Welcome to the North American Subaru Impreza Owners Club Saturday September 7, 2024
Old 08-18-2005, 10:43 AM   #1
XaznPKdogX
Member#: 43568
Default 06 WRX: Semi-closed or Open Block?
Most of the people here believe the new WRX has a semi-closed block like the Legacy GT and STI but does anyone know for sure? I mean really, the truth?
From cars101:
2.5L boxer DOHC, 4 cylinder, 16 valves
Active Valve System
Turbocharged
Hood scoop air intake with Intercooler
Block and heads, Aluminum alloy. open deck design, with
cast iron cylinder liners
Sequential multi-port fuel injection
Bore: 99.5x79mm, 3.92x3.11
Redline 7000 rpm
Since the 06 are being sold or will be soon, I was hoping some of you may have real answers.
XaznPKdogX is offline   Reply With Quote
Old 08-18-2005, 11:03 AM   #2
Lachlan
Member#: 19470
1981 Brat GL
I have no authority here, but from some of the reading I've done I infer that "open" is sometimes used as an overarching term for semi-closed and open--i.e. if it's not (fully) closed, it's "open." If someone could confirm or deny I'd appreciate it.
Lachlan is offline   Reply With Quote
Old 08-18-2005, 11:57 AM   #3
flyinpig
Member#: 43640
2015 Levorg sedan
SOA's WRX spec sheet, http://vocuspr.vocus.com/VocusPR30/T...WRX_Specs2.pdf says "semi-closed deck cylinder block design".
flyinpig is offline   Reply With Quote
Old 08-18-2005, 12:14 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
They aren't going to use one block for the LGT, FXT, and STI, and then use a different one for the WRX... It's a semi-closed block.
dwx is offline   Reply With Quote
Old 08-18-2005, 01:55 PM   #5
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
The part number for the complete shortblock is different than the others, however, the part number for the cylinder block is the same (11008AA930) so it has to be a semi-closed deck design.
I am currently looking into the other part numbers to see what else changed to warrant the shorblock having a different part number.
Templar is offline   Reply With Quote
Old 08-18-2005, 02:19 PM   #6
Templar
Member#: 483
2010 RSV4
The pistons for the 06 WRX AND 06 Forester XT are a different part number than the 04-05 Forester XT, 04-06 STI, and 05-06 Legacy GTs and XTs.
The piston part number for the STIs, 04-05 Foresters, and all the 05 and up Turbo Legacys is 12006AC390.
The part number for the 06 WRX and 06 Forester is 12006AD210.
List price on either piston is $85.42
Other than that, the crank, rods and cylinder block are the same between all the turbo 2.5 models.
Old 08-18-2005, 02:29 PM   #7
187
Member#: 51427
How much cheaper are they than sti blocks?
187 is offline   Reply With Quote
Old 08-18-2005, 02:46 PM   #8
Templar
Member#: 483
2010 RSV4
List price on the STI block (10103AB440) is $1812.53
List price on the WRX block (10103AB630) is $1759.74 which is the same price the STI block was until July 1.
Most dealerships on NASIOC will sell them for quite a bit less than list...mine included.
Old 08-18-2005, 03:27 PM   #9
Jon [in CT]
Member#: 2992
02 WRX Sedan
Maybe the change in pistons (relative to the 2005 2.5L turbo engines) might account for some of the increase in compression ratio (now 8.4:1 was 8.2:1).
Jon [in CT] is offline   Reply With Quote
Old 08-18-2005, 03:43 PM   #10
187
Member#: 51427
so its like 50 dollars for hypereuretic lol pistons? I was hoping for a bigger saving.
Old 08-18-2005, 04:35 PM   #11
Templar
Member#: 483
2010 RSV4
My guess is the pistons are still Hypereutectic, but have a different dish design. As John [inCT] mentioned, the compression ration is different on the 06 Forester.
Old 08-18-2005, 04:44 PM   #12
WoohooRX
Member#: 70296
04 WRX
rally blue
does that mean the new wrx's have the same engine (almost) as the sti's, just detuned?
WoohooRX is offline   Reply With Quote
Old 08-18-2005, 05:34 PM   #13
Jon [in CT]
Member#: 2992
02 WRX Sedan
No, it means the new WRX has different pistons and different cylinder heads and different turbo and different intake manifold and different intercooler, etc.
Old 08-18-2005, 06:24 PM   #14
Fuzz541
Member#: 4739
This n00b gathers that you're talking complete shortblock pricing, right?
Fuzz541 is offline   Reply With Quote
Old 08-18-2005, 07:43 PM   #15
Templar
Member#: 483
2010 RSV4
Correct, that pricing is for a complete shortblock, which is the cylinder block, crankshaft, connecting rods, pistons and all the necessary, bearings, rings, bolts, and clips.
Old 08-18-2005, 07:51 PM   #16
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed (sold)
So is an 06+ WRX swap into an older Subaru gonna be just as complicated as an STi swap now - AVCS, drive by wire, immobilizer, etc?
ss
subysouth is offline   Reply With Quote
Old 08-18-2005, 09:19 PM   #17
Templar
Member#: 483
2010 RSV4
ss
Oh Yeah. Possibly more so if the secondary air pump is required and can't be bypassed easily.
Old 08-19-2005, 01:03 AM   #18
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed (sold)
That sucks but thanks for the info.
ss
Old 08-19-2005, 11:13 PM   #19
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
The only Open deck Subaru engines are the SOHC NA engines, right? The EJ251/2/3 are all Open, but the DOHC EJ22 is semi closed... Makes sense to me.
Chi_San is offline   Reply With Quote
Old 08-20-2005, 12:43 AM   #20
slvrwrx04
Member#: 58058
2014 STI Sedan
I thought the EJ22 blocks on the turbo legacy and the 22b were closed deck blocks...and don't forget that the old EJ205 block was also an open-deck design.
slvrwrx04 is offline   Reply With Quote
Old 08-20-2005, 02:25 AM   #21
Chi_San
Member#: 53558
2005 Baja Turbo
I'm not sure about the 22b, but the EJ22T is semi-closed deck.
Old 08-20-2005, 03:21 AM   #22
slvrwrx04
Member#: 58058
2014 STI Sedan
After some researching, the EJ22T is a closed deck block.
http://forums.nasioc.com/forums/show...2t+closed+deck
Kissing: Eyes closed or open? banman Off-Topic 19 11-29-2006 03:30 PM
Unused credit cards: Closed or open? Strider Off-Topic 21 07-31-2006 04:46 PM
Closed or Open? sixpack subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-20-2005 07:13 AM
Pics needed please: closed deck, semi-closed and open deck Impreza01 Off-Topic 16 09-08-2004 11:32 AM
Semi\Closed Deck STi block? hyp36rmax Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-06-2004 08:08 PM
