Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 11-15-2017, 05:30 PM   #11501
Topher03
Member#: 209375
2002 wrx wagon
Anyone have any heads laying around?
Topher03 is offline   Reply With Quote
Old 11-15-2017, 08:48 PM   #11502
Cobrakai
Member#: 176408
2005 STy
Got my protune done last night through Yimisport, 284/275 on a conservative "Stage 2" tune, no 6 speed yet.
So far I'm loving the V7, insanely smooth and very quick.
Only issue so far is the idle while warming up. The engine shakes violently like it wants to jump out of the engine bay. RPM seems to be ~ 900 and the temp gauge is just above the lowest mark, but goes away once it's fully warmed up
It's done this since I first installed it.
I cleaned the IACV when I first picked up the engine and put in a new gasket that should have expanded by now, going to snag another working IACV off my friends 205 that's sitting in my garage.
Anyone experience something similar?
Cobrakai is offline   Reply With Quote
Old 11-15-2017, 10:10 PM   #11503
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Your stage 2 ver 7 makes more power than my ver7 with a blouch 18G XTR.
Check your coil packs, My car had 2 weak coil packs and shook as you describe.
D-Rodman is offline   Reply With Quote
Old 11-16-2017, 08:31 AM   #11504
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You say that but you don't know what turbo he is running, or if he has headers, etc.. Maybe he has the VF30 and maybe not.
Did you install new coils?
Maybe your IACV is cracked, but if it was, it would act up more often that just at start-up.
Almost sounds as if the engine is being choked. Maybe the tune parameters need to be adjusted for cold start. Have you discussed this w/Yimisport?
Samurai Jack is offline   Reply With Quote
Old 11-16-2017, 01:53 PM   #11505
Cobrakai
Member#: 176408
2005 STy
Running the stock VF30, maybe it's just a high reading Dyno?
Nope the coilpacks are original, I may have to look into that.
It's done this since I dropped it in two weeks ago, on the JDM tune and now the protune.
I'll tinker around with it and see what I can come up with, aside from that it's running fantastically.
Thanks for the info
Old 11-16-2017, 04:41 PM   #11506
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
did u check your motor mounts?
Titter is offline   Reply With Quote
Old 11-16-2017, 06:34 PM   #11507
D-Rodman
Member#: 110078
05 Saabaru JDM STi
My car was e tuned recently, I actually have no idea what the dyno numbers are but on the previous tune the numbers were lower than the gentleman claims his car does.
Old 11-16-2017, 07:42 PM   #11508
Cobrakai
Member#: 176408
2005 STy
Yes that was the first place I looked, initially had a set of Group N motor mounts installed but the shake was driving me up a wall.
Edit
Could this be a tell tale sign for clogged AVCS screens? I wanted to remove them while the motor was out of the car but my friend said they're easily accessible with the motor in - aka he didn't feel like doing them with me
Can't seem to find any useful information when googling Ej207 AVCS Screens, from looking at the photos it appears that the banjo bolts are behind the rear timing belt cover and impossible to remove without taking off the timing components.
Old 11-16-2017, 09:19 PM   #11509
D-Rodman
Member#: 110078
05 Saabaru JDM STi
You'll wish you removed them while the engine was out, can still be done but its an easier job when the motor is out.
Old 11-16-2017, 09:55 PM   #11510
ether947
Member#: 297799
2003 WRX
EJ207 version 8
IIRC, you should be able to directly access the driver's side AVCS banjo bolt. Removing the after-MAF hose should gain you access to the passenger side. I think it took me 5 mins to check both. And probably 10mins of wrassling with that after-MAF hose.
ether947 is offline   Reply With Quote
Old 11-17-2017, 08:09 AM   #11511
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Just remember those coil packs are 15 years old. They are worth replacing.
Also remember: Numbers are a reference value for you, nothing more. You can't directly compare numbers. What matters most is what are YOUR numbers from YOUR tuner and how have YOUR mod changes have changed YOUR numbers with the same tuner/dyno.
Old 11-17-2017, 09:42 PM   #11512
SkaterFr3ak
Member#: 196479
2004 WRX
anyone know if the coilpacks are the same as usdm motor. I got fresh ones for my ej205 before i did the swap. It would be nice to use those for the price i paid.
SkaterFr3ak is offline   Reply With Quote
Old 11-17-2017, 09:53 PM   #11513
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Default EJ207 Owners?
