Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2024
Old 03-05-2006, 12:28 AM   #1
fifth.
Member#: 106370
2006 WRX sedan
give me some parts :P
Default whats wrong with my car!?!?! HELP ME OUT GUYS!!!
whats up guys?? ive got a question to ask and hopefully the people here can answer it for me ok, ive got a 06 wrx and ive had it since december of last year, and recently...like 4 days ago...the clutch when i realease it feels like its shaking??? the best way i can describe it is it feels like your leg is twitching when you release the clutch pedal. it does it when its neutral as well as when its in gear. this is my first subie so im still learning any suggestions/ ideas what could be wrong with her??? all the help i get is greatly appreciated...TIA
and in case you are wondering...i havent abused the car at all, i have only gotten on it once so far, i barely shift higher than 3xxx, im trying to be nice to her
fifth. is offline   Reply With Quote
Old 03-05-2006, 12:30 AM   #2
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
shaking?? or shudder..
You can't drive these cars like a honda or something.
Is it your first awd car? It drives like my gsx did,but was very different from the prelude.
enewtabie is offline   Reply With Quote
Old 03-05-2006, 12:33 AM   #3
fifth.
Member#: 106370
2006 WRX sedan
^^ yeah, shudder...shaking was the only word i could think of to use
yea, its my first AWD car...and yea, i owned a honda before i got this car, perhaps i dont it the same???
Old 03-05-2006, 12:35 AM   #4
Tim-H
Member#: 65751
'10 VULVA
if its shaking the pressure plate fingers may be damaged, if its shudder you glazed the clutch and it will go away.
Tim-H is offline   Reply With Quote
Old 03-05-2006, 12:38 AM   #5
fifth.
Member#: 106370
2006 WRX sedan
im hoping its nothing bad like that. all of which is covered by warranty correct?? is the clutch on a wrx prone to damage that easily??
Old 03-05-2006, 12:39 AM   #6
23b_Rex
Member#: 79394
02 gda
wrb
clutch shudder... not just for '02s
23b_Rex is offline   Reply With Quote
Old 03-05-2006, 12:39 AM   #7
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
You can't dump the clutch for one thing..a little slack is required..
I'm not sure I can explain it right..On the prelude,you could just dump it most of the time with not problem,but with my WRX I let it out a little slower..I'm on the stock clutch four years later..
Old 03-05-2006, 12:42 AM   #8
Tim-H
Member#: 65751
'10 VULVA
a damaged pressure plate would be covered by the warranty, yes. I don't think a glazed clutch is but it will go away after driving it a few times anyway.
Old 03-05-2006, 12:42 AM   #9
fifth.
Member#: 106370
2006 WRX sedan
thats one thing i DO know about awd cars i have never attempted to "dump" the clutch...im too afraid
but in regards to the pressure plate, how could it become so easily damaged???
Old 03-05-2006, 12:43 AM   #10
fifth.
Member#: 106370
2006 WRX sedan
it has been doing this for about 2 days now...i only have 36xx miles on it
Old 03-05-2006, 12:46 AM   #11
Tim-H
Member#: 65751
'10 VULVA
I don't know for sure if that's what is wrong so don't take my word for it. but I've had a damaged pressure plate and it felt like what you are describing. I would assume it's just defective if it were damaged this soon.
Old 03-05-2006, 12:49 AM   #12
fifth.
Member#: 106370
2006 WRX sedan
^^thanks for the help man, i really do appreciate it. i just dont want my baby to have any problems.
any other ideas???
Old 03-05-2006, 01:37 AM   #13
parker
Member Status: Member
Member#: 46241
- Can I get
a wayo
Get to where you can re-create the shudder and take a service tech for a ride at your dealer.
parker is offline   Reply With Quote
Old 03-05-2006, 02:47 AM   #14
RexisMe
Member#: 96821
well, i noticed that if i dont shift above 3300 rpms, it seems like my car bucks, or almost as if i dont know how to drive a manual. even though i've been driving them all my life. From what i have read, the wrx is one of the trickiest cars to drive manual whether it be an sti or a regular wrx. then some days, it seems like my car is a well oiled machine and ive been driving manual all my life (like i have).
RexisMe is offline   Reply With Quote
Old 03-05-2006, 03:51 AM   #15
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Sorry but as far as normal driving, AWD, FWD or RWD engaging the clutch is all the same. It doesn't matter what RPM you decide to upshift so long as you let go of the gas(i.e you don't power shift like an idiot) and you don't end up in too low RPM range(like upshifting at 2000rpm and ending up at 1000 rpm- that still wouldn't cause clutch damage but you're engine would hate ya).
