Welcome to the North American Subaru Impreza Owners Club Tuesday June 19, 2018
Old 08-08-2005, 09:56 AM   #1
e_a_olson
Member#: 7034
2005 Nissan Altima
2.5SL - Black
Default CEL P0328 fixed, now pulling P0172
So I replaced the knock sensor and spark plugs because I was pulling a P0328. There was no CEL for about 100 miles after changing the knock sensor, and then on the highway, the CEL came back on. My wife said she noticed a "drumming sound" comming from the rear of the car. I listened for it and hear it as well. Pulled into Autozone and had the code pulled, and it was P0172: Fuel trim malfunction (A/F too rich). I figure the "drumming" sound is the popping of unburnt fuel hitting the cats, right?
What are the best things to check? Plug gap? Secure the plug wires? Secure the vacuum hoses? Clean the air filter (K&N panel filter was cleaned about 3 months ago - 5000 mi)?
e_a_olson is offline   Reply With Quote
Old 08-08-2005, 02:34 PM   #2
abosworth
Member#: 53856
2012 Speed3
Red Mica
If the fuel air mixture is incorrect then i would guess that the O2 sensor is bad. what kind of car is it? or maybe check to see if the fuel pressure is correct.
abosworth is offline   Reply With Quote
Old 08-08-2005, 04:19 PM   #3
e_a_olson
Member#: 7034
2005 Nissan Altima
2.5SL - Black
I cleared the code today, and it has not returned yet. I also no longer hear the unburnt fuel hitting the cats.
Knock sensor cel p0328 occurs only while Auto-Xing xcdhridr Service & Maintenance 9 04-11-2010 08:29 PM
Helping a friend with a 02 WRX CEL p0328 Jkmaynard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-20-2009 08:23 PM
Keep your fingers crossed. CEL - P0328 Hotrodguru Texas Impreza Club Forum -- TXIC 13 06-12-2006 05:04 PM
CEL P0328, knock sensor IWRXIT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-02-2005 03:03 PM
cel p0328 & p1544??? ges311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-29-2003 08:58 AM
