Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 09-20-2018, 03:55 PM   #1451
Bellipotens
Member#: 380646
2015 WRX Premium CVT
Glad it worked out for you
Bellipotens is offline   Reply With Quote
Old 09-26-2018, 11:48 AM   #1452
steve30avs
Member#: 426821
Just did the update, all looks well. My car was 3 updates behind on the ECU.
One question, are we allowed to sell the reprogramming CD when we are done with it? I haven't seen any discs around online, so I wouldn't want Subaru chasing after me haha. Just looking for some opinions.
steve30avs is offline   Reply With Quote
Old 09-26-2018, 04:47 PM   #1453
Ryann04
Member#: 392270
You could just post it for us to download.
Ryann04 is offline   Reply With Quote
Old 09-26-2018, 05:57 PM   #1454
Perscitus
Member#: 378214
Take this offline please. No need to pollute my brother's already fairly polluted build thread further.
Originally Posted by steve30avs View Post
Just did the update, all looks well. My car was 3 updates behind on the ECU.One question, are we allowed to sell the reprogramming CD when we are done with it? I haven't seen any discs around online, so I wouldn't want Subaru chasing after me haha. Just looking for some opinions.
I'd avoid doing so. I have 3 CDs (2016-2018; all dumped to USB,), so multiple DBs with all their associated PAK files. People would not only need the DB and their PAK file/s of interest but also the SSM software, which gets licensed.
Did you check for any EPB, BIU, CAMERA, TCU reflashes or just do the ECU for now? If you have the latest CD (Jul-2018) then you're on the final/last reflash the 2015-2017 WRXs will ever get from SoA.
Perscitus is offline   Reply With Quote
Old 09-26-2018, 08:27 PM   #1455
steve30avs
Member#: 426821
I did, those were all up to date oddly enough.
Old 10-13-2018, 11:49 PM   #1456
Bellipotens
Member#: 380646
Update:
So time has come for me to discuss CVT fluid change.
At 50k miles
I initially was not going to do this because up to now the color of the fluid and level looked good on my car (I did tests from time to time of the fluid by opening up the fill drain and inspecting its color on a white towel)
What caused me to move in the direction of needing to flush the fluid was the state of the cvt cooler lines. Before we go there the Mishimoto cooler is a very good cooler, it is actually a Setrab cooler.
Upon inspection the cooler was holding up great. No leaks or other issues with it (Was on my car over 4 years now). Now the lines they offer in the kit are ok but will not last too long sadly.
I began to notice numerous cracks in the hoses, mainly at the biggest stress points and that is where the hoses had to make a curve or at the connection points.
I reached out to Setrab and decided to purchase their transmission fluid hoses. I picked the ProLine Lightweight Fiber Braided Hose. Item description from Setrab:
SUSA LWN Lightweight Fiber Braided Hose is a stainless-steel-reinforced hose with a light-weight nylon outer-braid to provide traditional performance characteristics in a lighter-weight package.
Constructed of a chlorinated polyethylene (CPE) synthetic rubber, reinforced with a stainless-steel inner-braid, and protected by a light-weight nylon outer-braid.
Continuous operating temperature from -40F to 300F. Suitable for fuel, oil, coolant, and air.
Once the hoses arrived I immediately noticed the good quality, even my master transmission mechanic loved it. You will need two 5.5-6 feet hoses. 21-LWN08-B with the internal diameter of 0.44 inches.
I initially purchased the 21-LWN06-B but the internal diameter of 0.34 only can fit the Mishimoto cooler lines (very tight fit) but will be unable to fit the transmission line connectors on the car.
I have been talking to various amsoil engineers who worked on the cvt fluid and the decision for me to use their CVT fluid once I need to flush it was made a while ago.
I've used amsoil products in the past and even with this car when I had to change the differential fluid. The specs of their CVT fluid are very good and it is rated for our high Torque CVT (TR690).
The best part is that you do not have to purchase that enormous amount from Subaru when purchasing the orange CVT fluid. Various sizes can be purchased from amsoil.
