Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 03-27-2015, 11:59 PM   #1
lesh
Member#: 397058
2004 WRX Wagon
Default Did I FUBAR my ECU?
I have a 2004 WRX Wagon EJ205 (USDM) and I am getting ready to pass it on to a new owner. I am putting it back to stock and was attempting to install a stock rom. I found one on romraider, connected the green connectors and the flash block like I've done many times before. The install went normally or so I thought. Once I installed it, I started the engine and the CEL came on immediately. I looked at the rom again and realized I installed a JDM stock rom instead of a USDM. I thought to myself, you big dummy and tried to re-install the correct one. The problem I am having is ECUFlash will not read the ECU now. I have tried using the USDM and the non-USDM vehicle selections and still get errors. I have looked for the JDM XML file and it is there. Learning view connects and gives me the ECU Information. Romraider Logger will not connect, stating that it needs the XML file. Its there, I've checked multiple times. This is the JDM rom I used: 2004 JDM Subaru Impreza WRX MT/AT A4TE200A 3D0440300. Here are the errors from ECUFlash:
non-USDM
[19:55:10.395] using metadata XML ID read_wrxnonusdm from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrxnonusdm.xml
[19:55:10.410] J2534 API Version: 04.04
[19:55:10.410] J2534 DLL Version: 1.01.4341 Aug 8 2014 00:48:17
[19:55:10.410] Device Firmware Version: 1.15.4340
[19:55:10.410] Device Serial Number: TAr95KIQ
[19:55:14.593] denso02_bootloader_cmd_start
[19:55:15.828] denso02_bootloader_cmd_start
[19:55:17.062] denso02_bootloader_cmd_start
[19:55:18.297] denso02_bootloader_cmd_start
[19:55:19.531] denso02_bootloader_cmd_start
[19:55:19.953] kernel get version
[19:55:20.266] interface close
USDM
Does anyone know what could be wrong? Did I FUBAR it? Could the ECU be locked somehow? If I left out any needed information, let me know and I will try to fill it in.
lesh is offline   Reply With Quote
Old 04-08-2015, 05:38 PM   #2
lesh
Member#: 397058
2004 WRX Wagon
Problem solved with a nused ECU.
Old 04-10-2015, 03:20 PM   #3
mikeyPSF
Member#: 236475
Yep, you definitely want to use a ROM from the same market/year if you're trying to go back to OEM. The original ROM from your vehicle is ideal, but if you don't have that, stick with something in the same market. ROMs have a lot of changes across markets, and in some cases are actually using entirely different ECUs during the same year as the manufacturer will often roll out a new ECU in one market only before rolling it across all markets. RomRaider is definitely the best place to check online. If they don't have something there, feel free to email us at Tactrix (support at tactrix dot com). Happy to help.
-Mike
Tactrix
mikeyPSF is offline   Reply With Quote
