Welcome to the North American Subaru Impreza Owners Club Friday August 17, 2018
Old 04-11-2011, 10:44 AM   #1426
legacy2003
Member#: 38338
2003 Outback Sdn H6
By the way, if I didn't want to go one step colder, would it just be the Denso IK20's? I'm not sure how the numbering system for Densos work, as I've been out of the game for a little while. Do you guys prefer Densos or NGK's? If I didn't want one step colder NGK's it would be the BKR6EIX IIRC right?
legacy2003 is offline   Reply With Quote
Old 04-11-2011, 11:42 AM   #1427
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
The JDM 207 is already one step colder, that 7 series. The EUDM and AUS take the 6 series.
I know this from the EU and AUS workshop manual and from the JDM F.A.S.T. parts catalog.
The JDM coil packs are of a different part number than anything USDM. I didn't check the EU and AUS.
Old 04-11-2011, 10:38 PM   #1428
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
I just bought a set of NGK BKR7E-E (NGK 4776) plugs since they're gaped to 0.032", which is close to what I thought was stock (0.030"). The reason I bought these is because the engine came w/heat range 7 plugs, but I've been running heat range 6 plugs.
My Car runs pretty good w/the BKR6E's that are in there now. No misfires or anything. I gaped them to 0.030" before putting them in.
Should I continue to run the same gap w/the new plugs when I get them in?
Thanks!
K.Linchpin is offline   Reply With Quote
Old 04-11-2011, 10:57 PM   #1429
Clark Turner
Member#: 178047
02 WRX STI Spec C
bk7eix plugs gapped at 026. If you get plugs that have -11 at the end of the part number, You got the wrong plugs. Those are 44 gap plugs and are for NA motors. Lots of vendors and even catalogs are wrong. Make sure to get plugs that are not -11
C
Clark Turner is offline   Reply With Quote
Old 04-11-2011, 11:10 PM   #1430
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
From what I'm reading, it's difficult to find the plugs the car is specced with, the PFR7G.
What is available is the iridium version, the BKR7EIX. My info is that these have the right gap.
As far as the gap, I only have info for the PFR6G, from the EUDM workshop manual as 0.7-0.8mm or 0.028"-0.031".
I have not found yet the workshop manual for the JDM version and something tells me that it will be in Japanese, if I find it.
Edit: I guess Clark answered this already, as I was looking at info and typing my answer.
Old 04-11-2011, 11:14 PM   #1431
Clark Turner
Member#: 178047
02 WRX STI Spec C
BKR7eix is the right plug for the 207. The PFR is just a platinum plug. The EIX is an iridium. Close the gap down to 026 if the tune or parts are modified.
C
Old 04-12-2011, 12:09 AM   #1432
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
C
Clark, .026 is pretty tight. Should I do the same for my V-power coppers when I get them in?
My car has been tuned to run on street gas (93 octane w/a top end target boost of 19 psi) but mechanically unmodified.
Old 04-12-2011, 07:15 PM   #1433
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Originally Posted by gling View Post
Seanathanq83,
I'm not sure about the difference in cam sensors but was under the impression that they were the same. I've driven for more than 100 mi. on the USDM ECU before and have not had any issues. Good luck passing the emission test in Texas. Speaking of which, it'll be nice to compile a list of states that will pass JDM v8 ECUs. Thus far, we have:
Pass
1. CT
2. OH
3. IN
4. MD
Stinkin' 'lil f*kers
1. MA
Feel free to copy and paste the list to keep it alive.
Cheers.
Gerald.
V7's & V8's with respective ECU's pass in IL.
KenSekiguchi is offline   Reply With Quote
Old 04-13-2011, 12:03 AM   #1434
jam007
Member#: 174706
2008 LGT-B
Hello, i'm doing a v8 EJ207 swap on my 2004 wrx and having trouble figuring out this vaccum line in the photos. It is part of the purge control solenoid valve, the line that releases the fuel vapors into the intake manifold to be burnt has a "T" in it, off that "T" that vaccum line runs above the intake tube and along the passenger side of the intake manifold as well as parallel to a PCV line, and another line to the turbos pressure control solenoid then was cut not by me this is how I received it.
I have searched everywhere on this site and everywhere else trying to figure this out any help or ideas would be awesome cause i'm fresh out and this is the only thing in my way sadly of having a running car.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG
jam007 is offline   Reply With Quote
Old 04-13-2011, 09:12 AM   #1435
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
I've looked up the part diagrams for the V8 EJ207 JDM. The hose that goes to the valve is always in one piece.
This was aftermarket. Also, if your engine is JDM, this was driver's side. So maybe somebody teed-in for a some kind of gauge.
Also, perhaps some of the car guys in Japan don't know what they're doing, just like everywhere else.
Anyway, I would eliminate that tee and move on.
Old 04-13-2011, 10:00 AM   #1436
jam007
Member#: 174706
2008 LGT-B
Thanks! I was hoping you would chime in thats exactly what I wanted to hear.
Old 04-13-2011, 10:44 AM   #1437
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
i agree. Pull the tee off. I have a V7 so not sure if it's different but i don't have a tee nor is there a hose coming off the intake manifold. There's a bolt in it's place.
gingertooth is offline   Reply With Quote
Old 04-13-2011, 10:53 AM   #1438
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Glad to help.
JAM 007, Your EJ207 is JDM, right, as opposed to EUDM or AUS?
