12-01-2018, 08:55 PM | #1 |
Member#: 184183
SCIC
Vehicle:1996 Impreza RSTi V8 EJ207 Aerosim Carbon |
181stLeader's Aerosim Research Carbon Fiber Widebody
Since RS25 doesn't get much traffic I decided to start another journal here on naisoc. My original thread can be found here if you want to see more details: https://www.rs25.com/forums/f145/t16...ody-coupe.html
The next phase for my car is a Aegean Blue 96 Impreza L Coupe. I have swapped shells over from my 95L getting ready for the carbon Aerosim kit(I couldn't bring myself to install the carbon kit on a salvaged title car). Picture of the 1996 L coupe the day I bought it. Current picture: Current mods are: Exterior: Aerosim Research Full Carbon Fiber WRC Body Kit -Molded Quarters and Side Skirts -Rally Pin Jack Stand Bosses in The Rocker Panels Newton Equipment Locking Aero Fuel Filler Cap JDM Version 5/6 STi Aluminum Hood Replica S5 WRC Hood Vents Version 4 EDM Fluted Headlights with Beam Leveling Motors JDM Light Weight Rear Bumper Beam JDM Clear Corners with Amber LEDs JDM STi Tail Lights JDM STi Type RA Roof Vent WRC Replica Roof Scoop - Primitive racing(trimmed shorter and contoured to the roof) Hella Super Tone Horns Bakemono Adjustable 22B Replica Spoiler Bakemono S201 Carbon Fiber Aero Pocket Mirrors Sparco Hood Pins WRC Front Grille Subaru Stars Badge Holder World Rally Blue Paint (Paint code 02C) -PPG Primer -Sherwin Williams Basecoat -DuPont Imron Clearcoat Interior: 99 RS Dash, Door Cards and all Black Trim Plastics JDM Version 8 STi Gauge Cluster EDM LHD Passenger Airbag Delete Pocket USDM 05 STi Rear Seats Genuine Recaro/Blimp SRD seats 06 WRX Black Carpet 22B Nardi Steering Wheel(with working auto canceling signals and working horn) 22B Stainless Door Sills 06 STi Pedal Box 08+ Legacy STi Pedal Set STi Titanium Sphere Shift knob (6MT) OEM Trunk Light (converted to LED) 04 STi Red Stitched Leather E-brake handle STi Limited WRC Edition Blue Center Console (#425 of 2000) 02 WRX 6 Disc Changer Radio -Converted to Red Back Light -Jazzy Engineering AUX in module Passenger Vinyl Sun Visor without Airbag Warning from 93 (Impreza L base) 2002 WRX Intermittent Wiper Stalk Autopower Roll Bar Sabelt 6 Point Harness' Engine: JDM STi Version 8 EJ207 with working AVCS Version 7 Spec C VF-34 Turbo (Larger P20 Exhaust housing swap from a VF-22) 05 USDM STi UEL Headers APS Up-Pipe ID1050x Top Feed injectors Cobb 4 Bar Map Sensor iWire Harness Merge #109 Tomioka Racing Timing Belt Guide Gates Blue Timing Belt Kit. Mishimoto 1st Gen Legacy Turbo Aluminum Radiator GReddy GC8 Radiator Shroud 98 RS Metal Fan Shrouds(allows stock fans clear the Mishimoto, aftermarket slim fans suck!) JDM In Fender Coolant Expansion Tank 07 WRX Fuel Tank AEM 320LPH Fuel Pump (E85 Safe) Prodrive 3-Port Boost Solenoid Grimmspeed 3mm Phenolic Intake Manifold Spacers K&N Typhoon Short Ram Intake AP Racing Hard Turbo Inlet (too hard to find an APS) TurboXS V2 3" Downpipe & Catless Test Pipe TurboXS 3" Stealthback Midpipe Prodrive Round Tip Axleback Exhaust (2.5") Cusco Catch Can