Welcome to the North American Subaru Impreza Owners Club Tuesday June 17, 2025
Old 06-25-2007, 05:16 PM   #1
califesaver
Member#: 71234
2002 WRX Stage 2
Peelin Pearl Black
Default AC Compressor replace. Anything to watch out for?
I am replacing my AC compressor and my HI side AC line. Is there anything I should watch out for. I am going to replace the line first to see if there is anything unusual in the line, Is there anything that I need to watch out for in either that should make me stop and take it to Subaru?
califesaver is offline   Reply With Quote
Old 06-25-2007, 05:18 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Well, it's a pain to get the lower bolts off the AC bracket with it still in the car. A wobble will help with that.
Old 06-25-2007, 05:23 PM   #3
Jasper
Member#: 80136
2006 Ford F-150
dont forget to replace the drier!
did the compressor take a crap on you? (if it did, i'd STRONGLY recommend buying the tools to do a complete flush on the system. particles in those lines will tear up a new compressor in no time)
Jasper is offline   Reply With Quote
Old 06-25-2007, 09:31 PM   #4
califesaver
Member#: 71234
2002 WRX Stage 2
Peelin Pearl Black
bumpp
Old 06-25-2007, 09:36 PM   #5
bugeye829
Member#: 81995
2022 FORESTER SPORT
02 WRX 247k RIP
you don't have to replace the drier but make sure you vacuum the system real good before you charge it up.. oh and make sure the compressor has oil in it.
bugeye829 is offline   Reply With Quote
Old 06-26-2007, 09:01 AM   #6
jargon
Member#: 107150
Where are you getting your compressor from? You need to make sure you drain all the oil out of it first by turning it upside down. Sometimes they are shipped with 2-3 ounces in them. If you haven't bought the compressor yet, get one from discountacparts.com. They have pretty good prices.
You don't have to change the dryer, but it is recommended. The filtering funciton of the dryer should not be compromised, but the desiccant properties may be (drying). You can't change the dryer by itself since it is hooked to the condenser. You'll have to get a whole new one (rockauto has good prices for this-~$130 I think). What was the cause of failure of your AC system anyway? You might also consider changing the expansion valve ($100 from stealership), but again, not completely necessary.
What I would recommend is to do the install yourself and take it somewhere (again, no reason to take it to the subaru stealership for this) and get it flushed. They will also add oil to the compressor. Just make sure the compressor isn't hooked up to engage!
jargon is offline   Reply With Quote
Old 06-26-2007, 11:23 AM   #7
wrxwhite
Member#: 28632
2011 Legacy 3.6R
Dark grey metallic
Why are you replacing the compressor? If the compressor exploded; the entire system will need to be flushed to get all the metal out. There are kits available to install a screen on the low side inlet to catch all the particles. Most manufacturers will not warranty a replacement compressor if metal particles are found in it.
wrxwhite is offline   Reply With Quote
Old 06-26-2007, 01:38 PM   #8
jargon
Member#: 107150
I've flushed many AC systems and have yet to discover one that did not contain metal particles.
Old 06-26-2007, 01:48 PM   #9
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
one odd tidbit I can throw in is to be careful not to whack the #2 TGV sensor while you're working around there... I had a compressor replaced under warranty and it came back showing a P1086... they are not too robust apparently
UkNuck is offline   Reply With Quote
Old 06-26-2007, 08:56 PM   #10
califesaver
Member#: 71234
2002 WRX Stage 2
Peelin Pearl Black
I am replacing the compressor becuase the clutch seizes up when I am trying to run it. I had a leak in my Hi side line so I am figuring that it went too long with no fluid in the lines and it seized. Now even if I turn on the fan with the AC button not on it will back load on the engine, which I am figuring from the clutch seizing.
Old 06-27-2007, 09:58 AM   #11
jargon
Member#: 107150
In that case, don't bother putting another compressor on unless you plan to flush the system . Take it to a local shop with all (some) of the lines disconnected (after you install the parts, of course) and get them to flush and charge it for you.
Old 06-27-2007, 04:46 PM   #12
califesaver
Member#: 71234
2002 WRX Stage 2
Peelin Pearl Black
I looked at the condensor from rock auto. In talking to them they found out from the manufacturer that the part is the condensor only. It does not come with the dryer. I am going to hope that that part is ok and will take in the new compressor to the shop and get them to flush it and get it working. Hopefully the condensor/dryer is still in good condition.
Old 06-27-2007, 05:26 PM   #13
Parkay090
Member#: 20880
2003 WRX Sedan
MBP
Question
Not meaning to hijack, but I'm in a similar boat with AC Compressor troubles. The clutch on my compressor is slipping when compressor initially engages and it makes a god awful squeal during this time.
I have a replacement compressor, but I'd like to find a "how to" or a schematic of the Subaru HVAC system before I tear into it.
Any thoughts?
Thanks
Parkay090 is offline   Reply With Quote
Old 06-27-2007, 07:25 PM   #14
califesaver
Member#: 71234
2002 WRX Stage 2
Peelin Pearl Black
Well if your just replacing the compressor you probably only need to vaccum out the line. Then replace the compressor. You should probably get the system flushed for good measure. Make sure there is oil in the compressor. Recharge. Chill in your glory.
Old 06-28-2007, 12:26 AM   #15
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
wheres the drier located? any pics? just curious because i dont think i've seen it when i last replaced my compressor. Im having the same symptoms as parkay and recently replaced the ac tensioner pulley
fastnoypi is offline   Reply With Quote
Old 06-28-2007, 10:41 AM   #16
califesaver
Member#: 71234
2002 WRX Stage 2
Peelin Pearl Black
the dryer is located with the condensor
Old 08-06-2007, 08:08 PM   #17
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
Has anyone tackled this job yet? Same problem here, seized compressor, bad squeal and burnt rubber smell when AC is on. I can't locate the expansion valve, but I just ordered the dryer ($40 w/o the condenser) from discountacparts.com so I would assume it can be replaced alone...
Psipwrd is offline   Reply With Quote
What to watch out for when copying other maps for similar set ups? plus plus plus Engine Management & Tuning 4 02-17-2006 06:06 PM
STi on a car carrier. Anything to watch out for? Hollidark General Community 2 06-29-2004 10:24 PM
Anything to watch out for going to Vegas? karazyman Southern California Impreza Club Forum -- SCIC 26 05-08-2004 02:12 AM
Driving car out of USA...anything to look out for? balajc Off-Topic 10 12-22-2003 11:55 AM
replacing brake lines on wrx, anything i need to watch out for? wrxracer55 Brakes, Steering & Suspension 8 11-02-2003 10:00 AM
