03-15-2001, 05:21 PM | #1 |
Member#: 711
Vehicle:1993 Rx7 R1 Yellow |
Need Help With Turbo Kit????
Want to Buy a turbo kit for my MY99 finally... I want to be pushing about 250bhp. Where and How much?
03-15-2001, 05:45 PM | #2 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 15 Forester XT, 21 Ascent |
JC Sports sells an IHI ballbearing turbo kit for $3,899 that will push 5-7 psi easily and give you the 250hp you want. You'll need a boost controller or a tight wategate with ignition timing control and S-AFC to go higher safely.
I have one on my 2000 RS, and DaveK has one on his 1999. I rode in his MY99 RS with NO electronics, just a Vortech FMU fuel pressure riser and hi-flow fuel pump, and it rocks vs stock, with the wastegate set at only 4 psi! I was amazed, as it takes 5 psi for my MY00 turbo with the same kit plus extra injectots to feel as fast as his. ASR, rallispec and ludespeed have similar turbo kits, and you can search the links section of www.ImprezaRS.com to find them. Larry |
03-15-2001, 05:45 PM | #3 |
n00b Moderator
Moderator Member#: 4263
SCIC
Search "Turbo" under this forum...I found LOTS of info on where and how to get a turbo.
Skylab |
03-15-2001, 06:27 PM | #4 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Blasted "boost-suited" MAF owners!
03-15-2001, 06:52 PM | #5 |
Member#: 4460
Larry
How in the world can you recommend JC Sports? They are the worst company to do business with around. There are quite a few people STILL waiting for the turbo kits they ordered months ago. And you are not supposed to be even mentioning them, if I recall. Someone else is going to get screwed now! |
03-15-2001, 07:35 PM | #6 |
Member#: 1057
MWSOC
Vehicle:2004 WRX STi Very Yellow |
Oy vey! Let the people do a search and make up their own minds. There's already enough opinions on record about this topic to bore even Garrison Keillor to tears (and that's hard to do! ) No sense in being repetetively redundant twice now, is there?
-Doug |
03-15-2001, 07:56 PM | #7 |
Frank Army
Member#: 1457
SWIC
Vehicle:1999 Outback Sport Steel Blue Mica |
Larry, your a superstar and a smart man, but I'm with Short on this one.... How can you push JC Sports when they STILL haven't delivered all the kits in their GB?
I still respect you though.... Go for a <A href="http://www.forcedairtech.com" target="new">Forced Air Tech</a> kit like AaronB and I have done. |
03-15-2001, 10:55 PM | #8 |
over boosted again
RMIC
One, I mentioned what my personal kit would cost and how it performs, which will provide the level of performance he wanted - relating my personal experience with it.
Two, I also recommended several other vendors. Even though I have no experience with them, I wanted to be objective and un-biased. I posted a similar tidbit in another post to someone else, and listed several other makers of turbo kits. For the record, JC Sports often takes the same 3-6 months to deliver a turbo kit that other vendors will quote you, but the have been known to promise delivery of the kits much faster than they can deliver. Eventually everyone get's their kit and JCS don't take money and keep it without delivering a product. See the 27 page "turbo gb closed" post by JC Sports in the vendor section for more info. There - was that more objective Larry |
Similar Threads | ||||
Need Help with Grounding KIT | JDMprojekt | Electrical & Lighting | 4 | 12-17-2005 05:55 PM |
need help with grounding kit | mcgizzle | General Community | 2 | 10-26-2004 01:28 AM |
need help for turbo kit install | rupteur7000 | New England Impreza Club Forum -- NESIC | 8 | 08-13-2002 09:00 AM |
need websites with turbo kits | RZ_BRNR | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 05-28-2001 09:06 PM |
Help! I need help with turbo 99 | HOK | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 04-16-2001 08:05 AM |