Innovate Motorsports ECF-1 Ethanol Content Analyzer Carberry ROM(Flexfuel) Suspension: 02 WRX Rear Subframe 07 STi Front Subframe 07 STi Steering Rack Unabomber's Sexy Rear End: -Kartboy Rear Subframe Lock Bolts -Kartboy Diff Outrigger bushings(race) -Whiteline Rear Diff Bushings 05 STi Aluminum Lateral Links 05 STi Aluminum Front Control Arms 98 Forester ALK Housings Bakemono Rear Camber Plates Whiteline Group 4 Coilovers Whiteline 5kgf/mm Front Springs Whiteline 4kgf/mm Rear Springs Whiteline 27mm Adj. Front Sway Bar (Adjusted to 29mm) Whiteline 24mm Adj. Rear Sway Bar (Adjusted to 22mm) Whiteline Caster Adding ALK Bushings Turn in Concepts Rear Trailing Arm Bushings Powerflex Front Trailing arm Bushings Powerflex Lateral Link Bushings Perrin Spherical Bearing Front Endlinks F&R Superpro Front Control Arm Front Bushings Alignment Specs: -2.0 Degrees Front Camber +5 Degrees Caster -1.5 Degrees Rear Camber 0 Toe all around Wheels & Tires: Enkei RC-T4 18x9.5 +30 (Painted Gold) -20.5 LBS Enkei 75mm to 56.1mm Hubcentric Rings Michelin Pilot Super Sports in 275/35/18 ARP Extended Studs Muteki Open Ended Lugs - Matte Black Brakes 05 STi 1 1/16th inch Master Cylinder 95 Impreza L Single Stage Brake Booster 01 RS ABS System "Prodrive" BBK
Speed Bleeder Screws x8 Goodridge SS Brake Lines F&R Stop Tech Street Performance Pads F&R Drive Train: JDM Version 8 STi DCCD 6MT Competition Clutch Stage 3 Ceramic Segmented Clutch Kit JDM Version 8 STi R-180 Rear Diff 06 STi Drive Shaft 06 STi 5x114.3 hubs 05 STi Axles DCCDPro Deluxe DCCD Controller(manual/Auto mode with STi switches and STi Cluster interface) Kartboy Rear Shifter Bushing |
12-01-2018, 09:04 PM | #2 |
Member#: 184183
SCIC
I guess the most logical place to restart is with some pics!
12-01-2018, 09:06 PM | #3 |
Member#: 184183
SCIC
Track day shots at Buttonwillow:
12-01-2018, 09:13 PM | #4 |
Member#: 184183
SCIC
Glamour shots
12-01-2018, 09:18 PM | #5 |
Member#: 184183
SCIC
12-01-2018, 09:21 PM | #6 |
Member#: 184183
SCIC
And a few more from an autox and the subiefest autox:
Subiefest this past year: |
12-01-2018, 09:25 PM | #7 |
Member#: 176408
SCIC
Vehicle:2005 EJ207 STy White |
Car looks awfully shiny in the last set of photos
12-02-2018, 02:57 AM | #8 |
Member#: 34368
awesome build. wish I had the funds to finish my car like that!
12-04-2018, 03:02 PM | #9 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Out of all of that awesome-ness, I'm going to ask about this. I've got a '96 Brighton, and have no intentions of completely revamping it like you did yours, but I do appreciate convenience mods.
I assume the wiper stalk gives you variable intermittent speed? Is there anything special about using a GD/GG wiper stalk (as opposed to one from a GC/GF/GM)? I actually haven't looked in the junkyard at other Imprezas, but I guess I would've assumed that other GC/GF/GM cars (with higher option content than my lowly Brighton) had variable intermittent wipers. |
12-04-2018, 03:40 PM | #10 |
Member#: 283637
Vehicle:2005 STi OBP |
Damn... this is pretty awesome.
