01-18-2008, 01:04 PM | #1 |
Member#: 127704
TXIC
Vehicle:2015 Boosted Stang MAP tuned |
Injector scaling - top level fuel control
should have put these current questions in to one post but Im generating new ones daily
With regard to injector scaling.. E.g. stock 550 sti injectors. Currently scaled at 525 cc for arguments sake, I go logging and see I would liek to lean or richen things up across the board prior to fine tuning etc. Would a decrease in scaling generally increase the amount of fuel injected globally? and vice versa... Apologies if a rather obvious post |
01-18-2008, 01:16 PM | #2 | |
Member#: 10108
NWIC
Vehicle:1874 Bicycle |
01-18-2008, 01:19 PM | #3 |
Member#: 47145
MWSOC
Vehicle:2012 Gas Saver |
lower scalar = richer
higher scalar = leaner Do not make the mistake of many & assume the Injector scalar is absolute; assuming that 550cc/min = 550cc/min injector scalar. ALWAYS start with a smaller value than what they are rated at. I recommend starting at ~85% of rated flow, which would be 468 with a 550cc/min flow rated injector. |
01-18-2008, 01:38 PM | #4 |
Member#: 127704
TXIC
Thanks guys - needed confirmation - got it thanks - this must be the easiest forum area on NASIOC to get straight answers.
Similar Threads | ||||
RC 1000cc Top Feed Injectors, Apex-i AVCR Boost Controller *BALLLLLLLLLIN* | dan avoN7 | Engine/Power/Exhaust | 10 | 01-06-2010 12:19 AM |
help with fuel trims / injector scaling.. logs inside | AaronWRX | UTEC | 15 | 09-20-2007 09:37 PM |
STI WRX ultimate racing side feed to top feed fuel injectors & rails kit 785cc | Ricowrx | Private 'For Sale' Classifieds | 8 | 11-28-2004 05:52 PM |
Ultimate Racing top feed fuel rail injector problems? | Ricowrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 10-07-2004 04:59 PM |
Ultimate Racing Fuel injectors w/ top feed rail kit for STI | Ricowrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 22 | 09-15-2004 09:16 AM |
