:06 PM   #1251
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
IMPORTIMAGE is offline   Reply With Quote
Old 08-08-2018, 07:40 PM   #1252
Falcon WRX
Member#: 400310
2017 WRX Sport
Crystal White Pearl
I love those wheels and now it comes in my favorite color.
Falcon WRX is offline   Reply With Quote
Old 08-13-2018, 04:26 PM   #1253
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
awesome!
Old 11-10-2018, 09:46 AM   #1254
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Hyper Bronze R1's in 18x9.5 +35 5x114.3 These clear the 18+ sti 6 piston brakes!
XT-006r's in 18x9 5x114.3 +30, confirmed to clear 18+ sti brembos as well!
R1's in 18x9.5 5x114.3 white +35
Old 11-17-2018, 01:29 AM   #1255
BocaWRX18
Member#: 490931
2018 Premium
Lapis Blue Pearl
Iv got a 18 wrx on hks coilovers and was wondering what specs i could get in the xt006 to fit without a whole bunch of fender work. I want the 18-9.5
BocaWRX18 is offline   Reply With Quote
Old 11-17-2018, 06:47 AM   #1256
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Every one that you see in 18x9.5 is a +10 offset, meaning you will need to use some camber to get it to look right. https://www.instagram.com/tiffn_/?hl=en Tiffany is local to you and has the exact wheel on her 18 wrx. she has coilovers and control arms, feel free to reach out to her if you like. Her car looks pretty nice.
Old 11-19-2018, 03:47 PM   #1257
BocaWRX18
Member#: 490931
2018 Premium
Lapis Blue Pearl
Her fitment is my dream fitment, iv contacted her in the past but no replies .
Old 11-20-2018, 01:19 PM   #1258
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Dang, she must get a lot of leg humpers haha ill ask her for you, pm me the question
Old 11-20-2018, 08:10 PM   #1259
ericwudi0830
Member#: 468703
Nice wheels!
ericwudi0830 is offline   Reply With Quote
Old 11-21-2018, 10:53 PM   #1260
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Thanks!
Old 02-22-2019, 10:13 PM   #1261
jamesongiardino13
Member#: 498092
Default Cosmis wheels
Hey guys I have an 04 STi with the 5x114.3 conversion . I also installed the Karlton Flares! I was told to do an 18x10.5+15 wheel. I was wondering if I could get away with a Cosmis rim 18x9.5+10 offset and (clear the brembos)!!! I really like them and want them and I feel that 10.5 width would be too wide!
jamesongiardino13 is offline   Reply With Quote
Old 02-22-2019, 10:22 PM   #1262
jamesongiardino13
Member#: 498092
Old 02-23-2019, 12:02 AM   #1263
fullah
Member#: 233053
Is fender work required to run these offsets? I see the cars are lowered. Any idea on tire size being used? Definitely like the aggressive styling of these wheels but I really don't want to have to deal with rolling my fenders to avoid rubbing.
fullah is offline   Reply With Quote
Old 02-24-2019, 02:58 AM   #1264
BocaWRX18
Member#: 490931
2018 Premium
Lapis Blue Pearl
Old 02-24-2019, 03:25 AM   #1265
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Originally Posted by hamgatan View Post
Just wanted to pipe up and show off my new shoes a bit but also convey some issues with fitment. they're not as straight bolt up as this thread suggests.
Got XT-005R's in white. 18x9 +25. Tyres are Michelin Pilot Sport 4 245/45/R18. Suspension is stock springs with KYB shocks. No intent on changing that setup as I don't really want to go lower. It's daily driven which means it needs to be practical, not #hellaflushomgwtfbbq #illeststickers+5kw
absolutely love the look of them. but it's not an easy fitment. I'll have to get guards pulled shortly and check back with an update on the rubbing. i have a feeling the 245/45 isn't helping, a 245/40 would have been better.
As you can see theres a bit of poke. it's not ridiculous enough to warrant new flares and cutting out the existing guards - but fielding opinions on how much i can pull out? Here's a tighter angle.
The fronts do have a bit more poke than the rears but my biggest concern is clearance on full lock. Front wheel has about 1" around all edges which is fine for driving in a straight line and braking etc.
With the factory guard liners in the front wheel wells there is a lot of rubbing. After I removed them, most of the rubbing is gone except when I go on full lock the wheel scrapes against the front of where the factory side skirt is attached and comes dangerously close (10mm or so) to this ridge/seam on the body below (marked in red).
Can this ridge/seam be dollied down flat and a reinforcement weld be done before its sealed back with Urethane or would more inner wheel well work be required? (Or too hard basket - just sell the 245/45's and go down to 40's?)
Your wheels stick out too far, the offset is wrong. A 245/40 with silly camber might help but you may not be happy with tire wear and the wheelwell gap look. You have wrong wheel fitment, +40 offset would probably be just right.
The only thing worse would be running a stretched 215 tire with the rim lit exposed but people do it, crazy kids.
D-Rodman is offline   Reply With Quote
Old 02-25-2019, 11:20 AM   #1266
cdcee
Member#: 444981
Super interested in the MRII's
Not sure if it will fit my 2015 STi.
Currently on AirLift 3H/3P; Whiteline rear LCA's, and will consider rolling fenders.
What wheel specs will clear the stock Brembo's?
Ideally want to end with about a 265 width tire and an 18" x 10" wheel (unsure of offset). Flush look. Car will be have some track time at the strip and road course a few times a year.
cdcee is offline   Reply With Quote
Old 03-06-2019, 05:08 PM   #1267
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
the 18x9.5 bolts right on, it will poke due to the low offset, but it will clear the brembos no problem
Old 04-03-2019, 07:54 AM   #1268
jfernandess14
Member#: 341863
2015 WRX Premium
Dark Gray Metallic
Any one have the Cosmis S5R 18x10.5 et 20 on a 15+ WRX on coils?
jfernandess14 is offline   Reply With Quote
Old 04-13-2019, 08:45 AM   #1269
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
i think there are a few setups on fitment industries, i have some pics as well if you need them
Old 04-14-2019, 06:58 PM   #1270
jiffy
Member#: 480267
2006 Subaru STi
hey, does anyone know how the xt-206rs in 18x11 +8 5x114.3 will fit with the 2006 sti brembos? i've been looking around and can't find a definite answer. if they don't fit how big of a spacer will i need to run them, or are there any ways around it?
jiffy is offline   Reply With Quote
Old 04-16-2019, 01:18 PM   #1271
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
15mm spacer sir
Old 04-29-2019, 10:02 PM   #1272
loneyboy
Member#: 500974
Default Black Chrome on Silver?
Does anyone have pics of a black chrome rim on a Silver WRX? Debating between the black and black chrome R1's for my 2015 silver WRX
loneyboy is offline   Reply With Quote
Old 04-30-2019, 11:17 AM   #1273
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
i have a few, email [email protected] and ill send them over
Old 05-04-2019, 05:12 PM   #1274
jiffy
Member#: 480267
2006 Subaru STi
anyone have pictures of their 06-07 sti with xt-206rs in 18x11 +8 5x114.3?
Old 05-04-2019, 05:29 PM   #1275
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
