Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 12-09-2014, 01:43 AM   #26
subi400
Member#: 216984
1996 Impreza outback
Green
Originally Posted by cHowland View Post
If anyone is still checking on this thread, I have major questions. I have a 1995 impreza Wagon with a 2.2 manual, and a 1998 subaru legacy 2.5 gt limited auto, what would I have to do to swap the drive train from the impreza into the legacy?
Ok, so I gather either the 4eat is going out or you want a 5 spd swap right?
Let us know what it is and we can go from there.
subi400 is offline   Reply With Quote
Old 01-31-2015, 02:15 AM   #27
casper_actual
Member#: 410557
1998 Legacy GT 5MT
Red
I know this is a month old, but found it most relevant to my current project. I have a 98' Legacy GT 5MT, with a dead motor and bad tranny, and am pulling a good ej22 motor out of a 98' Impreza Outback Sport, and just bought a 2005 Legacy GT 5MT Tranny for the 98 GT since it's current tranny is fubar'd. Couple noob questions: Will the 05 Tranny have the correct number of bolts/studs to line up with the 98 ej22? (which is currently connected to a 5MT, but since the final drives are different between the OBS and legacy, and my rear diff is rusted bad on the OBS, I opted for a new tranny) Should I use the wiring harness and/or ECU from the OBS or GT? Also was advised I need WRX front axles for the 05 Tranny... thanks
casper_actual is offline   Reply With Quote
Old 02-21-2015, 01:36 AM   #28
grossgary
Member#: 88368
1989 XT6
98 Impreza EJ22 will bolt in and plug right into a 1998 Legacy GT EJ25. No wiring or ECU needed.
Use the 1998 single port exhaust manifold. The EJ25 is dual port exhaust. The manifolds easily interchange. Remove EJ25 manifold, bolt up EJ22 manifold.
Trans will bolt in just fine.
Front axles - use the 05 front axles and knock the tone ring off the outer joint? That works on 00-04 axles and will for 05's if they use the same hub-side set up.
I'm unsure of overall transmission length, multiple speed sensors, etc?
grossgary is offline   Reply With Quote
Old 02-27-2015, 04:48 PM   #29
scptaco
Member#: 407839
2001 RS
black
I've been trying to find another 2.5L they're a rare find
scptaco is offline   Reply With Quote
Old 02-27-2015, 04:52 PM   #30
grossgary
Member#: 88368
1989 XT6
Old 07-05-2015, 08:30 PM   #31
onewipewonder
Member#: 423855
I have a gen 1 91 legacy 2.2L 5 speed sedan are the older ej22 wired the same like the new one to put a 2.5 motor in?
onewipewonder is offline   Reply With Quote
Old 07-05-2015, 09:15 PM   #32
grossgary
Member#: 88368
1989 XT6
are you trying to install an EJ25 into a 1991 legacy?
1994 and earlier are OBDI and not compatible but you have some options:
1. bolt the 1991 heads onto the EJ25 block - then you just use the 1991 intake and electronics.
2. install the 1991 wiring harness onto the EJ25 intake manifold. then drop the entire lump into the car - it'll be an EJ25 with 1991 wiring/electronics.
i'm unfamiliar with doing it that way on 1994 and earlier stuff as they're all rusted away and i avoid them like that plague anyway. but it works in other swaps and these are so similar it probably does here as well.
Since I don't know 1994 stuff...i'm starting to guess right now - so the below is a mix of probable and possible:
you'd want to install any 1991 sensors that are different from the EJ25 sensors. you can check opposed forces or ebay for which sensors are the same or not.
TPS is certainly different - swap the 1991 TPS onto the EJ25 - if it works, i'm unsure?
Or swap the entire 1991 throttle body with TPS/idle controller onto the EJ25...again
i'm unsure.
knock sensor, TPS, idle control, cam, crank, and ignition coil are the major ones.
Old 07-05-2015, 09:15 PM   #33
grossgary
Member#: 88368
1989 XT6
check each of those part numbers, interchanges, and find out which ones are different and how to work around it - namely TPS and idle control are the only two i'd be concerned about, the rest are easy.
