Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 05-15-2018, 12:08 AM   #626
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by jawang213 View Post
having the same issue as you guys. i have an 06 wrx with a p0171 only mods i have is an AP with stage 1 91 octane tune map and a invidia down pipe heres what ive replace/checked
replaced upstream a/f sensor
replaced downstream 02 sensor
replaced leaking intake manifold gasket
swapped/cleaned MAF sensor (swapped with good reliable one)
checked fuel pressure 38-40psi 50-52psi with return line clamped
smoke tested intake system (found no additional leaks)
replaced pcv hose
cleaned throttle body
replaced air filter
noticed that this code only appears when im at idle. checked my fuel trims with obd tester and found that its sitting at max correction +25% which would indicate lean but when analyzing 02 sensor it indicates rich condition (which you can noticeably smell) looking for any ideas of anything to check or replace code came on out of nowhere no major repairs or no tune changes. please help!
Where did you buy your wide band sensor? also how do you know the MAf is good?
Old 05-31-2018, 04:07 PM   #627
LGCjairen
Member#: 486639
2005 wrx, 9-2x
silver :(
to add my fix to this.
05 wrx, started throwing code and running like garbage. before i got the code i would get mild surging/hesitation at wot. after the code and running like garbage i started getting misfire codes along with the 171.
fpr/fuel pump and filter solved all of it. took that opportunity to switch the fuel filter to the engine bay like the 02-04 wrx
LGCjairen is offline   Reply With Quote
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
