Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
11-11-2012, 06:27 PM | #3426 | |
Member#: 145105
Vehicle:2015 Honda Accord |
11-11-2012, 06:29 PM | #3427 |
Member#: 292732
SWIC
Vehicle:2007 FXT SGM |
Washed, clay bar, 2 coats of wax. It took a couple hours but it Looks like fuggin glass. And now I don't want to take it out of the garage lol
11-11-2012, 07:57 PM | #3428 |
Member#: 281656
Vehicle:2011 DGM WRX 5dr limited |
New swaybays and end links went on the car today
11-11-2012, 08:07 PM | #3429 |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
^how'd the install go?
Rolled over 76000 today |
11-11-2012, 08:24 PM | #3430 |
Member#: 64624
Vehicle:2008 FS XT WR Blue Pearl |
Washed it, cleaned the Weathertech floor mats, sprayed on Iron Cut (still can't get used to the smell ) and washed again with ONR. Ran out of sunlight before I could wax it.
11-11-2012, 09:30 PM | #3431 |
Member#: 234416
Vehicle:It's A BRAAAAAHtato, Yo. |
Parked the car looked down to this little surprise...
11-11-2012, 10:09 PM | #3432 |
Member#: 111343
Put it on jackstands in preparation of swapping back to street brake pads.
Cleaned my wheels inside and out in preparation for Prima wheel armour. |
11-11-2012, 10:17 PM | #3433 | |
Member#: 137791
SWIC
Vehicle:2002 Impreza WRX WR Blue |
I'll look into it but what is the problem? Are people claiming that it lubricates too well or something? Really, I'd like to know about this because I think there are a lot of oil myths out there. |
11-11-2012, 10:33 PM | #3434 | ||
Member#: 304662
Vehicle:2001 Impreza L coupe Sedona red Pearl |
11-11-2012, 10:45 PM | #3435 | |
Member#: 281656
11-11-2012, 11:02 PM | #3436 |
Member#: 302496
Vehicle:2016 STI LIMITED WRB |
damn
my sti just hit 81k of course I missed the photo I hope to see the numbers you display., Today I decided no more 25mm spacers on the sti., And to sell the seats door cards and carpet! for something new.... |
11-11-2012, 11:06 PM | #3437 | |
Member#: 243697
Vehicle:2002 TOPSCOOB031 HighwaystarGarage |
Generally the problem is that if M1 5w30 shears down too much and/or burns off, lower oil and/or lubrication levels can lead to spun bearings. Realistically speaking though, a spun bearing due to low oil levels is not just the oil's fault... it really behoovs any WRX/STi owner to check oil levels at least weekly. Here is a UOA on Rotella T6 on an STi: http://www.iwsti.com/forums/attachme...9&d=1350740917 |
11-11-2012, 11:14 PM | #3438 |
Member#: 334143
Vehicle:2008 WRX Vin Diesel. |
Blacked out the tail lights, cleaned, washed, and detailed inside and out. Ripped some gears on the highway
11-12-2012, 01:45 AM | #3439 |
Member#: 255716
Vehicle:Itsa bugeye 04, V9 RHD and it makes me smile |
Got about 70% done with version 2.0 rear diffuser. Then I cleaned the **** out of the garage to make room for the subie.
11-12-2012, 09:45 AM | #3440 |
Member#: 64624
11-12-2012, 10:07 AM | #3441 |
Member#: 259164
Vehicle:2003 WRX Wagon silver |
I will be installing adjustable rear lateral links and aftermarket trailing arms.
If i have time a 21mm rear swaybar will be going in. anyone know of a good shop for alignments in Ocean City Md area? or am i driving to IAG performance outside baltimore |
11-12-2012, 10:11 AM | #3442 | |
Member#: 41447
Vehicle:---- _________ |
11-12-2012, 12:11 PM | #3443 | |
Member#: 166524
SCIC
Vehicle:2008 Spec C SSM |
If they have a newer machine they should be able to tell you what your ride height is at each corner. And they should also have weights to put on the drivers floor to simulate you sitting in the seat so your car doesn't pull to one side or the other. Just make sure they give you a before print out so you know the starting parameters. From that point you can tell them to set the camber, caster and toe where you want them. And once completed they should give you a final print out. |
11-12-2012, 02:30 PM | #3444 |
Member#: 136701
Vehicle:2013 WRBBRZ/S14 240 04WRX/05STi- Goooone |
11-12-2012, 02:48 PM | #3445 |
Member#: 239452
Vehicle:2012 Volvo S60 T6 2005 Outback 2.5i |
Installed the Blizzaks and gave it a nice bath.
11-12-2012, 03:11 PM | #3446 |
Member#: 310385
HIIC
Vehicle:2016 BRZ Limited Series.HyperBlue |
Installed a DW65c fuel pump. Seriously. Never again. I can't imagine trying to squeeze the Walbro 255, this pump was direct fit and still a massive pain in the ass.
11-12-2012, 03:17 PM | #3447 |
Lil Curious
Moderator Member#: 149626
Vehicle:2005 CGM FXT Rocket Box! :D |
11-12-2012, 03:23 PM | #3448 |
Member#: 310385
HIIC
The clips that hold the actual pump to the housing was probably the most difficult part. It took two of us, and a weird contraption of 4 flathead screwdrivers, one of them bent to hook the clips easier, and then we smacked the pump out with a nice headbutt.
11-12-2012, 04:10 PM | #3449 |
Member#: 288292
Vehicle:2004 sti wrb. the blue one. |
Received my Cobb iwg bracket and started deleting my tgvs
11-12-2012, 05:07 PM | #3450 |
Member#: 275640
Vehicle:2012 WRX hatch Silver |
Rebuilt the headlight actuators, replaced the headlight relays, and ran all new vacuum lines in the Corvette.
Similar Threads | ||||
What did you do to your car today? | Jester808 | Texas Impreza Club Forum -- TXIC | 3235 | 08-05-2013 12:55 AM |
what did you do to your car today? | Schrecken | Bay Area Impreza Club Forum -- BAIC | 11 | 09-25-2012 03:08 AM |
What did you do to your Scoob today? | Sheehan | North West Impreza Club Forum -- NWIC | 27 | 11-23-2007 12:02 PM |