To check, search the user PDX tuning with keyword bonanza.
The excel spreadsheet should come up and then check the engine number.
Old 04-13-2011, 10:57 AM   #1439
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
Anyone know how to figure out the engine number without the stickers on the block? My timing belt cover has been replaced and the sticker on the back is too faded to read.
fellstar is offline   Reply With Quote
Old 04-13-2011, 12:44 PM   #1440
jam007
Member#: 174706
2008 LGT-B
Originally Posted by Vlad View Post
Glad to help.
Yes it is a JDM EJ207, where were you able to acquire those JDM Subaru service manuals? I purchased an incomplete one on trade bit....so pissed about that.
Thanks again.
Old 04-13-2011, 01:12 PM   #1441
scoobie_snacks
Member#: 212744
2005 Ver8 EJ207 VF37
6 speed
Anybody here care to share some Version 8 base maps for stock engine/turbo/exhaust? I'm looking for a safe reliable 91 or 94 octane map for the summa!
thanks
scoobie_snacks is offline   Reply With Quote
Old 04-13-2011, 02:34 PM   #1442
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
I don't have service manuals, but the parts software for JDM.
I have service manuals for EUDM and AUSDM 207.
I suspect that the JDM EJ207 service manual would be in Japanese, just like the parts software.
I am working to get the service manual for the JDM, but for that a friend will probably have to walk to a store in Japan.
I am sure that 75% of the stuff from the EJ207 EUDM and AUSDM manuals still apply, trouble is you won't know for sure what doesn't.
Also, I'm kinda tired with all the speculation and mistery and want to kinda clarify some stuff, if I can.
Many people used already parts and procedures from the USDM with no trouble and that is fine.
I want to understand what differs in part number and procedure, that's all.
Old 04-13-2011, 04:59 PM   #1443
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I'm considering doing an EJ207 v8 swap into my 03.
I've been told to avoid the sellers from Canada. What's a good importer within the states that has reasonable pricing?
Also, what's the durability of this motor in stock trim in the 400-450whp range?
I called the vendor about the Ebay listing below and they are shady. They said they paid over 13K just for the motor from Japan and they are losing money on it. He also said, they have a shop setup in Japan just to buy salvage cars from there. When i informed them, that a used EJ207 v8 motors never sold that high. He hung up on me. LOL!
http://cgi.ebay.com/ebaymotors/Subar...item5198a5c239
Fierysun is offline   Reply With Quote
Old 04-13-2011, 05:47 PM   #1444
jam007
Member#: 174706
2008 LGT-B
Right your correct, I basically used the USDM STI manual for torque specifications and what not, the only thing that plagued me was that stupid vacuum line and I was just worried cause of the missing purge valve that is on the USDM and not on the JDM motor. But I cut that tee out and saw that it was aftermarket there must of been some type of gauge that used that for a vacuum signal cause there was HKS inscribed on the fitting, oh well its a learning process.
Old 04-13-2011, 10:50 PM   #1445
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
What is available is complete engine part number to engine model number finding.
You still have the engine serial number etched at the top/back of the engine, but I would guess only the dealer could help you ID that.
Old 04-13-2011, 10:59 PM   #1446
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Right u are
white guys wrx is offline   Reply With Quote
Old 04-14-2011, 07:25 AM   #1447
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Last night I found the V9 Spec C owner's manual, in Japanese. The gap specified for the PFR7G is also 0.7-0.8 mm
The Sti also gets the same plugs, it's shown in the same table. The JDM WRX gets PFR6G with the same gap.
The oil reccomendation chart looked similar to the USDM, but there was language (which I did not translate) that sat next to "10W50".
Old 04-14-2011, 09:52 AM   #1448
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
I would have hung up on you too, lol. That price is fairly cheap. I paid 4K for my v7 swap without a transmission last year, from a canadian shop. I am very pleased with it. Looks like it has an aftermarket y-pipe on it too.
Most people want 3200 for a 6 speed, so that is a really good deal.
Be mindful that if you pay via credit card (highly recommended) that your bank may charge you a fee for international use. BOA does.
langsbr is offline   Reply With Quote
Old 04-14-2011, 10:30 AM   #1449
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
I paid 7.5k for my v8 swap with transmission and vf37 installed.
Old 04-14-2011, 11:17 AM   #1450
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
13k for just the motor? wtf! That is a lot of money.
On the motor that you linked to. I'd make sure the number on the bar code checks out. The after market y-pipe doesn't impress me, nor does the green wire that is all over the place. 6k for both engine and trans is a pretty good deal. sometimes you can find the whole engine and drivetrain for 8k.
I got mine from eagle japan motor and it came in looking like new. I changed the timing belt, water pump, and idler pulley, but didn't need to as they looked like they were in perfect shape. The engine came with a butchered chassis wiring harness and some butchered ac, coolant, and vacuum lines, but I was able to reuse a lot of stuff from my car. The engine harness was in good shape and using pins from the butchered chassis harness, i was able to make my own avcs cable. They gave me a 30 day warranty, but it took me longer than that to get it up and running (dam exhaust!). Oh, shipping was MUCH cheaper from canada having it delivered to my work's commercial truck dock, so keep that in mind. They used the cheapest freight company imaginable, but everything was in good shape, so no complaints. It was a leap of faith, but they were very reputable, plus try building a better motor for less....
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
