Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 04-16-2018, 09:12 AM   #1
subieguy22
Member#: 420815
Default stripped banjo thread
recently bought a second hand engine and brought it home to find that the threads where the banjo bolt goes has been stripped. my initial thought was helicoil but I fear that this won't work since the diameter of the whole will be bigger than the banjo and crush washer. has anyone encountered this problem and has success? I've been trying to find info a few people had this problem with no real solutions.
subieguy22 is offline   Reply With Quote
Old 04-17-2018, 01:27 PM   #2
ghostrida3
Member#: 221570
I have used helicoils before and the diameter is only slightly larger than original hole. The crush washers should still seal. Timeserts may be a better option if the helicoils dont work.
ghostrida3 is offline   Reply With Quote
Old 04-17-2018, 01:48 PM   #3
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Use a locking Heli-coil rather than a standard one. You will likely need to order it.
mrsaturn7085 is offline   Reply With Quote
