Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 11-17-2012, 06:07 PM   #1
Buellrunner
Member#: 144553
2004 Impreza WRX
Default Metallic sounds that oscillates
Hey all I'm looking for a little bit of help with a diagnostic. My car seems to be making a high pitch oscillating metallic sound that seems to come and go and does not seem to be affected on whether I press on my breaks or not. The only way I can make the sound go away when it is occurring is to put my car through a turn. When my car is moving and turning/cornering the sound goes away, but once my wheel returns to center it will come back again. Shortly after the sound occurs for a few minutes it completely goes away and will eventually return again. Any ideas? Cheers!
Buellrunner is offline   Reply With Quote
Old 11-17-2012, 08:59 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It could be a wheel bearing
Old 11-17-2012, 09:13 PM   #3
Buellrunner
Member#: 144553
2004 Impreza WRX
Would a bearing issue come and go? Also would turning affect it?
Old 11-17-2012, 09:35 PM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
yes and yes
Old 11-17-2012, 11:32 PM   #5
Buellrunner
Member#: 144553
2004 Impreza WRX
Ok thanks for the input. Ill get it checked.
Old 11-19-2012, 02:01 AM   #6
CanadianImprezaSTi
Member#: 312159
2004 WRX
You can check it yourself by jacking up the car and grabbing the top and bottom of the wheel and checking for play. When a bearing is bad enough to make some good noise it will be a pretty good amount.
CanadianImprezaSTi is offline   Reply With Quote
Old 11-19-2012, 10:22 AM   #7
Buellrunner
Member#: 144553
2004 Impreza WRX
Thanks Canadian. This issue only seems to show up about 10% of the time when I'm driving. It seems to only show up after I have been driving the car on long distance trips. Never on short runs in the city. Does it still sounds like a wheel bearing issue? Another person that I know suggested a cv. I'm not technical enough to be able to diagnose it on my own And was hoping to avoid some of the costs associated with diagnosing it at Subaru.
Old 11-19-2012, 05:21 PM   #8
CanadianImprezaSTi
Member#: 312159
2004 WRX
Could still be. Weight transfer of steering making it go on and off really sounds like a wheel bearing. Especially if it's not related to engine RPM.
Takes a few minutes to check them.
If it was a CV joint it would make more of a clicking sound which would be very apparent at full lock on the steering.
Joel
Old 11-19-2012, 11:41 PM   #9
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have had alot of wheel bearings make noise and not be loose too.
Old 11-19-2012, 11:48 PM   #10
corvallisbattery
Member#: 333030
'05 WRX
Yeah it does NOT have to be loose to be bad. only the worse will show that much free play. Long trips give your wheel bearing enough time to heat up and start acting a fool. My front passenger makes a hum but only after an hour + drive. I've fixed it before... and will have to fix it again
corvallisbattery is offline   Reply With Quote
Old 11-20-2012, 10:26 AM   #11
Buellrunner
Member#: 144553
2004 Impreza WRX
Thanks for the help. If its just starting up now 10% of the time - should I replace immediately or can it wait?