Well here's the most important question- would you say the whole car or more then just your foot shakes when ya engage it?
If so, get it looked at. Pressure plate fingers are just 1 thing that could be wrong. You're also looking at possible rear main seals on the engine leaking or front seals/bearings on the trans leaking into the clutch assembly.
If not, you indeed don't know how to drive stick and glazed the clutch during it's break in period and already burned it out(real important to go easy on break in period).
Either way get it looked at from your dealer. Just prepare to pay up for a new clutch/pressure plate if you indeed burned the clutch up(only you know how you drove it). If you sincerely drove it correct and know you didn't abuse it at all during it's break in period and they say just a bad clutch only- argue that it may of been misaligned then(this happen with a friends honda, clutch burned out at 600miles and they tried to dump a clutch misalignment on abuse). If somethings leaking into the clutch assembly it will be warranty work and recorded that it had problems for later observations. Mis-aligned clutch also counts as warranty work.
EtoS is offline   Reply With Quote
Old 03-05-2006, 05:08 AM   #16
fifth.
Member#: 106370
2006 WRX sedan
the doesnt shake at all. its just, i feel a "vibration" in the clutch pedal, like your leg is twitching, when you RELEASE the clutch...i.e bringing it up off the floor.
i DO know how to drive a stick, my last car for 7 years was a 5speed, so im pretty sure that we can rule out that i cant drive a manual trans.
i hope i dont have to pay for a new clutch or anything like that, i havent beat the car at all, and the time i DID get on it, it was only 2/3rd gear, and then i let off and slowed down...i just wanted to feel what it was like to have a boosted car. all of which happened when the car had around 3xxx miles on it already. thanks for the info as well
Old 03-05-2006, 06:55 AM   #17
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
So long as there's no blueing, hard spots or warpage on your pressure plate/fly wheel- most likely they would warranty your clutch as defective. Maybe they might stick ya all together. Just tell them "hey i just bought this car from ya guys and it has no more then 3000+change and I get clutch chatter/shudder- what gives? I'm bringing it in to get it looked at." Explain to them the truth. Trust me if you really did abuse it they will find out and you're stuck with the bill and they'll secretly mark ya down as a stiffer and it could make it hard for you to get warranty work done on for real.
Old 03-05-2006, 07:58 AM   #18
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
Just to clarify when you release the clutch pedal off the floor you are actually engaging the clutch and vice versa.
D fresh is offline   Reply With Quote
Old 03-05-2006, 07:09 PM   #19
fifth.
Member#: 106370
2006 WRX sedan
sorry guy, i meant when your bringing it up off the floor...
english > me
Old 03-23-2006, 02:49 AM   #20
fifth.
Member#: 106370
2006 WRX sedan
**UPDATE**
so i took the suby into the dealership today to get the oil changed, and to have them check the clutch. turns out that they have had 8 other 06' wrx owners bring their cars in with the same problem as me. they said that its just the way the car is...i hope they were right
Old 03-24-2006, 02:13 AM   #21
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Find some other friends with Subarus and have them drive your car, or take it to a different dealership and have them evaluate it, some dealerships are real bad about warranty work. We bought a '98 Outback new and it started popping out of first or second gear when you decelerated in gear, after about 20K miles. They flipped us a lot of crap before they finally agreed to fix the shifting detents in the trans, only after an evil e-mail from me to SOA about this dealership's incompetence. If you are an experienced manual transmission driver, don't take any crap from them. Your clutch should work the same way any manual transmission clutch works.
STirocket is offline   Reply With Quote
WTF? Whats wrong with my car? Help please Bruce Wayne North West Impreza Club Forum -- NWIC 14 01-24-2008 09:41 PM
Whats wrong with my car, help! albie1kanobi Proven Power Bragging 48 06-28-2007 05:30 PM
help! find out whats wrong with my car =[ Enriched Mid Atlantic Impreza Club -- MAIC 12 10-14-2006 03:30 PM
What the *beep* is wrong with my car? Help needed! smacksube Normally Aspirated Powertrain 4 08-01-2002 03:00 PM
Can't figure out whats wrong with my car Revision Mid West Subaru Owners Club Forum -- MWSOC 10 05-05-2001 01:41 AM