Old 07-16-2015, 02:44 PM   #34
96legacyl5
Member#: 425864
[quote=69subaru360;24324557]Yes, this is a very common and easy swap. I have done almost 20 of the phase 1 EJ25 > EJ22 swaps. Cheap and reliable, everything just plugs in and works, everyone that I did has a happy owner![/QUOTE
I'm looking to do a 96 ej22 legacy L swap with a manual tranny into
A 97 Legacy GT with and automatic tranny. What would it take to do this and how hard would it be?
96legacyl5 is offline   Reply With Quote
Old 07-18-2015, 10:16 AM   #35
grossgary
Member#: 88368
1989 XT6
Easy
I've written everything you need to know here:
http://www.ultimatesubaru.org/forum/...-dohc-vehicle/
Old 07-30-2015, 11:49 PM   #36
AWDacious
Member#: 409099
1997 Impreza EJ25
Red,blk and stupid purple
So after reading this thread, it seems to me that people prefer the EJ22 to the EJ25 DOHC. I just finished swapping an EJ25D from a 97 Legacy GT into my 96 Impreza OBS. Should I have just kept the EJ22? I'd hate to hear that. I'm not overly concerned about the EJ25 I got because the PO had done the head gaskets and the coolant that came out was clean when I did the swap.
AWDacious is offline   Reply With Quote
Old 07-31-2015, 05:16 PM   #37
grossgary
Member#: 88368
1989 XT6
people don't necessarily prefer the EJ22 - plenty of people have swapped to the bigger motor and prefer more power.
The EJ22 swap needed some space, write ups, and was a good option for some people. Also, there was a sweet spot a few years ago where EJ25's were really expensive - like $1,000+ and the cars that needed them weren't worth that much - particlarly in the rust belt where you don't want to spend $2,000 - $3,000 on somethign that's rusty. So a good alternative was the EJ22 - which back then could be found really cheap.
But now, a few years later - they're all older, cheaper, rustier - EJ25D's are getting equally old, less demand and cheaper, EJ22's are only going to get harder to find, the vehicles are dated, and age and rust are driving 90's values down enough that it's less of an issue now.
up to you if you have space, want to keep it, but sure keep it if you can.
best if the heads were resurfaced and Subaru or MLS quality headgaskets were used.
Old 08-01-2015, 06:35 PM   #38
AWDacious
Member#: 409099
1997 Impreza EJ25
Yeah, that makes sense. I guess people say they're [ej22] better constructed motors. I did inspect the ej25 before I decided on the swap. It's already had a HG job done on it with the MLS gaskets installed because I can see them on the seam. Not sure if the heads were resurfaced, and I'm not sure how I'd check it after the fact.
Old 02-06-2016, 08:28 AM   #39
Vid303
Member#: 439850
newbi here hope someone is still active so I have a 99 forester sohc 2.5 and I have put in a 97 2.2 complete with exhaust y pipe and had to use the 2.2 intake manifold I have spliced the harness from the 2.5 into but the issue I'm having is what looks like to be the throttle body from my 2.5 has an upper layer for what is the air bypass valve/aic valve and the 2.2 intake does not have that .... I have the iac valve from the 2.2 as well but it is a 3 prong connector and the 2.5 one is a 6 prong connector any one delt with this ?
Vid303 is offline   Reply With Quote
Old 05-11-2016, 10:04 PM   #40
shwangjohnnson
Member#: 441221
Default Vacuum lines
This is the closest related post I could find, but I need some advice. The vacuum line that splits off the fuel regulator and the intake manifold off of a 99' (which is the engine I'm running) intake has an electric pressure switching valve, where as the same line off a 95' (the body of the car the 99' is in) runs to a charcoal canister and back into the fuel reg or the tank. So who has ideas on how to combine these two systems into one? Or am I fine just plugging that extra line?
shwangjohnnson is offline   Reply With Quote
Old 01-10-2017, 11:58 PM   #41
serious
Member#: 22879
Yeah, what do you do with the charcoal canister lines when swapping a 95 2.2 in place of a 2.5 in a 98/99 car?
