Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 07-14-2006, 11:57 PM   #1
roboace
Member#: 67762
2000 GC8 JDM STi
Silverton
Default How to tell if your ECU is blown
I was wondering if there is a way to tell if your ECU is blown. I have been having problems with my swap and can't seen to get it to start, I can get it to turn over thought, but the fule pump doesn't come on. I need to know if the car would even turn over if the ECU whas blown, or if my problems is else where. Also my fuel pump does not turn on when hooked up throught the harness, could that be my problem?
Please HELP
ACE
roboace is offline   Reply With Quote
Old 07-17-2006, 02:27 AM   #2
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
No... The engine won't turn over... It will crank..
Back probe...
MonsterRallySport is offline   Reply With Quote
Old 07-17-2006, 03:14 AM   #3
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
do u get a CEL?
.sith.
sith is offline   Reply With Quote
Old 07-17-2006, 03:42 AM   #4
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
If the ECU is working properly then you will. If not, you may not..
Old 07-17-2006, 04:14 AM   #5
moss
Member#: 10197
If the engine will crank, and the fuel pump wont come on, I think its wiring... not your ECU.
What swap are you doing?
moss is offline   Reply With Quote
Old 07-18-2006, 02:48 AM   #6
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
did u ground out pin 3 of the fuel pump relay to pin 1(black) of the ingition relay?
.sith.
Old 07-18-2006, 09:45 PM   #7
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
argh, that is exactly my problem too guys, i have an ej20k and the motor turns over but the fuel pump doesnt come on, only the pump comes on when the key is in the start position...but as i said before it turns off as u turn the motor over...id like to know the answer to this as well, also...does anyone know where to buy jdm wiring harnesses for an ej20k?
2.5rsTurbo is offline   Reply With Quote
Old 07-18-2006, 10:11 PM   #8
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
well thats a pickle.. as there should be no change in the relays between the "on" position and when cranking.. are you running an FPC?
.sith.
Old 07-19-2006, 03:05 AM   #9
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
sorry, whats an fpc? fuel pressure controller?
Old 07-21-2006, 02:34 AM   #10
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
ooooooohh... so close... fuel pump controller
.sith.
Old 07-21-2006, 06:27 PM   #11
roboace
Member#: 67762
2000 GC8 JDM STi
Silverton
I did screw up the wiring, but now i have figured it out. but i am blowing the inginton fuse when i put it in the on position. i am trying to trace it out, but still working on it. does anyone have an idea if i could of blown my ecu or would it still be good if i just messed but the bottom part of the 3 connectors into the ECU. they were totaly flipped, how could i be so stupid.
Thanks
ACE
Old 06-08-2019, 12:41 AM   #12
1wrex
Member#: 501221
Default What was the problem??
[quote=roboace;14605085]I did screw up the wiring, but now i have figured it out. but i am blowing the inginton fuse when i put it in the on position. i am trying to trace it out, but still working on it. does anyone have an idea if i could of blown my ecu or would it still be good if i just messed but the bottom part of the 3 connectors into the ECU. they were totaly flipped, how could i be so stupid.
Thanks
ACE
Was it the ECU did you figure out the problem I'm having the same issues
1wrex is offline   Reply With Quote
Old 06-08-2019, 08:46 AM   #13
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
[quote=1wrex;46047446]
Thanks
ACE
Since this post is from 2006 I doubt he will be replying. You’re better off listing as much detail about your car as possible so we can help you trace your issue.
Turpid Porpoise is offline   Reply With Quote
How to tell if your uppipe is stock? Marlons101 Newbies & FAQs 1 01-20-2008 10:07 PM
how to tell if your boyfriend is the antichrist scaryfastskier Off-Topic 8 12-18-2007 07:38 PM
How to tell if an ecu is usdm or jdm? 2slofouru Subaru Conversions 4 08-11-2006 11:49 AM
How to tell if your nose is broken? Stickee Off-Topic 11 01-26-2006 03:41 PM
How to tell if your uppipe is leaking? 02wrx999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-16-2002 08:34 AM
