Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2025
Old 06-15-2014, 12:51 PM   #1
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Default 2015 WRX auto-x impressions
I took my wrx to an auto-x last weekend and figured I'd share my thoughts since I haven't seen a lot of discussion on 2015's yet.
I see this thread becoming a place where people can talk about which driving techniques these cars reward with good times and what effects modifications to the car itself have.
To keep the discussion meaningful, use data when it's available and accompany subjective reports with relevant info on your background(past experience, previous vehicles, etc.) for context.
Here's my fastest run, which also happened to be the FTD: https://www.youtube.com/watch?v=wE-U0UcLP0s
I have been autocrossing casually since 08 and most of my recent experience is in an auto-x/track day oriented ls1 swapped Miata. The WRX is my daily driver and I don't have big plans for it.
The good:
-Steady state grip is great.
-Transient steering response is good for a decently large sedan.
-The electronic torque vectoring seems to help. I did one run with the system off and then turned it back on. If you're the type who immediately turns off driver aids upon getting into a car, you should at least give this one a chance.
The not necessarily bad but could be improved:
-The car felt a bit soft and floaty in the tighter sections of the course. That's at least in part due to the stock tires. The roll stiffness felt as though it improved as the tires warmed up and the pressure increased. The chalk I applied to the sidewalls after the first run supports this as on subsequent runs it wasn't rubbed away from parts of the sidewall that had obviously contacted the pavement on the first run.
-Turbo lag. It's not very noticeable in normal driving, but becomes very noticeable when you need power to get out of a tight turn. To give you an idea of what I mean, I did a few of runs with times varying by no more than a few tenths. Then on the next run, I started left foot braking to build boost earlier in the turns. Without changing my lines, I dropped an entire second and my left foot braking skills have lots of room for improvement. Simply getting on the gas earlier in a turn doesn't cut it with this car as the onset of power is progressive and caused me to push wide of the apex if I applied the throttle early enough to have power just after the apex.
-Understeer. It'll push a lot if you let it. I found smoothing turns and doing a larger proportion of my braking before turn-in to be very important. Enter a turn too quickly or too abruptly and the car won't yaw.
Basically every fault I've cited is something that an engineer intentionally worked into the car.
-For the tires, they have NVH and ride quality targets to meet. Have different priorities? Get different tires. Wider wheels would firm things up too.
-The lack of torque down low is harder to explain. Probably something to do with fuel economy and smoothness. I suspect that there's a decent bit of room for improvement and that changing the calibration will help.
-The understeer protects average drivers from their own inexperience and the safety guys and legal department are grateful for that. Making the car more neutral could be as simple as changing the alignment settings.
573 is offline   Reply With Quote
Old 06-15-2014, 01:19 PM   #2
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
wow great review.....looking forward to hearing what else you encounter
hekler is offline   Reply With Quote
Old 06-16-2014, 10:01 AM   #3
iLuveKetchup
Member#: 66258
05 STi
Sounds like some kool aid. I think physics & price point has more to do with the short comings.
iLuveKetchup is offline   Reply With Quote
Old 06-16-2014, 03:58 PM   #4
ubersoph
Member#: 130552
I had a similar experience to you in when I autocrossed my WRX. For frame of reference I've been autocrossing for over 8 years now, in a variety of cars from an old MKIII supra to a couple of miatas to most recently (and most of the time) an STX prepped BRZ.
Good:
Nice having power after autocrossing miatae and a BRZ.
Torque vectoring is great - helps me make turns I shouldn't
More grip than expected from stock tires
Steering is tight, easy to control body.
Bad:
It's fat
Brakes feel only okay
Body roll after full on sweepers or during slaloms
Slaloms take a little setup due to size of car
Turbo lag
I think it would do the job if I were in One-Car mode but I'd still rather be in something like a BRZ or Miata.
