Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 01-14-2019, 01:32 PM   #1
bobdole888
Member#: 316658
2012 Impreza limited
5dr silver
Exclamation Valve spring recall on Impreza
Just got a recall letter on my 2012 Impreza for valve spring replacement.
What's the risk of them screwing something up?
Should I wait a few month for the the tech's to get good a doing this repair before bring it in?
Or am I better not doing any fix and take a chance that the the spring won't go bad?
bobdole888 is offline   Reply With Quote
Old 01-14-2019, 02:27 PM   #2
KC
Member#: 442
17 Imp Spurt
00 S2k
KC is offline   Reply With Quote
Old 01-14-2019, 05:22 PM   #3
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
There is discussion about this in the 2012 Impreza thread.
If they mess something up while in there then they “should” be responsible for it.
I would hope a Subaru dealer would have sufficient knowledge to do this properly.
I will probably get it down the line somewhere
DieselDorf is offline   Reply With Quote
Old 01-14-2019, 08:36 PM   #4
Angelus911
Member#: 89967
2020 Volvo S60
Gray
Risk vs reward I guess. When I had my new shortblock installed it came with a 1 yr 12k mike warranty. Not sure if that will apply to this or not
Angelus911 is offline   Reply With Quote
Old 01-15-2019, 05:00 PM   #5
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
I did schedule service for mine, it is over 100k miles anyways and I have heard some abnormal noise at times, not sure if it is related to this. Dealer was booked 3 weeks out for this service, so hopefully by then they should be practiced in the procedure.
Haunty is offline   Reply With Quote
Old 01-15-2019, 07:48 PM   #6
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
are they actually starting to repair this already?
Old 01-15-2019, 08:10 PM   #7
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
The letter from soa said bring it in ASAP.
Old 01-16-2019, 08:02 AM   #8
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I will wait until there are better reports. Only report i have seen so far is 1 brz whose engine failed shortly after the repair......
Old 01-16-2019, 03:44 PM   #9
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
I was told about it when I brought my 13 Crosstrek in for the 2nd oil consumption test. They told me coming in and asked if I wanted it done while I wait. I just laughed. Half an hour later, they tell me I'm getting a new short block. So I'll be getting all kinds of new stuff to go along with my already replaced CVT.
Old 01-16-2019, 06:18 PM   #10
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Dang how many miles? You will have a whole new drivetrain if a few more pieces break XD
Old 01-17-2019, 12:22 PM   #11
2012NYCSUBIE
Member#: 327440
2012 IMPREZA SPT LTD
DARK GRAY METALLIC
I went yesterday to my dealer to make an apt and he said give us like 2 weeks, we have to get the parts in stock and the techs have to go to school to learn how to do the job.
2012NYCSUBIE is offline   Reply With Quote
Old 01-17-2019, 03:04 PM   #12
Angelus911
Member#: 89967
2020 Volvo S60
Gray
Yeah, best to wait for them to do the repair. Don’t want to be an early adopter for this repair.
Slightly disappointing that the cam carrier doesn’t have to be removed for this fix, maybe my leak is from somewhere else. We shall see
Old 01-17-2019, 07:58 PM   #13
bobdole888
Member#: 316658
5dr silver
What is this 'short block' that you speak of?
Is this something that the dealer does to fix some other issue?
Old 01-17-2019, 08:08 PM   #14
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Short block replacement is for the oil consumption issue.
Old 01-19-2019, 09:01 PM   #15
chasnasty2016
Member#: 460929
Here's my question regarding this issue.
I have a 212 Imprezza that I understand is one of the years that has experienced head gasket failure (correct me if I'm wrong).
Will the valve spring repair include removing the head? I'm thinking if it does they would have to replace the head gasket as part of this repair. 2 birds is the thought.
If head removal is not needed, I wonder how likely a dealer would be to give me a "deal" and fix the gasket preemptively, since they are already in there.
Any thoughts?
Charlie
chasnasty2016 is offline   Reply With Quote
Old 01-20-2019, 07:54 AM   #16
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No head gasket issues on FB motors, just other things......rings, valve springs,
Old 01-20-2019, 01:19 PM   #17
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
No head gasket issues. At least no more than other brands.
I was wondering the same thing, if they will give you a deal on labor for doing plugs or something since everything is already opened up and easily accessible. I need plugs soon.
Old 01-20-2019, 02:15 PM   #18
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Doubtful, they will just charge book value. They almost lose money doing warranty work
Old 01-20-2019, 04:50 PM   #19
chasnasty2016
Member#: 460929
So 2012 Imprezza doesn't have head gasket issues? That's good to hear. Anyone care to explain things I should be looking out for in this model year then?
Charlie H
Old 01-20-2019, 06:21 PM   #20
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Charlie H
Oil burning due to ****ty rings, luckily no one wants the FB so low mileage motors are dirt cheap. Mine was 600.00 complete w/ 25k on it.....
Valve springs breaking (apparently)
Old 01-20-2019, 08:09 PM   #21
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Only other thing than what flyboy mentioned is brakes sticking has been a relatively common issue. Not a major one though. Usually it’s the pad edges rusting make them get pinched in the clips.
A little filing or grinding does the trick.
Old 01-23-2019, 11:57 AM   #22
bobdole888
Member#: 316658
5dr silver
I have minor oil consumption issue. With 7500 miles between oil changes, I usually need to add about 0.5 quart oil after 5000 miles. I'm experimenting with 5w30 conventional oil right now. I'm hoping the thicker oil will 'leak' less and less oil consumption.
I haven't complained to Subaru about oil consumption and the car is out of warranty now, so I guess they won't be doing a short block replacement for me then.
Old 01-23-2019, 01:10 PM   #23
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
That is nowhere near excessive consumption.
I lost a quart in 3000 miles, since switch to 0-40 I lose a quart in about 7000.
Don’t go with conventional do full synthetic just go for a heavier weight like 0-40
You only need to worry if it’s like 1 quart loss per 1000miles.
Old 01-23-2019, 02:57 PM   #24
bobdole888
Member#: 316658
5dr silver
This is a econo car...why does it need synthetic oil for protection?
It's mainly needed for best MPG, but the difference is not even noticeable.
I have had at least 10 tanks of fill ups with the 5w30 and see no difference in MPG.
On a separate topic, I did see 10% MPG drop when I switched tires.
Old 01-23-2019, 06:32 PM   #25
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
There really is no benefit to running conventional oil.
Synthetic is slightly more expensive but last twice as long and doesn’t gum up as bad as conventional.
Also it is recommended by Subaru to run in your car.
I put synthetic in everything saves money in oil and keeps engines cleaner.
