Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Old 03-18-2004, 01:23 AM   #1
waitandbleed92
Member#: 33990
09 WRX STI
Lightning Red
Default What are the signs of a motor that is about ready to let go?
I am not having problems just wondering what the signs may be, like how can you tell that your compression is bad? or can you even tell with out having a leak down test ran? Anything like that type of knowledge would be helpful.
waitandbleed92 is offline   Reply With Quote
Old 03-18-2004, 02:55 AM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Compression test is different than a leakdown test.
You can get a compression guage and do the test pretty cheap. A leakdown tester is a lil more expensive.
On the WRX if compression is down in one cyl. many times that will throw a misfire code.
mr2guru is offline   Reply With Quote
Old 03-18-2004, 11:53 AM   #3
shields102
Member#: 9598
02 wrx
white
You could almost say, "many times, if you own a wrx, you will get a misfire code."
Lots of oil blow-by in the intake track. You may think that your turbo is gone. I personally know two people that sold turbos that they thought were blown( @ a discount) that were fine.......but their engines were not so fine.
Another thing would be a very rough idle.
shields102 is offline   Reply With Quote
Old 03-18-2004, 05:09 PM   #4
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
I guess overheating, smoke, burning oil. Bad signs of blown gasket. Bad hessitation. Or loud rattles followed by loud pops, followed by a loud boom, followed by you calling the tow.
vapore0n is offline   Reply With Quote
Old 03-18-2004, 07:45 PM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Usually it blows just after it goes the best.
Wombat North is offline   Reply With Quote
Old 03-18-2004, 08:50 PM   #6
Rally Punx
Member#: 10285
APS Club Spec - Blue
Rally Punx is offline   Reply With Quote
Old 03-18-2004, 08:55 PM   #7
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Misfires at idle was the calling card I recieved. The misfires then turned to knock at cruise and light acceleration.
LiquidForce is offline   Reply With Quote
Old 03-18-2004, 09:17 PM   #8
waitandbleed92
Member#: 33990
09 WRX STI
Lightning Red
COuld someone explain what a misfire sounds like?
Old 03-18-2004, 10:06 PM   #9
AlpineFD
Member#: 42573
2004 WRX
bang bang
AlpineFD is offline   Reply With Quote
Old 03-19-2004, 05:17 AM   #10
WRX Harvey
Member#: 13025
1998 RS-T
Rally Blue
A misfire sounds like a correct ignition event, it is just in the wrong place. Usually your motor runs with pretty close to evenly spaced firings in the cylinders, giving it the smooth idle you know and love. When you have low compression, or a bad spark plug, or some other problem causing misfires you will hear and feel a lumpy idle, the CEL may even flash at stoplights. I beleive that the conductivity of the fuel mixture drops at lower pressure, making for retardation. That is just my speculation.
A compression tester can be had for about 20 bucks and will tell you if you have a low compression cylinder. It is a good first test and is simple.
If you do have a low cylinder (more than 10% lower than the other 3), then you may want to do a leak down test. If you have access to a compressor capable of supplying 100psi with a small reserve tank on it you can do a leak down test. It measures the rate of loss in pressure. The testers can be pricey, so I reccommend having a mechanic freind help you with that one. With the compressor charging the cylinders, the leak can be easily found. You can hear it in the intake if it is an intake valve. If it is a piston or ring, air will be coming out the dipstick. If it is an exhaust valve you can cap off the exhaust with your hand in some cases. Fun with broken motors!
WRX Harvey is offline   Reply With Quote
Old 03-19-2004, 10:09 AM   #11
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
cling clang clang clang cling cling clang .....BANG
AutoSpeedWRX is offline   Reply With Quote
Old 03-19-2004, 10:11 AM   #12
mrbigisbudgood
Member#: 54378
2013 Mazdaspeed 3
Lets say your in 3rd gear WOT at about 5500 RPM and you hear a loud CLUNK BANG CLUNK K K K K BANG. This is a good sign that something has gone wrong.
"I think we threw a rod"
"Is that serious?"
"Yep"
mrbigisbudgood is offline   Reply With Quote
What are the signs that point to a bad flywheel? azn_outlaw Transmission (AT/MT) & Driveline 3 05-16-2010 03:14 AM
What are the signs of a bad Alternator? wrx03.4wz Electrical & Lighting 13 12-23-2009 09:34 PM
What are the signs your Struts/ Springs are wearing out? snow111 Brakes, Steering & Suspension 9 02-12-2007 04:54 PM
What are the symptoms of motor mounts? quickscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-15-2003 02:46 AM
Finally getting ready to let go of my car... RSX2STI STi Forum Archive 35 04-23-2003 11:34 AM
