Welcome to the North American Subaru Impreza Owners Club Thursday September 20, 2018
Old 02-07-2004, 11:22 PM   #1
WRXVII
Member#: 15854
VF34'd...
Default What is the sign of worn out engine mount?
I hear this clunking noise from underneath the car and the movement can be felt via brake pedal... it could mean that something is moving around. Could that be due to work out engine mount? this is from my beater - 92 Miata =)
WRXVII is offline   Reply With Quote
Old 02-08-2004, 07:03 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
When do you hear the clunk? If it's engine mounts you'll probably hear it when the engine moves, such as when you first get on the throttle or first release it. If you hear it when going over bumps it's probably suspension-related.
Mulder is offline   Reply With Quote
Old 02-08-2004, 02:46 PM   #3
WRXVII
Member#: 15854
VF34'd...
could it be due to worn out struts...? it is felt when going over a bump and also when driving...
Old 02-08-2004, 03:13 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Possibly, if the internal valves in the struts are bad or the fluid has leaked out they may clunk over bumps. Bad upper strut mounts can cause this also.
What's the sign of worn out springs? txl146 Brakes, Steering & Suspension 15 11-14-2004 11:00 PM
what is the name of the machene gun that sticks out of the side of a bomber D-I-Z-Z-L-E Off-Topic 29 10-25-2004 07:30 PM
What is the sign of an imbalanced wheel/tire? WRXinEffect Tire & Wheel 5 07-08-2004 08:05 AM
What are the signs of a motor that is about ready to let go? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-19-2004 10:11 AM
What is the purpose of an angled top mount intercooler? latinskllz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-10-2001 10:07 PM