Hows the brake balance with the 6pots front and 2pots rear? |
12-04-2018, 09:07 PM | #11 |
Member#: 184183
SCIC
Not much different than stock due to the pistons having less area that the stock Brembos. According to the math it shifts slightly forwards but it hasn't been noticeable to me
12-04-2018, 09:06 PM | #12 | |
Member#: 184183
SCIC
None of the GC cars at least in the US had the intermittent wiper stalk. The GD is PnP to the 98 ans up cars I'm not sure it will fit on the 93-96 tho. There may be an early Legacy that has the 93-96 style plug/stalk and intermittent wipers. This thread explains what you need for the pre 98 impreza: https://forums.nasioc.com/forums/sho...d.php?t=559808 |
12-04-2018, 11:12 PM | #13 | |
Member#: 120
AKIC
12-05-2018, 02:20 PM | #14 | |
Member#: 284221
MAIC
Vehicle:2011 WRX GV SSM 2013 MacLeod |
Nice car! |
12-09-2018, 11:12 AM | #15 |
Member#: 37229
Bro. Your car looks refined. I mean the way you did the 22b widebody is spot on. I see other 22b replicas and there is just something off about it. Props for all the hard work that went into this.
02-26-2019, 08:06 PM | #16 |
Member#: 184183
SCIC
Rainy trackday at Streets of Willow
02-28-2019, 03:18 PM | #17 |
Member#: 234236
RMIC
Vehicle:06 STI AW |
I know this is an older post but I was wondering where you got your brackets made and if they'd make more! Love the car! I hope to do something similar!
02-28-2019, 05:02 PM | #18 |
Member#: 2258
Tri-State
Vehicle:1999 gc8 ver7 6mt GT35R 504.7whp;) |
Very impressive. Your car's a nice balance of classic, exotic, and modern Subie. Tasteful, functional, clean, and fast.
It's like the best GC touches, 22B styling, GD technology, and a sprinkle of aftermarket without going full mod. Really cool. How much planning/time went into it and how long did the full build take? |
03-24-2019, 11:30 AM | #19 | ||
Member#: 184183
SCIC
03-24-2019, 11:31 AM | #20 |
Member#: 184183
SCIC
Subie challenge round two was last weekend at Chuckwalla Raceway. This was my first time at Chuckwalla.
My first session I got a 2:30.5 lap as my best. I managed 2:21.5 in the second session saving 8 seconds off. The fastest time of the S2 class in was a 2:04. I'm happy to be getting some seat time in as the car is totally different than before and I'm used to lower speeds of autox so the road courses take some getting used to. Unfortunately a few laps into my 3rd session the throw out bearing popped out of the pressure plate and I had no clutch after that. I was able to get it back to the paddock but my track day was cut short. AAA took forever to come and i had to take two different trucks to get home. |
03-24-2019, 11:31 AM | #21 |
Member#: 184183
SCIC
I had just swapped out my Competition Clutch for a Exedy OEM replacement and lightweight fly wheel(I have hated the Competition Clutch, stiff and makes noise when you feather the clutch).
I'm not sure why the TOB popped out of the pressure plate but ill be pulling to motor today to find out. |
03-24-2019, 11:49 AM | #22 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
nice, looks like a great day at the track, yeah I have a act clutch and i hate the thing. i was thinking of trying a southbend. A friend of mine has one and its alot lighter than the act.
BTW what camera is that you are using? |
03-25-2019, 10:27 AM | #23 |
Member#: 184183
SCIC
The front camera is my IPhone XS and the rear is a GoPro Hero3+
03-25-2019, 10:58 AM | #24 |
Member#: 243697
MAIC
Vehicle:2002 TOPSCOOB031 HighwaystarGarage |
Best 96 I've ever seen? Quite possibly!
03-25-2019, 11:09 AM | #25 |
Member#: 499465
MWSOC
Vehicle:2011 STI WR Blue |
Ya it looks gr8
