Brakes & Suspension Forum sponsored by The Tire Rack |
06-13-2007, 02:12 PM | #26 |
Member#: 34536
Vehicle:2008 Impreza WRX STI Aspen White |
What should someone do if the brake system was flushed with DOT 5 fluid ?
06-13-2007, 02:45 PM | #27 |
Member#: 118082
SCIC
06-22-2007, 07:43 PM | #28 |
Member#: 150248
SCIC
Vehicle:08 FXT Sports WRB |
great info! every time I read a thread on this site, I realise how bad it could be to just go out and buy something. research is key!
----- ButtDyno Obviously you're not a golfer ----- haha! "he peed on your ****ing rug." |
11-21-2007, 04:11 PM | #29 |
Street's closed, pizza boy
Member#: 17301
Vehicle:2018 Focus RS 2006 Evo #17 STU |
Mental note to borrow some stuff from here:
http://www.stealth316.com/2-brakeupgrade.htm |
12-27-2007, 07:10 PM | #30 |
Member#: 167631
I got a 2000 STI wagon V7, the chassis model number is GGBA5EH, I was wondering if I can upgrade my brake kits to brembo or other racing kits? Thanks!
12-27-2007, 07:14 PM | #31 |
Member#: 50167
Vehicle:1996 Subaru STI RA White |
Did you read the FAQ? If you had an STI wagon you should have the Subaru 4-pots. I would stick with those.
01-23-2008, 10:41 AM | #32 |
Member#: 17301
Update: Added "do I need to buy new pads when I buy new rotors / do I need to buy new rotors when I buy new pads" to post #3.
02-23-2008, 11:37 AM | #33 |
Member#: 82148
SCIC
Vehicle:1992 Daihatsu Charade |
Question:
Is it possible to bed in brakes on a dyno or simply have them on a jack/rack and do the process? It is quite difficult for people (especially in southern California) to find a place to bed in brakes properly (without getting busted by a cop). |
02-23-2008, 11:57 AM | #34 |
Member#: 7958
Vehicle:09 GH B+ |
I don't think so. No remote areas where a guy can go- your not talking reckless speeds for most bed ins- most only need to get up to 60ish
02-23-2008, 05:45 PM | #35 | |
Member#: 82148
SCIC
Why isn't it possible to bed in on a dyno? |
02-23-2008, 06:12 PM | #36 |
Member#: 90575
You could put the car on stands off the ground and achieve the same results. It's only heat cycles you're looking at. (I was going to say a jack but I see some problems there...) Just don't over do it as you won't have a ton of air flow. Unless you fan it.
02-28-2008, 03:12 AM | #37 |
Member#: 158498
Vehicle:07 WRX w/ JDM 6spd SWP |
Thanks, great job! Saved me some money sitting and reading all of this.
03-23-2008, 09:42 PM | #38 |
Member#: 17301
Added drum to disc stuff to 4th post. Thanks mechanizedmedic!
03-27-2008, 11:25 AM | #39 |
Member#: 17301
Good StopTech stainless line FAQ here:
http://www.stoptech.com/products/sta...al_lines.shtml |
04-30-2008, 11:06 PM | #40 |
Member#: 17301
07-28-2008, 09:35 AM | #41 |
Member#: 121108
International
Vehicle:2006 06 Spec C OBP |
Ok after reading all this I feel like the title should be "StopTech ..why there the Best" ... Not BBK FAQ.
How about reviewing some Kits? And I would love to hear why STOPTECH would put DNF for AP Racing? ..what the hell is that for? Did the car fail? There is life outside Stoptech. |
07-28-2008, 09:59 AM | #42 |
Member#: 7958
Vehicle:09 GH B+ |
I wouldn't hesitate a second to purchase a Brembo (grand turismo) or AP kit
07-28-2008, 08:53 PM | #43 | |
Member#: 17301
The DNF was for a given team running AP Racing. It doesn't mean anything about ALL AP Racing calipers or that the company sucks. It probably means that the team that chose them just happened to break their car for some reason. Yes there is life outside of Stoptech. I even say "Now - admittedly this is StopTech's website. But StopTech doesn't make any outrageous claims. The stock RSX in that comparison was on Michelin Pilot MXM4's - an all season tire. It did 60-0 in 132 feet. Of the two StopTech shod cars, one was on Hoosiers (very sticky) and one was on Advan A032R's (also very sticky). So you'd expect them to stop noticeably shorter than the stock car on all seasons." The fact is, some cars on race tires with BBK's lost to a stock RSX on stock tires. The implication is, braking faster is not as simple as throwing on the biggest calipers you can find. Someone buying AP's probably knows that, but you never know. |
08-17-2008, 02:41 PM | #44 |
Member#: 121261
TXIC
Vehicle:06 STG 2+ STi CGM |
Anybody have dependable data on the benifits of brake ducts? Something like the RCE kit or similar? Do they really work? List of known benifits? Other options?
08-17-2008, 04:13 PM | #45 | |
Member#: 82148
SCIC
08-17-2008, 06:25 PM | #46 |
Member#: 7958
Vehicle:09 GH B+ |
I wouldn't run track days w/o them personally. No empirical data to provide (wish I had laser pyrometer to document it), but they clearly reduce brake temps.
01-22-2009, 06:05 PM | #47 |
Member#: 17301
Added two new FAQ's
Drilled rotors *must* be good for track use! Porsche/BMW/Lamborghini use them on their cars! But if you cast the holes in place, it should be better than drilling them, right? |
01-22-2009, 06:21 PM | #48 |
Member#: 151079
Vehicle:2005 2.5RS RBP too many friction losses |
I find this hard to believe because when you're on stands, you're only stopping wheels, which weigh what, like 40 pounds a pop with a tire? You're not stopping the car which weighs 3000ish.
04-07-2009, 10:02 PM | #49 |
Member#: 71903
Vehicle:11 Audi A4 6MTQ 13 Mazda CX-5 |
I've been looking for a good how-to on replacing the 4-pot pads and rotors, and the 2 pot rear pads but haven't found it. Anyone got a link?
04-07-2009, 10:08 PM | #50 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
This is a complete 4-pot caliper install but it includes fitting the pads
http://www.scoobymods.com/forums/sub...rake-t349.html |
Similar Threads | ||||
The problem with changeing Big Brake Kit in the front and leaving the stock | ChAi | Brakes, Steering & Suspension | 5 | 03-19-2006 10:34 PM |
Anyone installed the AEB Front O.E. Caliper Big Rotor Brake Upgrade Kit? | WhiteWRoX | Brakes, Steering & Suspension | 2 | 06-02-2002 11:05 PM |
Big Brake Upgrade Kit in the Works | bsquare | Brakes, Steering & Suspension | 50 | 05-20-2001 04:13 PM |
