09-05-2018, 02:43 AM | #1 |
Member#: 446288
IL: Price Drop! $9.9k Built 2002 WRB WRX STi W/ rotated 35R, IAG Closed Deck
Pains me to do so but I have a MINT condition 2002 WRB Subaru Impreza WRX that was fully swapped to a 2004 WRX STi and currently has an IAG STAGE 2.5 EJ25 SUBARU CLOSED DECK SHORT BLOCK, rotated Garret 35R, and a 2004 WRX STi 6 – Speed manual transmission with a working DCCD controller. Car was purchased nearly 2 years ago out of a garage in southern Indiana and built by 6 Star Motorsports starting on February 26th*and since have put around 2,2xx miles on it and $14,000+. I have well over $20,000 in just performance modifications not including the full STi swap. Was emissions tested may of this year and passed. Car does not get driven as often as I was intending on so these miles will not fluctuate as much, one of the main reasons I'm selling. This car will make the perfect track monster with the proper set of tires or even a great daily for anyone looking to have more power than the average Subaru.Car is 16 years old although most of It's life was spent in a garage it does have some small scratches and rock chips but paint is in immaculate condition! Looking to get around $9,900 which is fair given the condition the car is in and also the detailed list of modifications. I will entertain trades, please message me with any questions or concerns. Detailed build sheet will be provided to those who are interested.
- Car has issue with wiring and keeps blowing fuse. Will idle for 30-40 seconds then will lose fuel and die, price reflects that. Year: 2002 Model: WRX STi Mileage: 117k on body, 65,xxx on EJ257 and 6-Speed STi Transmission -2,xxx on build Power: (on base map) Asking: $9,900 or make offer Location: Lemont, IL Zip: 60439 Title Status: Car will be paid off upon sale @ State Farm Clean otherwise. (Took these while it was raining lightly, images may look like dust was on lens. Better pics updated soon.) UPDATE: MOTIVATED TO SELL, FIND ME A BUYER AND GET 300$! Build List: 04 WRX STi EJ257 ~60k miles 2k miles on fresh build 04 WRX STi 6-Speed Transmission with working DCCD ~60k miles ENGINE: STAGE 2.5 IAG EJ257 CLOSED DECK IAG Stage 2.5 Closed Deck * S3 Closed Deck Case Halves * Manley 99.75 Pistons * IAG Spec Hone * H Tuff rods * ACL Bearings ARP Head Studs Unknown ELH APS 500 FMIC Tial 44mm EWG Tial 44mm blow off valve Gates Timing Belt Kit Killer B Ultimate Oil Pickup (Wired for Speed Density Tuning) Aeromotive FPR Aeromotive Fuel Rails ID1050X Top Feed Injectors TURBO: GARRET 35R Garrett GT3582r .63 (35R) Ultimate Racing Rotated Kit * Ultimate Racing Up-Pipe * Ultimate Racing 3" Stainless Steel Downpipe * Ultimate Racing Stainless Steel Wastegate Dump SUSPENSION/Drivetrain: Driveshaft Shop Upgraded CV Axle Front Driveshaft Shop Upgraded CV Axle Rear Tein Coilovers Adjustable rear lower control arms MISC: Walbro 450lph Cobb V2 Accessport Slotted front and rear rotors ACT Heavy Duty Performance Street Disc Clutch IAG PERFORMANCE COMPETITION SERIES AIR / OIL SEPARATOR Apexi turbo timer Harness Bar Installed HKS hi power exhaust Oversized Tachometer Boost Gauge attached to Steering Column Digital A/F Ratio Gauge Stock 16” WRX Wheels FOLLOWING PARTS WERE JUST ADDED TO BUILD AND HAVE LESS THAN 2K MILES, BUILT AT SIX STAR MOTORSPORTS * IAG Stage 2.5 Closed Deck * S3 Closed Deck Case Halves * Manley 99.75 Pistons * IAG Spec Hone * H Tuff rods * ACL Bearings * Gates Timing Belt Kit * Killer B Ultimate Oil Pickup * ACT Heavy Duty Performance Street Disc Clutch * ID1050X Top Feed Injectors * IAG PERFORMANCE COMPETITION SERIES AIR / OIL SEPARATOR MISC * New Wheel Bearing hub and bearings * New Oil Pump * New Oil Pan * New Engine Mounts * New front O2 Sensor Left out a lot of the small stuff, detailed list can be sourced if interested. Car was babied and does not get the attention it deserves, please take this to the right home and give this the road time it deserves! Will be able to take other detailed pictures shoot me a text for faster responds 1-630-423-2zerozerozero
12-19-2018, 06:37 PM | #11 |
Member#: 493793
Do you have any interior pictures? You mention the car is mint. Is it rust free? I see rust on the coolant overflow reservoir and the bolts on the radiator support look rusty and some look loose.
Any brake upgrades? What would it take to get the AC functioning again? |
12-20-2018, 02:20 AM | #12 | |
Member#: 446288
