02-11-2003, 01:55 AM | #1 |
Member#: 18372
Vehicle:2002 WRX White |
How bad is this?
If you accidently fill up the oil beyond the top dot on the dip stick how bad is it? Will this cause gunk up in the engine?
02-11-2003, 02:16 AM | #2 |
Member#: 15622
Vehicle:2002 WRX SW WRB |
If it's too high then the crankshaft will be under the oil in the oil pan and at 5000rpm will churn the oil pretty badly. You should be able to drain some oil at the plug pretty easily if you're careful. I've done it before. Just catch it in a clean container so you can add it back in if you take too much out.
02-12-2003, 12:46 AM | #3 |
Member#: 9185
Vehicle:2012 Toyota Tundra Black |
When you drain the oil out .....make sure the car has cooled down.........Ya burn ow ....Im speaking from expierence. If you do burn yourself try not to stand up underneath the car ...ya owww
Wolfie |
02-12-2003, 03:31 AM | #4 | |
Member#: 25234
SWIC
Vehicle:2016 DGM WRX Premium 287 Igg-Points just `cuz |
poor guy.. lol... 93WRX |
My brother is looking at this 1999 Dodge Durango. How bad is this rust? | skywaffles | Off-Topic | 37 | 06-12-2008 01:48 AM |
laptop fan is dying. how bad is this going to hurt my wallet? | Captain TinklePee | Off-Topic | 19 | 10-26-2007 01:54 PM |
How bad is this bottleneck? | drdome99 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 18 | 01-29-2005 08:12 PM |
HELP: How bad is this damage? | samwY | Tire & Wheel | 11 | 09-18-2003 03:18 PM |
