Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-14-2006, 01:15 PM   #1
Hotrodguru
Member#: 37210
2016 Subaru WRX
Default Keep your fingers crossed. CEL - P0328
Well Greg was nice enough to pull this code for me while dropping off the Subie for the graphics. Going to see about replacing knock sensor and see if this resolves my no power, hesitating from like 1k-3k.
Guru
http://forums.nasioc.com/forums/show...ighlight=P0328
Hotrodguru is offline   Reply With Quote
Old 03-14-2006, 01:17 PM   #2
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
I think you can get a generic replacment one. They OEM ones aren't that expenseive anyway.
It should help.
Oh, TITTYWOP for the graphics.
Big_Hitter is offline   Reply With Quote
Old 03-14-2006, 01:58 PM   #3
Hotrodguru
Member#: 37210
2016 Subaru WRX
Car should be done later this week. I left it at Underground and will pick it up sometime this week. I'll take some photos at that time or I'm sure Greg will.
Old 03-14-2006, 02:29 PM   #4
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
we want lots of smoke in the pics!!!
Old 03-14-2006, 04:09 PM   #5
SnowmanFX
Member#: 25753
2015 WRX
Lightning Red
I think TypeC had the same problem and I believe it was his sensor. You may want to shoot him a PM and see what he had wrong.
SnowmanFX is offline   Reply With Quote
Old 03-14-2006, 04:38 PM   #6
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
No, I never had a P0328. I had false knock due to the wrong parameters in the UTEC. I'm still running the original KS.
Going from a quick search, replacing the KS should take care of it. Did you make sure it was plugged in? (sometimes things are obvious)
hth,
-C
TypeC is offline   Reply With Quote
Old 03-14-2006, 04:42 PM   #7
Hotrodguru
Member#: 37210
2016 Subaru WRX
hth,
-C
Well I'm hoping with the motor swap and the rush to get the car to the Statemeet maybe I left it unplugged. I'm just trying to remember where the heck it it. If not mistaken on bottom or top of block or somewhere?
Old 03-14-2006, 04:56 PM   #8
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Lt side of the block, in the rear, next to a thin water pipe, 12mm bolt, I see it in the pic- white connector sticking up next to the hoses in the center....it's easy to leave it unplugged...it's hidden.
_R
RickInLittleElm is offline   Reply With Quote
Old 03-14-2006, 07:37 PM   #9
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
Jay did you have any trouble with that PE timing belt. I am having issue with deciding what belt to get. 2 options are the $204 STI one or the PE one does the PE belt have the marks to line up the cam gears?
txjunglist is offline   Reply With Quote
Old 03-14-2006, 08:39 PM   #10
Hotrodguru
Member#: 37210
2016 Subaru WRX
_R
Thanks Rick, the car is over at Underground getting the graphics done so I'll check it out once I pick the Scooby up. I hope unplugged turns out to be the case or I would still be stoked with it needing to be replaced.
Car is running like a dog right now. Don't think it explains the smokin that started up though on my 3rd run at statemeet. On the freeway I think max boost I'm hitting is like 8lbs or so. Well I have a turbo available locally if its going to need replacing.
The PE belt doesn't have timing marks and wasn't aware the STi one did. I do know I found my PE belt for way less money than any STi belt. The build quality on it is first class.
Old 03-15-2006, 02:22 PM   #11
jefersun
Member#: 37716
2002 ej257 Black WRX
i have an extra knock sensor if you need one
jefersun is offline   Reply With Quote
Old 03-15-2006, 04:49 PM   #12
Hotrodguru
Member#: 37210
2016 Subaru WRX
Whoa...might actually need to take you up on your offer. Nice the way Karma works huh?
Old 03-16-2006, 09:18 PM   #13
Hotrodguru
Member#: 37210
2016 Subaru WRX
Alright, just picked up the car from Lilly's and brought it home. Took off the intercooler and BAM! knock sensor was disconnected. Reset ECU and started vehicle. Haven't driven it but getting ready to head to HHH. Wish me luck again and hope the car runs good.
Guru
EDIT: Alright, nothing like posting and driving. 20 miles so far and almost to Bull and Bear and no CEL. Boost issue is still around, max boost is .05MPa which I think is around 7-8lbs.
Old 06-12-2006, 06:04 PM   #14
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
Guru
hey did you ever get your boost issue sorted out? 7-8 PSI sounds like the vacuum T line on your turbo/wastegate might be reversed. easy fix if so.
adeliciouspizza is offline   Reply With Quote
Keeping my fingers crossed... BlkTS02 Texas Impreza Club Forum -- TXIC 3 02-18-2006 02:30 PM
Cross your fingers for me! please! Black-X Off-Topic 5 04-29-2004 05:44 PM
Cross your fingers... 4x4GGG Off-Topic 18 03-02-2004 10:31 PM
Keep your fingers crossed for me! evil's girl Tri-State Area Forum 16 10-03-2003 01:21 PM
cross your fingers rjrutzky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-19-2003 04:34 PM
