Welcome to the North American Subaru Impreza Owners Club Tuesday August 14, 2018
Old 07-02-2018, 11:00 PM   #1
albersondh
Member#: 196882
08 WRX
Default Head repair
Anybody got a shop/welder willing to take a crack at this difficult weld repair? Possibly a tad greedy on the dog leg. The liquid is flowing down from the port wall, where I "allegedly" went through the wall into the water jacket. Found the leak while checking valve seal during port side pressure test.... FML.
albersondh is offline   Reply With Quote
Old 07-03-2018, 07:35 AM   #2
rtv900
Member#: 428511
2016 STI
it's hard to even tell what you are looking to get welded
I guess it's down in the port?
Old 07-04-2018, 06:46 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
if you ported the hell out of them, and there is little meat left there is a good chance heads will develop more cracks during operation especially if you have high EGT or running ignition cut LC
Hyper is offline   Reply With Quote
Old 07-04-2018, 07:27 AM   #4
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
what hyper said is a good possibility.
you’ll prolly want to get new heads. expensive lesson to learn.
Titter is offline   Reply With Quote
Old 07-04-2018, 02:48 PM   #5
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
IAG stage V heads in your future
user1029 is offline   Reply With Quote
Old 07-04-2018, 03:02 PM   #6
albersondh
Member#: 196882
08 WRX
This is the third set of D25s I have P&P and the first one I have punched through. I consider myself pretty conservative on my porting. Shame, these flowed very nicely with 210-CFM at only .2 lift, 265 at .4.
Dog legs 187 at .4.
Old 07-20-2018, 07:12 PM   #7
albersondh
Member#: 196882
08 WRX
Fixed.
Before smoothing over the weld repair:
After blending the weld a bit.
Holding vac.
and 20psi. I test all ports to 20psi. Typically start to see some foaming around 20psi and I consider that ok as long Im not getting bubbles, and not losing more than 1psi/5-min.
Old 07-20-2018, 11:24 PM   #8
TDagen
Member#: 163648
2002 Resurrected WRX
Wow. Nice repair!
