08-05-2016, 02:11 AM | #276 |
Member#: 433295
08-05-2016, 02:25 AM | #277 |
Member#: 18440
SCIC
Vehicle:2004 WRX Wagon Always need moar grip! |
So I could replace both of those....
With all due respect! I would like to point out that the chamfered washer needs to be chamfered side towards the bushing. |
08-05-2016, 01:00 PM | #278 |
Member#: 151895
You are correct...
I've noted that as well... Them Australian instructions are not very intuitive .... Still a good catch... |
08-06-2016, 11:11 AM | #279 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
Wow, this is insane, awesome work! Love seeing these types of builds. Will be curious to read about the ViPec when you hook it up, thinking of using one for a future project I have.
keep it up! Ben |
08-07-2016, 03:55 PM | #280 |
Member#: 452169
BAIC
Vehicle:2016 WRX White |
Subscribed
08-07-2016, 06:30 PM | #281 |
Member#: 151895
Build a harness they said..
It will be fun they said... Stripping few connectors from the old GC harness. Few of the tools required... To merely produce this... Last edited by remski; 08-07-2016 at 06:51 PM. |
08-07-2016, 06:35 PM | #282 |
Member#: 234236
RMIC
Vehicle:06 STI AW |
Good luck.. looks like LOADS of fun.
08-07-2016, 09:14 PM | #283 |
Member#: 183670
SWIC
Vehicle:2002 Bugeye PSM |
holy build! what is being done with the suspension ?
keep up the great work |
08-08-2016, 11:25 AM | #284 |
Member#: 151895
Still undecided on the coils...
Possible choices are... MCS, Jrz, or Penske... Basically I need somebody that will stand behind their product as I don't have much experience yet with tuning the suspension... |
09-04-2016, 09:18 PM | #285 |
Member#: 151895
So.. some long overdue progress....
Finally decided on the radiator stay brackets. A bit thick for my liking but its still aluminum. Also started working on putting the thank together. A small puzzle trying to figure out what vents stay and what vents get blocked. One of the valves with vents melted shut. Lots of time spent de-rusting exhaust pipes. 4 days soaking in vinegar helped a lot. I dont have the before pics.. but there was a nice layer of rust. Next in line is the steering column... Still deciding if I'll keep the turn signals and wiper switches... Since I wanted to use my original key i had to swap the locks... While at it steering wheel lock was shaved as well. Now I feel much safer. |
09-05-2016, 01:50 PM | #286 |
Member#: 327671
International
Vehicle:1998 Impreza Blue |
Do you have more photo's from other angles of the lock? I want to relocate the lock and get rid of the steeringwheel lock..
09-06-2016, 12:20 AM | #287 |
Member#: 151895
There isnt much to it.
Once the rectangle piece is shaved flat you'd be able to mount it anywhere on the column (if thats you you want)... considering that doing this wont make the guts fall out. I must say.. it is a heavy piece.. I've been wondering if I should delete it as well... But then you can just drive away without a key... |
09-06-2016, 01:46 PM | #288 |
Member#: 327671
International
Thanks, yeah I don't want to delete it completely. But I want it mounted like a gauge somewhere else in the console of my car. That big metal block must go as well...maybe I should think about another key mechanism but then I have two keys (doors and starting)
09-06-2016, 08:26 PM | #289 |
Member#: 151895
Well.. the key is incorporated into the whole mechanism and the contacts are at the end so i doubt there is an easy way to break it apart.
At this point this does not look like a good theft deterrent device. |
09-06-2016, 08:32 PM | #290 |
Member#: 454041
Vehicle:2005 wrx sti black |
The paint looks great in the bay!
09-08-2016, 01:56 AM | #291 |
Member#: 194708
RMIC
Vehicle:2005 Impreza WRX STi Aspen White |
Damn... this a wild build. I just want to see it finished! Awesome progress!!
09-08-2016, 10:55 PM | #292 |
Member#: 151895
09-11-2016, 11:19 PM | #293 |
Member#: 151895
Started making slow progress with wiring.
Since I didnt feel like doing splices with the old plugs, decided to put a new connector on the tail light. Few cuts later and those jdm tails now have a new plug. No going back now... Besides sitting and looking for ways to run the wiring, steering column, "brake booster" and clutch got installed. Its starting to look busy... Still deciding if I should ditch the ignition lock..... |
09-12-2016, 11:33 PM | #294 |
Member#: 453792
Wow!!! This thing is going to be sick when its done.
11-03-2016, 01:06 PM | #295 |
Member#: 151895
Time to get back to work now...
Picked up this last week... Was hoping to put this in the living room .. but hall will do for now.. |
11-03-2016, 01:09 PM | #296 |
Member#: 234236
RMIC
Vehicle:06 STI AW |
Yaaaaasssss
11-04-2016, 08:11 AM | #297 |
Member#: 327563
Vehicle:2018 Civic Type R 2008 N54 335i |
Great progress. Very meticulous. Car looks fantastic.
11-04-2016, 12:23 PM | #298 |
Member#: 145643
Vehicle:95 Impreza L-ish Blueish Green |
In for more!
11-07-2016, 04:36 AM | #299 |
Member#: 314324
International
Vehicle:MY07 Lib GTB 6MT Wag OBP |
Looks like a Fluidampr is already installed there for you
Inlet only avcs... Also a box of pistons? Are you destroking and closed decking it? With JDM spec C heads conversion? Love eeeet |
11-07-2016, 10:26 AM | #300 |
Member#: 381955
NESIC
Vehicle:2014 WRX World Rally Blue |
Subscribed. You're lucky to have such friends devoted to time on someone elses build! I'm excited to see the final result.
