Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 02-28-2008, 09:20 AM   #1
RallyGuy2k
Member#: 1146
Default 225/45/17 on 2.5 RS?
I'm running the stock rims on the 2000 2.5 RS with 225/45/16 Falkens...
But looking to get Snoopy's P1s with 225/45/17s Toyos...off his Legacy...
ANYONE know if these would fit without rubbing???...
I have a nasty feeling I'm going to have to roll the fenders...
T
RallyGuy2k is offline   Reply With Quote
Old 02-28-2008, 10:04 AM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
you have to roll your rear fenders or you will rub...
don't fret... fender rolling isn't so terrible...
DanzBorin is offline   Reply With Quote
Old 02-28-2008, 11:35 AM   #3
Sn00py
Member#: 132408
2009 Lamborghini
Gallardo Supperleggera
Since when? i had 18" p1's with 225's on it and it fit just fine, and i was lowered on a 99 RS. Stock suspension it will not rub on 17's
Sn00py is offline   Reply With Quote
Old 02-28-2008, 11:44 AM   #4
DanzBorin
Member#: 7131
2015 Outback - Croc
well i guess the rest of the legion of RS owners that had them and they rubbed were wrong?
Old 02-28-2008, 11:57 AM   #5
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
rubbin is racin!
fender rolling is easy. just do it slow. If you want tool that makes it real easy, pm salaki. He has a fender rolling tool that he rents out.
lackofhp is offline   Reply With Quote
Old 02-28-2008, 12:53 PM   #6
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
rubs
after rolling quarter panels no probs
frnt fits fine
tht is what size i am running
AliBenn is offline   Reply With Quote
Old 02-28-2008, 01:00 PM   #7
DanzBorin
Member#: 7131
2015 Outback - Croc
Originally Posted by AliBenn View Post
rubs
frnt fits fine
Sno0py doesn't believe us...
Old 02-28-2008, 01:22 PM   #8
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
Most GC owners that asked me questions, in general, they rub w/ 225 and wider.
If you don't then you are probably "fairly close" to rubbing.
You may be able to get away w/ just removing the rubber strip
Try that first, before fender rolling.
If you like the P1 w/ 225/45/17, get them and try them on.
It's very hard to precisely guess whether you'll rub or not.
There are offset, width, alignment spec, tire brand/type that contribute into the rubbing/not rubbing.
As long as you don't get something crazy aggressive then fender rolling can mostly eliminate the rubbing issue.
PM Greg @ UG. I think they have fender roller for Houston guys to rent locally.
salaki is offline   Reply With Quote
Old 02-28-2008, 01:26 PM   #9
DanzBorin
Member#: 7131
2015 Outback - Croc
Originally Posted by salaki View Post
Most GC owners that asked me question, in general, they rub w/ 225 and wider.
But if it does rub w/o the rubber strip you could cut a tire...
but stand up of you to recommend the competition...
Old 02-28-2008, 02:38 PM   #10
RallyGuy2k
Member#: 1146
Right on...I remember the debate years ago and it all came down to what specific tire you run since '225' isn't always '225'...
There are some 225/50/16 that work and some that don't...I've always run 225/45/16 to be safe...
T
Old 03-01-2008, 03:21 PM   #11
couldnthinkaone
Member#: 2944
2008 MB R320 CDI
yeah, I'm wondering what kind of tires snoopy was running, cause I rubbed with 215/45R17's on a +53 17x7.5 with Kumho MX's AND rolled fenders(the back rubbed on big bumps/holes). tire manufacturer, alignment settings, ride height, and lots of other things can effect rubbing.
couldnthinkaone is offline   Reply With Quote
215/45-17 or 225/45-17 on an '05 RS sedan? Columbia1991 Tire & Wheel 4 02-24-2010 04:03 AM
('93-'01) 225/45/17 on 2.5 RS? RallyGuy2k Impreza Forum 8 04-06-2008 08:13 PM
225/45 17 on 2000 RS? Need help quickly. willguidry Tire & Wheel 1 04-18-2003 12:58 PM
215/45/17? or 225/45/17 on SDRs Costas Brakes, Steering & Suspension 4 02-11-2003 09:09 AM
225/45 17 on a my01 rs? suby ej25 Tri-State Area Forum 19 01-24-2003 11:40 AM