Plug them or do you just install the canister setup from the 95 engine?
serious is offline   Reply With Quote
Old 01-21-2017, 09:50 AM   #42
elmalosubie
Member#: 397395
I am in the middle of putting a 95 auto 2.2 into a 97 manual car. I have the engine in, so far i have noticed the AC compressor mounts are different as well as maybe the compressors. Did you have any issue with bolting the ac, ps, alternator up?
elmalosubie is offline   Reply With Quote
Old 01-21-2017, 12:24 PM   #43
serious
Member#: 22879
95 will have the heavy Iron black mount for the a/c pump and the 97 will have the aluminum one. Yes, they are different, just swap them around and you'll be fine. I'm pretty sure the power steering bracket is the same from 95-99, but not 100 percent sure.
Anyone have a clue about the charcoal cansister stuff?
Old 03-01-2017, 03:26 PM   #44
frankensuby
Member#: 463808
Awesome swap!! I miss my 2.2 since my newer 2.5 burns so much oil!!
frankensuby is offline   Reply With Quote
Old 08-19-2017, 02:23 PM   #45
subelove
Member#: 533
2008 STI
--Maybe someone here can help me out. I recently bought a cheap 2005 Saabaru that someone had already swapped a Phase II EJ22 in but they did not change the ECU. The thing runs great but I keep getting a P2096 code (there are no exhaust leaks before the CAT and new rear 02 sensor did not fix issue)
Anyone out there have thoughts on how I can get around this?
subelove is offline   Reply With Quote
Old 11-01-2017, 11:31 PM   #46
simoneau2011
Member#: 477041
I have a 99 legacy. It was a 2.2 but someone else put a 2.5 single cam i dont know what car they take it from I was Wondering if the ecu/ecm is the same or not. It runs and drive but when i drive the tranny feels its confuse the speedo dont work but no codes shows but when i go very slow or turning the speedo Peppa up for a sec and die out again. When the car idle the light Flickr today my radio stop working and my heater fan did too.i Un plug the fan the radio cam on but went off then i got the heater fan going again then both work rest of the night.
Can i get help on this
simoneau2011 is offline   Reply With Quote
Old 06-08-2018, 05:01 PM   #47
00_imprezaoutback
Member#: 452713
will a 00 legacy ej25 direct swap into a 00 impresa obs ej22???
00_imprezaoutback is offline   Reply With Quote
Old 06-28-2019, 04:56 PM   #48
Qualityautocare
Member#: 503515
I know I'm dragging up a really old thread but it seems relevant. I've got a 99 legacy 2.5 I just put a 97 2.2 in and all I get is backfiring. I was under the impression this swap was plug and play am I missing something?
Qualityautocare is offline   Reply With Quote
Old 07-25-2019, 11:16 PM   #49
christopher123106
Member#: 504623
1997 Legacy GT
Originally Posted by 69subaru360 View Post
Nothing is needed, it just bolts and plugs in.
I have a legacy gt 97 with ej22(phase 1) block and ej25d trans. What clutch kit buy ej22 phase 1 or ej25d?
christopher123106 is offline   Reply With Quote
Engine swap, '06 2.5i into '00 2.5RS--Direct swap? singincanary Subaru Conversions 13 10-01-2007 09:47 PM
Swapping a 2.2t Shortblock into my NA 2.5DOHC then Turbocharge MY99 2.5GT Subaru Conversions 15 11-08-2005 10:32 AM
Do they make a wiring harness kit for a JDM STI 2.0 into a '99 2.5rs? underground-mpyre Subaru Conversions 12 10-22-2004 08:44 AM
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I GODSON Subaru Conversions 10 10-12-2004 03:56 PM
swapping 2.2T into 95L 2.2N/A..questions scottsubarus Normally Aspirated Powertrain 4 04-01-2003 08:37 AM
