10-28-2006, 07:51 AM | #1 |
Member#: 103373
Low RPM Low Load Issue
Guys I've got a strange problem that start a couple of days ago. So it could be mechanical.
Taken -12% from the MAF table due to running a Fuel Pressure Reg to get as close to the AFR Maps as possible. Also the car has run minus MAF setup for 2 months with no known issues. The car has developed a stutter/surging condition at below 2000rpm and idle is rough. Looking at the logs the diagnoses looks as... 1. Idle is rough and evident from log 1 AF Correction adding fuel, then suddenly settles down to normal - see log 1. 2. Cruising below 2000rpm the car will stutter/surge sometimes violently. Again AF Correction is adding then substracting fuel frequently - see log 2 *** How do you post at NASIOC? Logs are too long to wrap around code! *** What mechanical problems should I be looking at? Spark Plugs etc? Now above 2000rpm the car hauls and runs normal with no CEL's etc. Strange? |
11-01-2006, 12:52 PM | #2 |
Member#: 48219
Vehicle:. Always drive the race line . |
you're tuning in a weird way. Increase the injector scalar instead of removing 12% from the MAF table. The car thinks you're in a lower load zone then you really are causing you to run higher timing than you should. That's the first of your problems.
I know that wasn't much help to your current problem but check for intake leaks. |
Similar Threads | ||||
Knock at low RPMs and load | fenix-silver | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 05-17-2010 12:51 PM |
Low RPM/low boost knocking? | Fred Fredburger | UTEC | 8 | 11-22-2007 10:59 AM |
Flash CELs at low rpm & load? | Si2WRX | Engine Management & Tuning | 8 | 04-04-2004 06:29 PM |
Flashing CEL at mid-low RPMS / low Throttle - then gone | johnnytran | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 06-06-2003 03:45 AM |
Detonation during low RPM/High load | crash | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 03-11-2002 11:33 PM |
