Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Old 08-26-2005, 08:45 AM   #1
subenick
Member#: 48968
1999 impreza 2.5RS
Default JDM Version 7 STi going into my 99 RS project thread!
Here we go… after 2 years (since I got my car) I have finally purchased an STi Version 7 Drivetrain. The install will be a complete Version 7 running hardware. After months of reading threads about other peoples installs to gain vital information about it, I hope that this thread can provide even further information about the process. Of course, I hope it can also provide me with information if I get stuck (which I will!)
The drivetrain includes thus far:
- Engine: EJ207… version 7 with crossmember
- Transmission: TY856WB1CA (suretrack, non dccd)
- Driveshafts
- Rear subframe, rear 180
- V7 suspension and sway bars
- Brembo brakes
- Complete wiring harness (incredibly uncut) and ECU
- Aluminum a-arms.
- All sensors
What im missing: might need some help here
- MAF (of course… there must be some huge surplus of MAF’s in japan cause they never make it here) most likely by one new from subaruparts.com
- Intake (suggestions?)
- Exhaust (suggestions?) im thinking custom made double resonated non muffled cartback. Don’t want to be noticeably loud.
- Power steering lines and reservoir. I hear these are expensive so if anyone has some from a wrx lying around please let me know
- Fuel pump (ebay!) walbro 255
- Wrx dash. Does anyone know which dash will work with the stock wiring… aside from the jdm version 7 dash! (I don’t feel like splicing wires)
Im sure I left something out. So please add it in if you can.
Also, any tips or tricks about this install are welcome and greatly appreciated.
Stay tuned for pictures and updates on this project.
subenick is offline   Reply With Quote
Old 08-26-2005, 10:55 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
are you sure you want to do the wrx dash?
that adds a bunch of work to the project .. espically if you don't have the cluster (not listed above) and a non dccd tranny
YOU ARE GOING TO HAVE TO SPLICE WIRES no ifs ands or buts about it
Old 08-26-2005, 11:04 AM   #3
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
grab a USDM OEM sti fuel pump. $40 shipped easy.
does JDM car have FPC?
supermoose is offline   Reply With Quote
Old 08-26-2005, 01:48 PM   #4
subenick
Member#: 48968
1999 impreza 2.5RS
oops... did i say dash... i meant cluster. i want to add just the cluster so its plug-in
whats fpc?
Old 08-26-2005, 01:51 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Fuel pump controller...the jdm v7 should have come with it. You may not have one as they are part of the rear harness. They are about 120-150 new from a dealer an 02 usdm wrx one will work fine.
Soon2Bgreat is offline   Reply With Quote
Old 08-26-2005, 02:12 PM   #6
wuuusaa
Member#: 92894
2015 Wrx
The Guys At I-speedusa.com Said The Conversion Is Very Difficult And Time Consuming,also The Dash Board Frame For The Wrx And Rs Is Very Much So Diffirent.
Old 08-26-2005, 11:07 PM   #7
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
you can use the MAF, Ps pump and lines, intake, air box, exhaust, and boost control valve for a wrx. That is what i didn in mine, and there is no problems
JeremyRS is offline   Reply With Quote
Old 08-27-2005, 11:53 AM   #8
subenick
Member#: 48968
1999 impreza 2.5RS
Default update
thanks for the info guys.
heres some pics of the gear:
questions:
can the brake lines from my rs plug into the brembos?
im guesssing the rs abs sensors dont fit with the sti hub.say goodbye to abs (thank god i hate abs)
thanks for the input
Old 08-27-2005, 11:55 AM   #9
subenick
Member#: 48968
1999 impreza 2.5RS
Default driveshaft
Old 08-27-2005, 11:57 AM   #10
subenick
Member#: 48968
1999 impreza 2.5RS
Default lets try this again..
http://i5.photobucket.com/albums/y17...k/EJ207011.jpg
this one should work
shouldnt this end be male?
Old 08-27-2005, 01:36 PM   #11
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Did you find out if this 'incredibly uncut' harness had the fuel pump controller?
Looks like you have a MY2001 JDM motor there...what's the white tag say?
The RS brake lines will work.
The axle stub looks correct for a v7...something must be up with the tranny, can you get a pic of what it looks like.
I bet i can guess where you got this drivetrain...make sure to compression test it. Let me know how much you spend in extra parts also to get it to work.
Good luck.