During the drain process we were pleased to see the good color of the old CVT fluid that was draining out of my car. Still nice and orange but of course a bit darker than new. At 50k miles of numerous fun spirited drives this shows the importance of performing the stock cooler/warmer bypass. My master mechanic was pleased to see this and reported if you want to do it right you bypass the stock cooler. The stock cooler setup eventually burns the fluid and braises the TC and VB internals.
Drain and Fill in a nutshell:
So process was rather straight forward. Disconnect the lines and clean up the fluid that drained out of them (Have some towels ready). Attach new setrab transmission hoses.
Drain CVT fluid from the pan. I ended up flushing 6 quarts out of the pan. The total fill is about 13.1 qts.
I filled using the main fill plug and then the second fill plug a bit higher on the side of the transmission.
We used my master transmission mechanics transmission pump to pour it all in (Setup can be seen on the photos)
Of course make sure the car is warmed up - all is in the manual.
Opinion:
As stated above I am very pleased with the Mishimoto cooler. Definitely required lin upgrade but that's where Setrab ProLine Lightweight Fiber Braided Hose comes to save the car.
Amsoil CVT fluid in my opinion is great. I felt an immediate difference once it was in. To me there was a distinct improved "grip" of the CVT chain. Transmission sounds were also changed to lower levels.
Acceleration was another improvement but thats is related to the improved grip. Temperatures seemed a bit lower after spirited driving compared to before.
Overall I would recommend the Mishimoto cooler (Its a Setrab cooler), Setrab ProLine Lightweight Fiber Braided Hose and Amsoil cvt fluid.
Always special thanks to my brother Perscitus for helping me out with the project and to the secret master transmission mechanic aka "the master."
Links to items:
1. Setrab ProLine Lightweight Fiber Braided Hose 21-LWN08-B
2. Amsoil CVT fluid
Mishimoto cooler doing well at close to 5 years
Drained out CVT fluid (pan is dirty so just focus on color of the fluid)
Mishimoto kit lines failing
Setrab hose - old on the left and new on the right
Filling with Amsoil CVT fluid
Old 10-13-2018, 11:52 PM   #1457
Bellipotens
Member#: 380646
Amsoil CVT fluid
I also replaced my gatorback belt with this Continental Elite Poly-V belt while we were at it
Also made some connectors for the JDM LED bezels
Old 10-14-2018, 12:07 AM   #1458
djemzine
Member#: 361609
2015 WRX CVT
WRB Pearl
Originally Posted by Bellipotens View Post
Update:
At 50k miles
Opinion:
Links to items:
2. Amsoil CVT fluid
Awesome update Bellipotens and definitely shall purchase the Setrab lines to replace the ones that came with Mishimoto.
djemzine is offline   Reply With Quote
Old 10-14-2018, 11:33 PM   #1459
Bellipotens
Member#: 380646
I finally joined instagram.
Just search for bellipotens.
My profile photo is the black and white front end photo that is the first on this thread.
See you on instagram
Old 10-15-2018, 09:38 AM   #1460
Obviously Tyler
Member#: 395955
2018 Mazda 3 GT
2018 Crosstrek
I'm sure it's been said before but thank you for blazing the trails on these WRX CVTs.
I think other owners are going to have the confidence to do these things in the future.
It's nice to see an option on the CVT fluid as well.
Obviously Tyler is offline   Reply With Quote
Old 10-15-2018, 06:30 PM   #1461
Bellipotens
Member#: 380646
Always enjoyed the journey with this car and glad you liked this thread as well. As for the CVT fluid by amsoil, to me it is a good choice over the OEM orange fluid.
Old 10-21-2018, 10:07 PM   #1462
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
Another great post by the now world famous and Iconic Mr. Belli!! Thanks Bro for all you do for the community!!
hekler is offline   Reply With Quote
Old 10-21-2018, 10:11 PM   #1463
Bellipotens
Member#: 380646
You have been a big part of this journey as well Hekler!
Old 11-10-2018, 05:17 PM   #1464
Nahoward
Member#: 486869
2018 WRX
Lapis Blue
So pulling everything together with the CVT Cooler, if I'm looking to add one to my '18 WRX, go with the Mishimoto, and instead of using their hoses, go with the Setrab "ProLine Lightweight Fiber Braided Hose" listed at http://www.setrabusa.com/products/hose/index.html .
