Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Old 06-21-2009, 08:34 PM   #1
canjee
Member#: 195367
Forester Fuel pressure problem, need some advice.
Hi Guys,
My fuel pressure is sitting at about 48psi at idle, which is too high. I know that the 0vac 0boost pressure is 43.5psi and that idle should be about 35psi (21 in hg = 8.8psi).
I am taking the measurement on the engine side of the fuel filter.
The fuel regulator has been swapped with no change and I have disconnected the fuel line before the pressure damper to see it was a return line blockage.
I have also tested the fuel regulator by cycling the pump without starting the car, and the pressure sits at about 45 psi.
The only fuel system mod I have is a walbro pump, but since the problem isn't low pressure I have ruled out a pump problem.
what else can I do / should I check? Are there any problems with my methodology so far?
canjee is offline   Reply With Quote
Problem...need some advice not2fast Newbies & FAQs 5 06-09-2010 04:15 PM
I'm a moron hear me roar. Pump install problem need some advice noonagon Newbies & FAQs 9 04-14-2009 02:09 AM
Fuel Pressure Problem - Need Help dwarren Water/Methanol Injection, Nitrous & Intercooler Cooling 4 07-02-2007 07:42 AM
defi d-series air/fuel gauge install, need some advice Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-09-2003 01:17 AM
Need some advice diagnosing a problem. paultg Car Audio, Video & Security 15 09-12-2001 01:45 PM