Old 08-27-2005, 06:30 PM   #12
subenick
Member#: 48968
1999 impreza 2.5RS
its an ej207dw4cr (my02 sti engine v7)
http://i5.photobucket.com/albums/y17...ck/prep002.jpg
heres the front diff housing area:
http://i5.photobucket.com/albums/y17...ck/prep014.jpg
and if someone has a pic of an fpc then i can tell you if i have it or not.
all the plugs on the engine and trans mission match up to those on the harness. as soon as i get a wiring diagram from my friend im going to start removing what is not necessary from the harness.
thanks for the info on the brake lines
nother question... my rs is pull type clutch and the sti is push type. i havent looked closely at my master cylinder yet. but im guessing i need one from a wrx
thanks for all the info
Old 08-27-2005, 06:31 PM   #13
subenick
Member#: 48968
1999 impreza 2.5RS
... so where do you think i got this engine?
Old 08-27-2005, 07:00 PM   #14
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
No master cylinder...just the slave cylinder iirc. Even then you can use a usdm wrx 5mt slave also. Anything that uses a pull clutch also. (I believe rs is push type)
Yea looks like you should have a stub coming out of there. Did you run the tranny numbers to see what year it is...i think the later models have a stub on the axles as opposed to the tranny.
The FPC should be a white box about 4 inches by 2 inches and 1 inch wide (give or take) and i think it says denso on it iirc.
Did you get your drivetrain from a shop in montreal?
Old 08-28-2005, 12:23 PM   #15
subenick
Member#: 48968
1999 impreza 2.5RS
Default mtl
i got the engine in mtl but not from a shop. you might be thinking of sunrise or jdm import. i checked them out... the engines looked clean but all the wires were really butchered. i checked out lachute too. they had some nice stuff. very complete kits.. but they had nothing in when the time to buy came. nice guys there.
as for the clutch. it looks like the 6spd pushes and my rs pulls. im going to have a closer look. but i think i can just hook the slave up to the rs master.
going to go sort through wiring today. and look for that fpc!
Old 08-28-2005, 12:31 PM   #16
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
pm OvenMitts
he will tell you how much of a PITA a full WRX dash is to swap into a GC car.
Good luck on the build!!
thrdeye is offline   Reply With Quote
Old 08-28-2005, 12:44 PM   #17
subenick
Member#: 48968
1999 impreza 2.5RS
Default confusion
... i just realized i used the wrong word about the dash. i just want to insert a wrx or jdm sti 2002-2004 (or newer if they work?) gauge cluster in place of the one from the rs so that i can simply plug it in.... plus obviously i need the 9000rpm tach in the middle
Old 08-28-2005, 02:01 PM   #18
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
I don't think that cluster will fit into the dash without some "customization" aka sawzall.
Old 08-28-2005, 03:49 PM   #19
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
The RS is a push type clutch and the turbo subaru's are pull type, and yes you can resuse your master cylinder and swap the slave.
Old 08-28-2005, 04:57 PM   #20
JoshP
Member#: 94350
is your 2.5 going to be for sale?
JoshP is offline   Reply With Quote
Old 08-28-2005, 06:55 PM   #21
subenick
Member#: 48968
1999 impreza 2.5RS
Default 2.5 drivetrain
the entire drivetrain will be for sale. 110,000km
will decide what its worth when its out...
although im not sure how easy it is for me to ship this to the states if someone wants it
Old 08-29-2005, 10:16 AM   #22
subenick
Member#: 48968
1999 impreza 2.5RS
Default fpc
Heres a picture of the FPC with harness for anyone who was wondering like i myself once was!
hope this helps future swappers
Old 08-29-2005, 08:47 PM   #23
WhozyerDADDY
Member#: 3420
2001 2.0 Sti Ver.7
Blue ridge pearl
So, how much is a slave for the 6spd anyway? I'll have to check subyparts...
WhozyerDADDY is offline   Reply With Quote
Old 08-31-2005, 11:51 AM   #24
subenick
Member#: 48968
1999 impreza 2.5RS
Default fpc
so just to be sure. will the fpc p/n 22648AA011 work for this swap?
thanks
Old 09-01-2005, 11:58 PM   #25
sith
Member#: 66362
2015 WRX
Grey
bump!! anyone know?
.sith.
sith is offline   Reply With Quote
my jdm version 7 sti interior in my 06 WRX fuel110 Interior & Exterior Modification 9 03-03-2009 04:21 PM
JDM version 7 STi suspension nekard Private 'For Sale' Classifieds 0 04-13-2004 12:52 PM
