07-12-2000, 08:22 PM | #1 |
Member#: 12
Vehicle:2018 STI Type RA Crystal Black Silica |
Possible to do sub 7.0 0-60 runs w/o turbo, supercharger, or nitrous?
I have a 98 RS with a JC intake, underdrive pulley, and a free flowing muffler. I am guessing my hp is around 190. Most 0-60 runs are in the low 7's with a few 6.9's and one 6.8. I was wondering if anyone was running faster with similar mods. I cannot afford a turbo or supercharger and don't want to blow up my engine with NOS, but I would like to make my Impreza faster. Any suggestions?
07-12-2000, 08:32 PM | #2 |
Member#: 1346
Have you looked at Rallispec's cams yet? I hear they're still being designed, the DOHC ones that is, and it's substantially less than a turbo setup.
Check out www.rallispec.com and mail em for details. |
07-13-2000, 09:36 AM | #3 |
Member#: 216
Since it sounds like you've only replaced the muffler, you could replace the exhaust piping from the headers back. Take it to a muffler shop, have them fabricate everything with 2.25" piping, throw in a 2.25" cat and weld it up to the muffler you already have. Should cost around $300, and it will probably net you about 10 more horsepower.
If you want a turbo, but don't have the funds, I'd just save up until April of next year. As soon as the WRX hits I'm sure there will be a plethora of used turbo kits available with not many miles on them. |
07-13-2000, 10:46 AM | #4 |
Techno Sapien
Moderator Member#: 449
Vehicle:2019 Impreza Sport Lithium Red |
I'm getting the same numbers as you with my mods. 6.8, 6.9 w/ a g-tec. I think I could do better with more practice but not much better
07-13-2000, 11:14 AM | #5 |
Member#: 102
My folks's 91 miata ran low sevens with a gtech! The miata for that year was rated with 115hp and errr... almost no TQ and a 0-60 of 9 ticks. So I won't trust gtech that much anymore.
07-13-2000, 03:25 PM | #6 |
Member#: 12
Tim, I thought replacing the exhaust from the cat back would be a good idea also, that is, until I did some research. There was a SCC mag a few months ago that tested many aftermarket items for the 2.5RS on a four wheel dyno and all of the enlarged catback exhausts actually lost horsepower due to the decrease in needed backpressure for the engine. Apparently a larger pipe will only help when you have more power, like with a turbo.
07-13-2000, 04:02 PM | #7 |
Member#: 216
That's why I said 2.25" piping. SCC found losses when going to 2.5" piping. Larger diameters will decrease the exhaust gas scavenging effect. Basically scavenging is when the gases pull themselves along in a smooth flow, if the diameter is too large (for the amount of flow) you'll get turbulence in the exhaust stream. Replacing the intermediate pipe (cat back section) will help some, but if you want best results replace the the cats as well with a high flow 2.25" cat. Have the muffler shop straighten out some of those bends too and you'll be in business.
07-14-2000, 12:17 AM | #8 |
Member#: 626
Vehicle:2001 Impreza 2.5 RS Black Diamond Pearl |
Nah Gambit I dont think the GTECH is that bad. Garbage in garbage out.
07-14-2000, 12:40 AM | #9 |
Member#: 518
NESIC
Vehicle:762 PGT Impreza L, Elantra GT Sport |
Well, remember that the GTech is very accurate...relative to itself. If you put it up against real timers, it will be off. But it'll be dead on if you use it to compare modifications on the same car using the same GTech.
Trunk Monkey is Coming! Sean Sosik-Hamor < [email protected] > Sosik-Hamor Networks Project Subaru Epinions Automotive Reviews by `Sean Dmoz Subaru Index by `Sean [This message has been edited by Sean (edited July 13, 2000).] |
Is it possible to do an 06 to 05 front end swap? | mobilezen | Interior & Exterior Modification | 20 | 11-30-2013 05:13 PM |
possible to do turbo, injectors, and plugs install in less than 5 hours?? | maramaralula | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 08-20-2008 09:57 PM |
What to do with 7 year old sticker pinstripes?!!! | Kostamojen | Interior & Exterior Modification | 21 | 05-25-2006 08:13 PM |
possible to do 02 front end swap to a 04 wrx? | subaru-noob | Member's Car Gallery | 16 | 03-17-2005 10:49 PM |
Possible to do a 2.5RS to WRX engine swap? | datpnoy2nv | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 04-20-2001 03:12 PM |
