Tire & Wheel Forum sponsored by The Tire Rack |
05-17-2011, 02:27 PM | #426 |
Member#: 280020
International
Vehicle:08 WRX OBP |
any of you guys running into issues being lowered on springs? More specifically the tein ones... XD
I got them a few months ago, and tonight I happened to come across the suspension sub-forum and nearly cried. Wondering if they are still a big no-no on the 08+'s.
05-17-2011, 03:29 PM | #427 |
Member#: 110783
Vehicle:2010 WRX Satin White Pearl |
Some springs are designed for the stock shocks in mind so the stock shocks will last longer. All stock shocks will blow eventually though; you're going to have to replace them eventually, it just depends on when. If you track the car, then they'll obviously go faster than if you only daily drive on them.
05-17-2011, 11:22 PM | #428 |
Member#: 225167
Vehicle:2009 wrx sdn dgm e85 332whp 370wtq |
How are some of you getting the camber angles that are pretty aggressive? I have seen -2 in the front on some of yours. Is it just because you are that low?
05-18-2011, 08:27 AM | #429 |
Member#: 253642
NESIC
Vehicle:2008 Impreza 2.5i SSM |
05-18-2011, 09:32 AM | #430 | |
Member#: 231674
Vehicle:2010 Impreza WRX Obsidian Black Pearl |
most decent coilovers come with front camber plates or some sort of front camber adjustment. Its the rear that is a little more difficult. |
05-19-2011, 10:40 PM | #431 |
Member#: 225167
05-19-2011, 10:42 PM | #432 |
Member#: 225167
05-23-2011, 01:58 PM | #433 |
Member#: 283566
Vehicle:2016 WRX Premium MT Ice Silver |
05-23-2011, 02:55 PM | #434 | |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
05-25-2011, 04:17 PM | #435 |
Member#: 236952
Vehicle:2010 WRX (SSM) Stg 2+ 310/370, 6sp R180 |
Work Emotion CR Kai
17x9 +44 no spacers still no fender work same tires as before, 245/40/17 Conti Extreme DW i loved my gold wheels, and they were a lot lighter than these, but i think these look a little better and the size is more what i wanted in the long run. being a non-lip wheel, they look larger and have that nice concave look because of the width/offset. and still doesnt rub (that ive noticed). |
05-25-2011, 10:55 PM | #436 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
^ Very nice, I was curious how that exact spec setup would fit.
05-29-2011, 04:46 PM | #437 | |
Member#: 255776
Vehicle:2010 LR WRX MPS powered. |
05-29-2011, 05:02 PM | #438 |
Member#: 236952
I'm probably right on the edge of rubbing. 255s will probably rub.
Offset of your wheels will play a huge roll too. I got these wheels because of the +44 offset. They were a custom order from Work (I think 17x9 +44 normally is an STI fitment) Most 17x9s are a +38 or +42. |
05-29-2011, 08:53 PM | #439 | |
Member#: 220629
SCIC
Vehicle:2010 White WRX Hatch 2015 White WRX Limited |
17x9 +45 rays g07wt 17x9 +44 ce28n's |
05-31-2011, 10:21 AM | #440 |
Member#: 251060
Vehicle:2008 Impreza Outback Black |
My 2008 Outback Sport
Wheel Specs: Sport Tuning AS-1 18x8 +35 offset powder coated flat black Tires: 225/40-18 Suspension: STi springs, stock struts. Fender Modification: None, definitely need to roll them soon, Rub all the time in the rear. Right now, i'm in the market for new wheels, tires, and coilovers. |
07-06-2011, 10:19 PM | #441 |
Member#: 196570
NWIC
Vehicle:2014 WRX Hatchback Black |
2010 WRX 5-door
RPF1 18x8 +45 gold 225-40-18 Conti DW RCE Yellows + RCE Billies It looks a bit stretched and the the tire performance is not to my liking. No rubbing with current setup. Does any one have experience with this wheel and 235 tires? -WK |
07-07-2011, 10:02 AM | #442 |
Member#: 110783
I'm surprised your 225 is stretched on an 8" wheel. Either they run a little narrow or the 225s I had on my 8" wheels on my previous car ran a little wide.
07-07-2011, 02:57 PM | #443 | |
Member#: 185688
NESIC
Vehicle:2006 STi WR Blue |
2008 WRX Sedan XXR 18x8 +45 gold 245/35/18 Conti DWS Xtreme Megan Racing Coilovers (dropped 1.25") |
07-07-2011, 11:36 PM | #444 |
Member#: 280718
South East
Vehicle:2009 WRX SWP |
Roadtrip, did you need Coilovers for inside clearance?
07-10-2011, 07:32 PM | #445 |
Member#: 185688
NESIC
07-10-2011, 07:39 PM | #446 |
Member#: 280718
South East
Thanks, because I already have Swifts installed.
07-14-2011, 12:45 AM | #447 |
Member#: 206899
Vehicle:2009 wrx pearl white |
hey, nice cars. Can someone tell me what size spacer I would need to make my stock 16" tires on my 2.5i flush with my fenders? I am running Koni Adjustables with Eibach lowering springs and Rallitek front + Rear sway bars. My car is lowered about 1.4" all around. I'd like to avoid rolling the fenders if possible. Thanks
07-14-2011, 07:40 AM | #448 | |
Member#: 251060
My wheels are almost flush and my tires rub my fenders all the time, and I'm not even lowered. |
07-14-2011, 08:35 AM | #449 |
Member#: 206899
okay, well i guess not completely flush, lol. Just want the rims to come out a little wider to get rid of some of that gap.
07-14-2011, 08:53 AM | #450 |
Member#: 230272
NESIC
Vehicle:07 STi WhiTe |
18x9 +40 with a 225/40/18's on my 10 hatch
and my husband has 18x9.5 +44 5mm spacers in the rear with 235/40/18's on his sedan. Both are rolled and pulled A LOT - no rubbing . Our tires have a little stretch and we have no negative camber in the front. Both cars handle amazing with no performance issues at all. |
