Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 07-03-2008, 10:49 PM   #1
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Default 07 STI Tactrix Cable Pinout
So I was working with Tactrix/Open ECU to get the my 07 STI logging (tried Enginuity as well). They said it will work in Vista I got the driver loaded and ECFlash program recognizes the Tactrix as Open ECU 1.3 Subaru. But I cannot read and log because it will not make a connection to my ECU. I starts then closes loop.
Compared to the pin out on my APV2 ODB2 its different which might be fine. Does anyone have the a pic of their pin out I can look at?
Thanks.
4ST-AIR is offline   Reply With Quote
Old 07-03-2008, 11:19 PM   #2
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Which cobb v2 connector do you have? the one with the red sticker or black?
robbieshonda is offline   Reply With Quote
Old 07-03-2008, 11:25 PM   #3
eminehart
Member#: 11205
2015 WRX
did you run as administrator (in vista)it will not load the drivers correctly unless you do.
eminehart is offline   Reply With Quote
Old 07-04-2008, 12:05 AM   #4
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Drivers are fine looks like the issue is 1.35 is not as consistent as 1.34 XP/Vista version.
Robbie are you referring to the refurb versions? I got one of the first APV2's that came out. My ODB2 is red with black letters.
Old 07-04-2008, 01:07 AM   #5
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Yeah the newer one has a black cobb sticker on it and I belive the pin out is different.
I'll take a photo of all of my connectors tomorrow and post them up if youd like.
I actually tune/ datalog with a serial data to USB cable and a AP V1 cable. I tuned an 07 sti yesterday with it with no issue but that was with cobb not open source.
Old 07-04-2008, 11:03 AM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by 4ST-AIR View Post
... ECFlash program recognizes the Tactrix as Open ECU 1.3 Subaru. But I cannot read and log because it will not make a connection to my ECU. I starts then closes loop.
EcuFlash doesn't do logging yet. In order for it to read your ROM image, the two green test connectors must by joined together before you start. But you will most likely never be able to read your ROM if your tuner locked it using AP or EcuTeK.
Jon [in CT] is offline   Reply With Quote
Old 07-04-2008, 12:20 PM   #7
robbieshonda
Member#: 122306
2002 Sti PTE 6262
^ you can read the basemap but not the realtime map
Old 07-04-2008, 06:55 PM   #8
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Thanks your the first one to actually shed some light on this. I got RomRaider working and its a great program and so easy to use pick your logging variables a window pops up and you set to log using the Defogger (I love that function)
Logs show boost gauge is out of calibration on both my 93 oct and Q16 maps by 4psi. Thanks for the help everyone!
How do I read the RomRaider map now that I logged??? It saved as an XML file, when I got to load a log to look at it it says .hex or .bin ????
Dan
Old 07-05-2008, 11:30 AM   #9
Freon
Member#: 88322
2009 BMW 135i
You can't save maps as an XML file. You might have mistakenly put ".XML" at the end of the file name but it is not an XML file. Rename it to .HEX or .BIN.
Freon is offline   Reply With Quote
Old 07-05-2008, 05:12 PM   #10
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
I moved on to using RomRaider. It saves logs as XML. where ECUFlash saves the ROM as .bin or .hex
I was more interested in logging vs editing.
Dan
I need to borrow Tactrix cable blue m&m Texas Impreza Club Forum -- TXIC 0 06-04-2010 09:17 AM
WTB: STi Tactrix cable. Tirpitz56 Private 'Wanted' Classifieds 0 10-09-2008 04:42 PM
WTB: Need 04-07 Sti Ebrake cables xdrian Private 'Wanted' Classifieds 0 04-01-2008 11:42 AM
New STI Tactrix Cable - $50 cpasti Engine/Power/Exhaust 3 10-14-2007 05:01 PM
07 STi Tactrix Cable, ViperJ Newbies & FAQs 8 03-23-2007 02:53 PM