That sound about right?
Nahoward is offline   Reply With Quote
Old 11-10-2018, 10:43 PM   #1465
Perscitus
Member#: 378214
You've answered your own question. Basically yes, that is one way to tackle it. Just get the right-sized and lenght hoses and good fittings.
Alternatively skip Mishimoto all together - use a Setrab unit directly (you'd be missing out on the OE like bracket, AN fittings, clamps) or use an entirely different aux cooler (for example the Ascent OE engine oil cooler).
Then decide how you want to plumb your aux or replacement cooler (in-line after rad, in-line before rad, bypass mode, thermo bypass, etc), if you want to add forced convection (slim profile fan).
Finally find a solution to monitor your CVTF temps (ideally before you mess with anything to get a baseline) and see how your changes affect the temps (avg temp, peak temp, time to warm up, time to cool off).
Old 11-12-2018, 11:51 AM   #1466
Bellipotens
Member#: 380646
Yes Sir. Make sure to get the LWN08 size lines from Setrab
Old 11-12-2018, 08:22 PM   #1467
rrrrrrrz
Member#: 493962
:+1: sweet build
rrrrrrrz is offline   Reply With Quote
Old 11-14-2018, 11:23 PM   #1468
Bellipotens
Member#: 380646
Fall color extravaganza and Bellipotens cockpit
Old 11-15-2018, 12:33 AM   #1469
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Possibly silly question, but does the HTCVT allow the WRX to "drift" in the snow with TC off? All of the standard Subaru CVTs and the BRZ 6MT I've driven/owned won't let the car get too sideways, unlike my 4EAT 01 Impreza RS coupe and manual transmission 11 WRX, 05 STI and 08 Forester XT.
Whenever it snows I don't get excited anymore since the new Subies don't seem to really "play" in it.
Old 11-15-2018, 01:17 AM   #1470
hackney1
Member#: 391014
'18 Prem. Perf Pkg
ISM
Umm, did you hold the Traction button down for a few seconds? That shut off both TC and VC in my '16 CVT and my '18 MT.
hackney1 is offline   Reply With Quote
Old 11-15-2018, 01:34 AM   #1471
chanomatik
Member#: 159474
SNOSLO
Yaaassss. You didn't specify which model you're referring to, but I assume 15+ WRX. I've only driven the 15 WRX 6MT during the summer. I'm curious to know how out-of-control the HTCVT gets in the WRX with TC (and I guess VC, too) turned off during snowy winters.
I'm patiently waiting for the next gen WRX/STI. Depending on if there's a 5-door or not, along with HTCVT, I might swoop one up or wait for the next gen BRZ. I miss having something fun to drive, but having the ABS kick in so early even with TC off is just soul-sucking.
Old 11-15-2018, 11:24 AM   #1472
Perscitus
Member#: 378214
Great fall photos!
Re recent posts, likely a question best put in the Technical section of the forum. No interest is TC/VSC on/off here.
Old 12-07-2018, 09:28 PM   #1473
Bellipotens
Member#: 380646
Blind spot mirrors and an Ecutek Update Tease...
New blind spot mirrors - ultra low profile. As always I love whatever adds a nice clean look to my car
and these ultra low profile blind spot mirrors do just that with a very nice large area of vision.
Easy install. No moving parts so they are always positioned well
(some blind spot mirrors can be adjusted - like the ones I replaced -
gets annoying at times to fix them - not these).
Link to the item:
https://www.abstractocean.com/blindspot/
Old 12-10-2018, 05:39 PM   #1474
jbatarseh11
Member#: 445220
2016 WRX
Can someone out in Minnesota pls lend your CVT to MAperformance so they can make maps for us CVT owners to use on our accessport instead of the Cobb maps. MAperformance has semi aggressive OTS tunes for the manuals so it would be cool to be able to slap one of those on my CVT heck Bellipoten should just take a road trip out there for a week or 2.
jbatarseh11 is offline   Reply With Quote
Old 12-10-2018, 05:41 PM   #1475
Bellipotens
Member#: 380646
Haha! I did drive once from NYC to Cali and back. But in another car.
