04-30-2006, 05:52 PM | #26 |
Member#: 22928
NESIC
Vehicle:2015 Legacy Limited Lapis Blue |
Here is what a BD sedan looks like with 02/03 WRX sedan suspension if anyone is interested
[IMG]http://i15.photobucket.com/albums/a389/rallyGC8/Car***37;2012%20-%201998%20Subaru%20Legacy%20GT%20FAT%20STGII/wrx_susp1.jpg[/IMG]
05-09-2006, 03:29 AM | #27 |
Member#: 99848
BAIC
Vehicle:2021 Ascent Magnetite Gray Metallic |
you think the same concept applies w/ the 05 BL's to work w/ the 05/06 wrx's?
05-09-2006, 05:06 AM | #28 |
Member#: 71875
no. 00+ Legacies have a multi link rear suspension. The difference between 04 and 05/06 sti suspension is that the front knuckles are beefed up so the flanges on the strut are farther apart, as are the holes in the flanges. Which I just noticed is right at the bottom of my post. R->C->P
04-06 non-sti impreza suspension all has the same fitment. MYfirst00- what is your alignment like? Also, does anyone have 02+ wagon suspension on a Legacy? Last edited by jamal; 05-09-2006 at 06:55 AM. |
05-09-2006, 07:33 AM | #29 | |
Member#: 22928
NESIC
06-20-2006, 05:54 PM | #30 |
Member#: 103245
SCIC
Vehicle:1967 912 STi Spec C Ivory White |
So if i put a sedan 02 wrx suspension on my BG... would i have some camber issues or just a problem with the springs not being correct?... assuming i put in the whole assembly from the wrx.
06-20-2006, 07:54 PM | #31 |
Member#: 37375
NESIC
Vehicle:2002 WRX Silver |
OK, I just purchased a 97 Legacy GT...what chassis do I have?? I see too many BD, BG, BE, B4....can anyone name mine please??
Thanks (Legacy Noob) |
06-20-2006, 08:14 PM | #32 |
Member#: 103245
SCIC
http://forums.nasioc.com/forums/showthread.php?t=973119
please read this first.. its posted at the top of the legacy forum. |
06-20-2006, 08:25 PM | #33 |
Member#: 37375
NESIC
Thanks for being so gentle
I was googling it and found something saying the chassis was a B11, but I guess it is a BD. Helps with ordering things! |
06-20-2006, 10:17 PM | #34 |
Member#: 103245
SCIC
Has any wagon owners used a sedan wrx suspension? had any problems or concerns/issues? thanks.
mike |
06-20-2006, 10:21 PM | #35 |
Member#: 65823
NWIC
Vehicle:2018 Impreza Sport Pearl White |
dont do it. You will have the "saggy" butt. wagon goes on wagon sedan on sedan. the rear spring rates are different, as well as the struts. trust me, this was my 1st setup. and i dumped it fast.
06-20-2006, 10:25 PM | #36 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
Well, the question then is...will +05 legacy suspensions fit 00-04 BE/BH legacies? They seem to have a wider range of aftermarket support, particularly coilovers...
06-21-2006, 12:10 AM | #37 | |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
Nope. The 05+ uses a larger strut mount than all previous years. |
07-14-2006, 02:11 AM | #38 |
Member#: 16087
South East
Vehicle:02 WRSTi World Rally Wooooo |
This is great help! Cheers to you guys!
09-06-2006, 11:08 PM | #39 |
Member#: 125150
Vehicle:1996 legacy & 03 R1 white |
ok soooooo my question would be if i wanted to put a full body coil over on a 92 legacy could i just use an application for the 04 imprezza?????
09-07-2006, 01:40 AM | #40 |
Member#: 65823
NWIC
93-01 impreza stuff will bolt up as long as you swap the front upper perches. if you wanna use anything 02+ you will need to use the stock tophats+perches for the rear.
i just put a full 01 2.5rs suspension on my 92 legacy L, it dropped it 1: f/r and i needed the front impreza spring perches but everything else bolted up fine. |
11-23-2006, 11:50 AM | #41 |
Member#: 105290
South East
Vehicle:97 Legacy GT Wagon Silver |
ok, so I have a 97 LGT Wagon, so to swap to WRX stuff, I need to find a WRX WAGON (02-03) and grab the shocks/springs. then, use the tops from MY 97 BG on the WRX parts? I saw an article a while back that shows that you can drill out the mounting holes in the chassis to angle the suspension correctly to get rid of the Camber issues...
But it was for a 93 legacy with 04 STI suspension.. Is any of that applicable to my 97? (ive only had the car a few days now... so im not very familiar with the suspension yet) http://www-scf.usc.edu/~leclaire/car...suspension.htm |
11-23-2006, 11:56 AM | #42 | |
Member#: 65823
NWIC
you got it. and save yourself the hassles and just get some camber bolts for the rear. but if you can i'd try and find some BG springs but the wrx is a cheap and fairly easy route... just not the best. -ben |
11-23-2006, 06:53 PM | #43 |
Member#: 105290
South East
on the same car, what if I just buy aftermarket WRX Wagon suspension? Still works with my tops?
11-23-2006, 10:10 PM | #44 |
Member#: 115154
04-02-2007, 01:20 PM | #45 |
Member#: 35276
RMIC
im so confused after reading all of this. but from what i gather its not quite as simple as just use wrx springs and that wrx top hats and struts are a must???
04-02-2007, 01:24 PM | #46 |
Member#: 22928
NESIC
As long as the Legacy tophats are used with the legacy springs, or the wrx tophats are used with the wrx springs, any strut can be used from either model.
04-02-2007, 03:16 PM | #47 |
Member#: 38629
NWIC
Vehicle:1999 Legacy GT (STI) White |
Armed with this information, I'm wondering if anyone has tried '03 JDM STI springs on a BD/BG?
04-02-2007, 03:19 PM | #48 |
Member#: 22928
NESIC
That would be the same as trying an 04' USDM STI style setup, wouldn't it?
04-02-2007, 03:30 PM | #49 | |
Member#: 71875
04-02-2007, 03:53 PM | #50 |
Member#: 128309
how big of a drop is it from LGT sedan suspention to WRX?
WRX Suspension Swap onto BD Legacy Ride Height Issue | RallyLegacy | Legacy Forum | 12 | 04-03-2012 03:03 PM |
Suspension options for '02 WRX suspension-swapped BD | mattwalters | Brakes, Steering & Suspension | 10 | 12-06-2007 12:32 PM |
Three-Way Suspension swap question, menage a toi if you will | mattminer | Brakes, Steering & Suspension | 8 | 11-28-2006 11:33 AM |
FXT To STi Suspension Swap Questions | SoyRacer | Forester Forum | 12 | 06-30-2004 07:30 PM |
STI vs WRX suspension Question | IJust8Chris | Brakes, Steering & Suspension | 26 | 09-06-2003 09:34 PM |
