Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 03-31-2017, 12:45 PM   #1
PERRIN_Thomas
Vendor Sales Rating: (0)
Member#: 423601
2016 WRX
LBP
Default PERRIN Charge Pipe 2015+ WRX
Replace the restrictive OEM plastic charge pipe and increase airflow and intercooler efficiency with the PERRIN Charge Pipe for 2015-17 WRX!
BETTER AIRFLOW OVER STOCK
The OEM charge pipe on the FA20 DIT engine is restrictive, narrows down in certain points, and has pleats that make for uneven airflow. The PERRIN Charge Pipe has a perfectly smooth interior, constant radii, and gradual bends, making for much more efficient air delivery. All of this combined creates for increased intercooler efficiency.
CONNECTORS AND COMPATBILITY
The PERRIN Charge Pipe comes with all the necessary connectors to install onto a stock system for greater compatibility. The CNC machined PERRIN turbo flange adapter uses the same design as the OEM flange on the turbo side of the charge pipe and uses the OEM o-ring for perfect fitment and no leaks, unlike off-the-shelf o-rings. The silicone connectors are reinforced multi-layered for durability and weather resistance.
PM ME FOR NASIOC DISCOUNTS!
__________________
PERRIN_Thomas is offline   Reply With Quote
Old 03-31-2017, 03:03 PM   #2
IvanFA20
Member Sales Rating: (22)
Member#: 227738
2016 WRX CVT
Sent you a message.
IvanFA20 is offline   Reply With Quote
Old 04-16-2017, 03:50 PM   #3
SFEBayWRX
Member#: 464526
Default Does the Perrin charge pipe require a tune?
I do not have an Access Port yet on my 2016 wrx
SFEBayWRX is offline   Reply With Quote
Old 04-18-2017, 02:04 PM   #4
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
No it does not require any tuning, does not change the A/F ratios enough to harm anything on the car.
__________________
Old 08-10-2018, 04:16 AM   #5
Suboo17
Member#: 489956
I currently have the machined turbo inlet and looking to add the charge pipe next and possibly your intake. Im guessing i should probably have it tuned but was looking for your input prior to purchase of at least the charge pipe.
Suboo17 is offline   Reply With Quote
Old 08-11-2018, 04:50 PM   #6
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2018 STI RA
Thanks for asking!
It is always a good idea to have the engine mapping re-tuned when making airflow changes, but you don't HAVE to.
Hope that helps and we look forward to your next purchase!
Thanks for continuing to choose PERRIN!
Adam
PERRIN_Adam is offline   Reply With Quote