The car is actually incredibly competent, and still very fun to drive - I imagine in STX trim this car would be fantastic - perhaps the car to have in STX, even more so than the twins? I'd love to see some sibling rivalry - BRZ/FRS vs WRX (vs the bmws and the RX-8 I guess...)
ubersoph is offline   Reply With Quote
Old 08-11-2014, 05:58 PM   #5
Mach V Dan
Member#: 12029
Originally Posted by ubersoph View Post
Turbo lag
Okay, so the OP's other car is an LS-powered Miata. I understand that he might notice some lag from the WRX. But compared to the older-generation WRX/STI cars, this car has NO lag. In the 2015 WRX I see full boost by probably 2500 rpm. That didn't happen in the older cars until 3000 or 3500 RPM. It's really a huge improvement.
Same goes for the suspension. Sure, it understeers a little, but the older chassis was an understeer hippo compared to this. The nose grips pretty well and the turn-in is, to me, vastly better than the GR/GV chassis cars.
--Dan
Mach V
FastWRX.com
Old 08-12-2014, 10:11 AM   #6
epv
Member#: 381966
2015 WRX
--Dan
Mach V
FastWRX.com
He mentioned that he had never done autox before. I'm just assuming that he was on the throttle/too hot into corners. As far as the lag... he's running a CVT, I would guess that his torque converter was ****ting a brick.
epv is offline   Reply With Quote
Old 08-13-2014, 05:03 PM   #7
Mach V Dan
Member#: 12029
I was replying to the Original Poster (OP) and ubersoph. Both of them appear to be experienced autocrossers, and neither of them mentioned CVT. I was NOT replying to stevesnow.
--Dan
Mach V
FastWRX.com
Old 06-16-2014, 04:33 PM   #8
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
They're only shortcomings to a small subset of consumers. To most, they're features. The reality is that most of these cars will never see an auto-x course. Subaru wouldn't be a very good business if they jacked up the price to accommodate parts that are of little value to their broader market or compromised the vehicle too much towards the interests of serious performance enthusiasts.
Old 06-16-2014, 04:42 PM   #9
jhalliman
Member#: 386937
2015 STi
Total noob in experience (first time ever running @ tracks ever), but I ran my '15 STi this weekend at two autocross days. Won novice class on the timed day, placed 27th or 29th (or something) out of 70ish cars overall on PAX, would've finished around 4th I think in Street (non-novice).
Take everything that was said earlier about the WRX and cross off the issues with the slaloms, brakes and floatiness. The suspension/diff/brake changes appear to have a huge impact on the car in stock form and you pay the price for A stock vs D (is '15 WRX still D?) stock. That being said, the car was still plowing all over the place if you were on the throttle anywhere near apex on wider sweeping turns - had to brake HARD in and add throttle at about 15-20% after apex gradually to prevent some serious front end wash. This does not want to drive at all like a rear wheel drive car when pushed near the limit.
I did mess with tire pressure a bunch and found that the best setup I could get on the stock tires was actually 37psi front/35psi rear (hot). It corrected some of the understeery plow and let the tail get a tiny bit happy in slaloms. C-diff auto appeared to also outdo c-diff auto- which surprised me, but I suppose it's rational.
Overall, I got a solid 15 laps in over two days so I had enough time to mess around with the setup. Also, the reviews of the brake vectoring are 100% accurate - definitely noticeable and not intrusive like traction control. Give it a try.
jhalliman is offline   Reply With Quote
Old 06-16-2014, 05:21 PM   #10
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Ive ran my car a bunch in the mountains and have done 2 autox events so far. Completely stock 2015 wrx minus a pitch stop mount right now.
I pulled 1st in novice my first event and 2nd in my second event (street tire with DS index).
Ive only done autox a few times in my 2011 wrx so I can't give any detailed comments.
Im currently building my car for STX, while still being street friendly (8k spring rates). Ill be using the stock wheels/tires for track/autox until they are ate up before I buy a dedicated wheel/tire set-up.
Subie_Noob_Brian is offline   Reply With Quote
Old 06-16-2014, 05:23 PM   #11
Subie_Noob_Brian
Member#: 288037
Video of first event.
