Tire & Wheel Forum sponsored by The Tire Rack |
06-06-2013, 10:53 AM | #2551 | |
Member#: 316364
Vehicle:2012 WRX |
06-06-2013, 11:27 AM | #2552 |
Member#: 295724
Vehicle:2022 WRX WRB |
Remember the 2010 is still the narrow body. Fit would be fine on the 2011 probably but may need a roll or pull on the 2010. If I recall the stock wheel on the 2010 was a 17x7.
06-06-2013, 12:52 PM | #2553 |
Member#: 316364
Vehicle:2012 WRX |
06-07-2013, 12:21 AM | #2554 | |
Member#: 97904
Vehicle:2002 WRX World Rally Blue |
06-08-2013, 12:27 PM | #2555 |
Member#: 353711
International
Vehicle:2002 WRX Wagon Silver |
year: 2002
model: WRX Wagon wheel model: Rota G-Force wheel size/offset:18X8.5 ET48 tire brand/model: Talon's tire size: 225X40R18 suspension: stock alignment: stock fender mods:none spacers: rear 3mm The rear with an ET48 and 8.5's was a little to close for me (close to the strut). But with the 3mm spacers no probs at all. Next is coilovers to drop front 1.5 and rear approx .5 inch. Last edited by kracky; 06-08-2013 at 07:49 PM. |
06-08-2013, 12:36 PM | #2556 |
Member#: 237565
Vehicle:I haz 06 WRB Wagon |
I ran the same size wheel with a 235/35 tire on my wagon dropped pretty low on coilovers. I had the rear fenders rolled and was running -1.75* of camber up front and natural (~-2*) in the rear. The 235/35 is a little shorter than the 225/40, but you shouldn't have to do a whole lot of work.
06-08-2013, 07:30 PM | #2557 | |
Member#: 353711
International
Front
06-08-2013, 08:04 PM | #2558 | |
Member#: 353711
International
06-08-2013, 11:11 PM | #2559 |
Member#: 237565
06-08-2013, 11:26 PM | #2560 |
Member#: 322188
Vehicle:05 STi/06 FXT CGM/RBP |
year: 05
model: sti wheel model: enkei pf01 wheel size/offset: 17x9 +48 tire brand/model: re-11s tire size: 255/40 if possible suspension: feals 441 (hopefully soon) alignment: camber -1.6 front -1.8 rear ( camber bolts) fender mods: none currently spacers: no Wanting to run these without fender modifications if possibly... Unsure on the 255 tire size being feasible? Saw this thread http://forums.nasioc.com/forums/show....php?t=2201790 post #23 shows 245s didn't know if anyone has tried 255. Wanting to run the feals at most optimum handling height which I believe is 13.9 inches from the hub center. Please advise and/or correct if i am wrong.Thanks. I have read the first 78 pages of this thread and a few others. Hoping someone can just chime in if its been done. Last edited by Blingstrom; 06-08-2013 at 11:29 PM. Reason: have done some research |
06-08-2013, 11:30 PM | #2561 |
Member#: 310366
South East
Vehicle:03 Widebody Wagon |
The problem will likely not be fender rubbing as much as inner wheel well rubbing. That's a pretty high offset. But with the right height, which the 13.9 is a good height, you shouldn't need any fender mods depending on how tight your suspension is and how hard you drive.
But a good flattening of the inner lip (roll) will guarantee you will not rub the fender |
06-08-2013, 11:57 PM | #2562 |
Member#: 322188
Thanks for the reply. That was kinda my thoughts too. I enjoy turning fast and hope to do some autox stuff in the near future after I get everything sorted. Trying to stick with a close to a stock offset but a wider tire for more grip.
06-11-2013, 01:56 AM | #2563 |
Member#: 356590
BAIC
Vehicle:2002 WRX Wagon WRB |
Wondering how much tire I can fit on these on a wagon
year: 2002 model: WRX Wagon wheel model: Drag DR-31 wheel size/offset: 17x9 +38 tire brand/model: ??? tire size: I'd like to fit as much meat as possible, I've seen 245s on a 17x9 +42, but the car seemed a little high suspension: Bilstein PSS9 with Cusco Pillowball Mounts all around alignment: Whatever I need, but within reason fender mods: " " spacers: yes/no? no |
06-11-2013, 02:42 PM | #2564 |
Member#: 321572
Vehicle:2001 Impreza Buyeye Dark Blue |
Anyone with a +20 on a Impreza? any GD model
06-11-2013, 02:48 PM | #2565 |
Member#: 310366
South East
06-11-2013, 04:49 PM | #2566 |
Member#: 293176
Vehicle:2005 STi |
Year: 2005
Model: STi Suspension: Complete STOCK Rims in question: Enkei RPF1 17x8 5x114.3 +45 Tires: Goodyear Eagle GT All Season Tires 245/45R17 Questions: Will these fit and clear Brembos? Will these rub on my fender lining? Thanks in advance. |
06-11-2013, 04:52 PM | #2567 | |
Member#: 310366
South East
06-11-2013, 05:03 PM | #2568 |
Member#: 293176
Vehicle:2005 STi |
06-11-2013, 05:05 PM | #2569 |
Member#: 310366
South East
06-11-2013, 08:29 PM | #2570 | |
Member#: 321572
IMG_9120 by FrostyApe year: 2001 model: Impreza TS wheel model: Rota G-Force wheel size/offset:18X9 ET35 tire brand/model: XXX tire size: 235X40R18 suspension: BC racing Coilovers alignment: -3 camber F&R fender mods: rolled spacers: XXX |
06-11-2013, 08:38 PM | #2571 |
Member#: 293176
Vehicle:2005 STi |
Can anyone else chime in on this?
06-11-2013, 09:02 PM | #2572 |
Member#: 310366
South East
I can confirm they will clear brembos with no spacer
Pulled from the enkei wheel thread "Wheels are RPF1 Black 17x8 45mm offset - fit perfect no issues clearing Brembos, however the wheels were roadforce balanced and the new thick weights they use were too tall and 1 got knocked right off immediately by the caliper up front. That wheel only had 1 weight on it, so I'm not real concerned." With a little research you can find anything EDIT: he is also running a 245/45 |
06-11-2013, 09:43 PM | #2573 | |
Member#: 293176
Vehicle:2005 STi |
Thanks you very much, much appreciated.
06-11-2013, 10:03 PM | #2574 |
Member#: 310366
South East
06-12-2013, 02:37 PM | #2575 |
Member#: 332386
NWIC
Vehicle:2005 WRX Limited Obsidian Black Pearl |
year: 2005
model: WRX Sedan wheel model: Rota SVN wheel size/offset: 18x8.5 +48 tire brand/model: None purchased yet (open to any options) tire size: 245/40/18 (I don't have tires yet, but was thinking this size) suspension: Stock alignment: Stock (would prefer no camber) fender mods: None (would prefer not to roll/pull) spacers: None Will these wheels fit my car with thiis tire size, without rolling/pulling fenders or adjusting camber? I read through nearly the entire thread and have gotten mixed messages. If this size tire wouldn't work without additional fender/camber mods, what size would I have to go with without worrying about rubbing? Thank you. |
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
