Welcome to the North American Subaru Impreza Owners Club Thursday November 15, 2018
Old 06-17-2002, 05:57 PM   #1
ILUVMY2.5RS
Member#: 7890
1999 Impreza 2.5RS
Default looking to upgrading my suspension on my 99 RS...
i want to lower it and have better handlin anyone know where i should start? and anyone know any good performance springs and do i need to upgrade the shocks if i change the springs?
thanx
ILUVMY2.5RS is offline   Reply With Quote
Old 06-17-2002, 09:46 PM   #2
T-WRX450
Member#: 18105
1995 95/99 Cst Wagon
93 Turbo Sedan
ILUVMY2.5RS,
I would recommend going with a larger FHI 20mm rear sway bar or going to a 22mm MRT or Cusco rear bar and a set of MRT, Eibach or STi springs all of them lower it about an inch or less and each have different spring rates (I have listed them hardest to softest) With these drops you don't need to change your struts, unless they are bad or leaking... or you are ready for the Version 6 inverted struts.
Troy
T-WRX450 is offline   Reply With Quote
Old 06-18-2002, 08:53 AM   #3
GQ
Member#: 4830
15 Alfa Romeo 4C
Rosso Competizione
I have KYB/AGX's with MRT Springs, and an 18mm sway bar. Also don't forget to put some good tires on. These parts are useless without good grip. I believe Tire Rack still has the Yok AVS Intermediates for $58.00 each. I pull .98 g's(G-tech) on this setup...GQ
GQ is offline   Reply With Quote
Looking to upgrade the turbo on my stock 05 wrx GRIPNGOWRX Built Motor Discussion 7 02-03-2009 11:06 PM
Looking to upgrade the sound on my Forester XT 03MBP Car Audio, Video & Security 2 03-02-2008 01:45 AM
lookin to change up my suspension on my 07 impreza Hedbergsuby07 Brakes, Steering & Suspension 4 01-11-2008 12:27 PM
Thinking about upgrading the suspension on my 05 STi black05STIguy Brakes, Steering & Suspension 5 06-24-2006 11:45 PM
I am looking to upgrade the turbo on my car... advise. WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-16-2004 07:20 AM