***** This is on Conti DW tires which are horrible for autox. The stock tires did much much better in my second event.*****
Old 06-17-2014, 03:18 PM   #12
KC
Member#: 442
25 Mazder CX70
00 S2k
Saw this on another site I frequent...
To me, it appears that it still wallows like the heft that it is.
--kC
KC is offline   Reply With Quote
Old 06-17-2014, 03:30 PM   #13
Subie_Noob_Brian
Member#: 288037
Originally Posted by KC View Post
Saw this on another site I frequent... To me, it appears that it still wallows like the heft that it is. --kC
They are on coils and I'm pretty sure conti DW tires.
Old 06-17-2014, 04:55 PM   #14
tuskenraider
Member#: 65699
15 WRX
WR Blue
--kC
IDK, a sub-3200 lb. car is hardly "hefty" compared to the majority of cars of similar purpose nowadays. And to think I was briefly considering a 2015 Mustang at 3700+ lbs.
It is interesting that those with more platform experience come away with a completely different impression than those new to it......not directed at kC.
My car will be in within 2 weeks and we'll see how things go at Wilmington against Feinberg.
tuskenraider is offline   Reply With Quote
Old 06-17-2014, 04:20 PM   #15
ABQautoxer
Member#: 198231
2007 Not a Subaru
My co-driver who has tons of D Street GR WRX seat time drove one locally (rustyshacklefords's car). He thinks it has less roll, a lot less turbo lag, and overall should easily beat the GR's once shocks are out for it and you get it dialed in. We shall see.
ABQautoxer is offline   Reply With Quote
Old 06-17-2014, 04:46 PM   #16
epv
Member#: 381966
2015 WRX
The real question is can it run close to the Audi TT in DS.
Old 06-17-2014, 04:51 PM   #17
ABQautoxer
Member#: 198231
2007 Not a Subaru
I'd be willing to try if I didn't like Pro Solos so much as I'm going to replace my TT after it is sold with something. The TT is on our watch list naturally as are other cars. We'll see what happens at nationals before that classing discussion gets serious. No need to send us letters either.
Old 06-17-2014, 05:18 PM   #18
rustyshackelford
Member#: 152733
Pretty spot on, also I have noticed it is very heat sensitive and feels to pull power pretty quickly.
rustyshackelford is offline   Reply With Quote
Old 06-17-2014, 05:20 PM   #19
ABQautoxer
Member#: 198231
2007 Not a Subaru
FWIW, you never do the things we did with the GR. Do you even own a bottle sprayer? :P
Old 06-17-2014, 04:58 PM   #20
ABQautoxer
Member#: 198231
2007 Not a Subaru
I was noticing the same thing Wayne.
Tom
Old 06-17-2014, 05:07 PM   #21
tuskenraider
Member#: 65699
15 WRX
WR Blue
Off topic, but why'd ya give up on the TT? Not a good daily? You can PM if you want, just curious.
Old 06-17-2014, 05:14 PM   #22
ABQautoxer
Member#: 198231
2007 Not a Subaru
One personal reason unrelated to the car itself at all, the other being DS is dead at Pros. Watching Jim run all those Pros and Tours against small fields or in bump looked boring so we moved to STX and its always a huge class. I have no regrets there, better to be trophy fodder in a big class. The TT is a neat car and I actually prefer a lot of it over the WRX except utility and potential cost of upkeep. I'm rather surprised they aren't more popular though I know they would never be WRX popular.
Old 06-17-2014, 05:35 PM   #23
epv
Member#: 381966
2015 WRX
Is it pretty obvious when the engine is backing off due to heat? I'm running my WRX for the first time this weekend and have never ran a turbo.
Old 06-17-2014, 05:48 PM   #24
rustyshackelford
Member#: 152733
Yes, it's painfully obvious. Tom I do indeed own a sprayer, it just rarely remembers to come along for the ride to the event haha. We borrowed one and sprayed the crap out of it between runs and it wasn't an issue at all.
Old 06-17-2014, 06:49 PM   #25
Subie_Noob_Brian
Member#: 288037