V7 coilpacks are black, just like 02-03 and I think 04 USDM wrx. I replaced all 4 on my v7.
V8 and V9 use gray coilpacks just like 05-07 USDM wrx and STi.
Old 11-18-2017, 04:35 PM   #11514
Micro
Member#: 103451
00 RSTI
Can a brand new sti dealer clutch handle a V7 207 with bolt ons?
(This is for a 6speed)
Edit... I know it can* handle it... but will I get decent life out of it? I daily drive with the occasional heavy foot on the highway. No launching or drag racing.
Micro is offline   Reply With Quote
Old 11-19-2017, 11:00 AM   #11515
Samurai Jack
Member#: 21145
2002 Enemy of Aku
What he said. They are the same P/N.
Old 11-19-2017, 02:34 PM   #11516
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Easily , The stock STi clutch will handle almost anything except repeated hard launches.
Gigs90 is offline   Reply With Quote
Old 11-19-2017, 02:58 PM   #11517
Samurai Jack
Member#: 21145
2002 Enemy of Aku
How much life anyone gets out of a clutch is directly dependent on the driver.
Drive like an ass and you will get much shorter life out to it.
" A heavy foot on the highway " has nothing to do with clutch life, unless you are dumping the clutch while you drive or riding the clutch.
Old 11-19-2017, 07:23 PM   #11518
Micro
Member#: 103451
00 RSTI
Thanks for the quick replies, guys. That’s what I figured. Im not trying to race my car around the streets of nyc. Just wondering if it’ll hold the 300 tq at the wheels for more than 20k miles.
Thanks again ������������
Old 11-19-2017, 09:16 PM   #11519
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
unfortunately your V7 swap is probably no where near 300wtq , Probably closer to 260-270wtq at best.
It will be fine
Old 11-20-2017, 02:18 AM   #11520
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Are the intake cam seals and AVCS seals on the EJ207 version 7 the same as the USDM variants?
What about the exhaust cam non-AVCS seals... are they the same as the WRX EJ205?
iNfEk is offline   Reply With Quote
Old 11-20-2017, 06:24 PM   #11521
wrxstefan
Member#: 478018
2003 Impreza WRX
Lightbulb
I've recently bought a 03 WRX fully converted to STi. Here's my setup:
2002 BUG STi EJ207 motor with AVCS (Can anyone tell me if its a v7,8 or 9?)
STi 6 speed DCCD tranny
STi drivetrain etc
Exedy stage4 clutch
APS SR40 turbo
Custom flowed pink STI injectors (840cc)
GT-spec exhaust manifold
Grimmespeed boost solenoïd
JDM STI ecu
Aluminium radiator
FMIC
HKS dumpvalve
Walbroo 255lph
3inch open exhaust
STI Intake
Brembo's all around
It's currently mapped at 385HP/460NM TQ. Does anyone have an idea what kind of power I can squeeze out of this car? The previous owner said I could crank it over 400hp, but didnt mention any exact numbers.
Sorry if it's offtopic, can't create my own topic yet as i've got 0 posts
Also, when the car is cold and I try to start it I have to pump the gas pedal for it once or twice in order to start. It's like the car is not getting any fuel untill you do so. No problems after that, runs smooth as butter.. Anyone knows whatsup with that?
wrxstefan is offline   Reply With Quote
Old 11-20-2017, 07:42 PM   #11522
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
STi drivetrain etc
Exedy stage4 clutch
APS SR40 turbo
JDM STI ecu
Aluminium radiator
FMIC
HKS dumpvalve
Walbroo 255lph
3inch open exhaust
STI Intake
Brembo's all around
That's good numbers already. What are your goals.
Old 11-20-2017, 07:42 PM   #11523
Topher03
Member#: 209375
2002 wrx wagon
Anyone have any V7 heads for sale?
Old 11-20-2017, 10:02 PM   #11524
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
STi drivetrain etc
Exedy stage4 clutch
APS SR40 turbo
JDM STI ecu
Aluminium radiator
FMIC
HKS dumpvalve
Walbroo 255lph
3inch open exhaust
STI Intake
Brembo's all around
Sounds like a V7 engine if its got a single scroll turbo bolted onto it , That sounds healthy.
I have a local who is selling V8 207 heads
Old 11-20-2017, 10:03 PM   #11525
Topher03
Member#: 209375
2002 wrx wagon
Any idea on a price?
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
