Welcome to the North American Subaru Impreza Owners Club Thursday September 21, 2017
Old 09-18-2017, 09:42 AM   #11426
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default EJ207 Owners?
its probably the coolant hose between the timing cover and the exhaust manifold on the front of the motor. it goes from the thermo housing to the oil modine.
Titter is online now   Reply With Quote
Old 09-18-2017, 02:03 PM   #11427
ddaley60
Member#: 211988
05 v9 ej207
Ill give it a check when i get back from work. Its not a lot of coolant but it builds up and runs down the oil pan and/or the rad hose. Hopefully its something as simple as that.
ddaley60 is offline   Reply With Quote
Old 09-18-2017, 09:43 PM   #11428
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
its a sneaky hidden hose thats notorious for leaking due to the heat of the exhaust manifold.
Old 09-19-2017, 06:49 AM   #11429
ddaley60
Member#: 211988
05 v9 ej207
update, both hoses around the water pump are clean no cracks or signs of a leak, for the $6 they are i still am going to replace them. Didn't have any drips during the day yesterday or evening but there were drips when i went out this morning but only underneath the radiator (drips through that little hole in the front subframe). So its only in the front and its only at night, temps have been between 50-60 lately.
Old Yesterday, 08:59 AM   #11430
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Have you checked both radiator hoses to be sure the connections are tight?
Have you checked the two small coolant hoses that run from the expansion tank down to the radiator?
Old Today, 11:56 AM   #11431
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Anyone have a part number for a version 8 IACV gasket or USDM compatible model?
Old Today, 05:13 PM   #11432
08OBS
Member#: 274397
2005 WRX V9 207
1992 Legacy SS
I believe it's the same as an EJ205 gasket. From doing some research I found this p/n.
22659AA120
08OBS is online now   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
