Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 01-18-2003, 10:04 PM   #1
jatyrx
Member#: 23382
2003 ej207
Unhappy CEL installed HELIX dp
hey ,
i just installed a Helix downpipe. and the only modifcations are a hks BOV and a helix. and i got a CEL just today. just wondeirng what happen. when i bought the helix i got mil elminator from gruppe-s. i installed it perfectly with butt connectors. and for soem reason i got a cel? does anyoen knwo what happen????
thanks
any fixes would help alot?
-jayson
jatyrx is offline   Reply With Quote
Old 01-18-2003, 10:07 PM   #2
darkstar1122
Member#: 28860
02 wrx
black
hows the down pipe working ? does it fit properly ?
darkstar1122 is offline   Reply With Quote
Old 01-18-2003, 10:07 PM   #3
teiva-boy
Member#: 22825
Although it's pretty obvious, you can't blame the DP just yet. You need to have the code pulled. I installed a header and got a TGV CEL.
teiva-boy is offline   Reply With Quote
Old 01-18-2003, 11:00 PM   #4
jatyrx
Member#: 23382
2003 ej207
downpipe works well. i can really hear the fluttering. ok i will check on the code thanks
-jays9on
Old 01-19-2003, 01:07 AM   #5
iloveturbos
Member#: 22868
MBP
hows the butt connectors working? soldering isnt my friend.
iloveturbos is offline   Reply With Quote
Old 01-19-2003, 09:23 AM   #6
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
Teiva-boy's right, the CEL could be something else. Go to Autozone or somewhere, have it pulled, and find out what it is.
I have the same downpipe and I decided to solder the connections together instead of using connecters and I have yet to receive a CEL.
By the way, how did everything fit?
02R6 is offline   Reply With Quote
Old 01-20-2003, 05:45 PM   #7
jatyrx
Member#: 23382
2003 ej207
well from the downpipe to the midpipe it fit well but, the brackets didnt aligned. so i'm trying to figure how to support it? and ideas?
-jayson
Old 01-20-2003, 09:23 PM   #8
protocol_droid
Member#: 13219
01 Audi S4 Stg 3
Nogaro Blue
What do you mean from the DP to the midpipe. THe Helix dp eliminates the midpipe altogether?
As fitment is concerned, do you have the first generation Helix that gruppe-s sold? I guess there was some type of fitment issue which was resolved more recently...don't recall if it was a bracket fitment or turbo flange fitment?
protocol_droid is offline   Reply With Quote
Old 01-21-2003, 09:15 AM   #9
02R6
Member#: 22157
'02 WRX '04 350Z
I have the first gen dp and my fitment was also terrible. I just enlarged the hole in the bracket on the dp nearest the turbo. And I ended up taking off the bracket (that is attached to the car) nearest to where the cat back meets up with the whole system.
Now the rearmost bracket on the dp (that should have been attached to that bracket that I took off the car) rubs a little on chassis when I go over bumps. Nothing a little grinding with a Dremel can't fix though.
If only I had a Dremel.
Old 01-21-2003, 09:48 AM   #10
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Hey guys just wanted to say I just got the helix and the fit was great. Nice DP and with a free CEL EMIL.
Eric
WRBLUEWAGON is offline   Reply With Quote
Installed Helix DP with audio clip The Chef General Community 1 05-04-2006 12:56 PM
Will COBB AP fix the CEL with HELIX DP? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-02-2006 11:07 PM
installed HELIX DP and is this NORMAL!? nuhga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-09-2005 09:15 PM
For those who installed Helix DP by yourself silvscorp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-18-2004 01:09 AM
Installed Helix DP, but no extra boost. scoobystas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-24-2003 04:49 PM
