Welcome to the North American Subaru Impreza Owners Club Tuesday January 16, 2018
Old 01-12-2018, 04:04 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default xluben's 2010 Subaru STI | PTE 6466 | E85 @ 38PSI | 608WHP / 583WTQ |
Event: Dyno Tuning
Ambient Temp: ~55F
Elevation: ~900ft
Weather: Cold Outside
Tires: 215/55R17 Hankook Winter Tires with Konig Hypergram 17x8" +35 Wheels
Car: 2010 Subaru STI
Tuner: Devin @ JM Automotive
Dyno Info: Dyno Dynamics @ JM Automotive
Transmission: OEM STI 6 Speed
Gear: 4th
Peak HP at RPM: 608 WHP @ 6k-7.5k RPM
Peak Torque at RPM: 583 WTQ @ 5000 RPM
Baseline hp/tq for a stock on same dyno: 220 WHP / 218 WTQ (Stock STI)
Shootout Mode: 767 WHP / 720 WTQ (Similar to Dynojet)
Target Boost: 38psi
Target AFR: 11's
Fuel: E85
608 WHP / 583 WTQ
Full Build Thread:
https://forums.nasioc.com/forums/sho....php?t=2855524
Engine:
  • IAG Closed Deck 2.5L Case
  • IAG Pinnned Mains
  • IAG Cylinder O-Rings
  • IAG 14mm Head Studs
  • OEM Subaru Crank
  • Cosworth Head Gaskets
  • Manley 99.75mm Pistons
  • Manley Turbo Tuff I Beam Rods
  • King Rod and Main Bearings
  • OEM 2010 STI Heads
  • BC Stage 3 (280) DAVCS Camshafts
  • BC Stock Size Valves
  • GSC Beehive Springs w/Retainers
  • Aluminati Solid Billet Motor Mounts
Intake/Exhaust/Fuel:
  • Precision 6466 Turbo
  • MAPerformance 4-1 EL Header
  • FobiaFab Gate Dump on Header Secondary
  • TurboSmart 40mm HP EWG (35psi)
  • ETS Rotated Uppipe and Downpipe
  • Invidia Q300 Catback
  • ETS 4" Intake and Filter
  • ETS 3.5" FMIC Kit
  • TurboSmart Race Port BOV
  • Radium Dual Pump Hanger
  • Dual AEM 50-1200 E85 320LPH Pumps
  • -8AN Fuel Feed Lines
  • -6AN Fuel Return Lines
  • ID1700cc Injectors
  • IAG Fuel Line Kit
  • Aluminati Billet TGV Deletes
  • Aluminati Billet Fuel Rails
  • TurboSmart FPR 1200
Drivetrain/Transmission
  • Stock STI 6 Speed
  • Kartboy Short Shifter
  • Anarchy Motive Shift Knob
  • Aluminati Solid Billet Tranny Mount
  • Aluminati Solid Billet Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Disk
E85 tune completed at JM Auto. The car made 608WHP and 583WTQ at 38psi on their dyno. It is known to be low reading, so the "Shootout Mode" numbers are used as a reference to the local Dynojet. The numbers aren't too important to me as long as the trap speeds are there. Overall the power seems to be holding great and is about where I would expect based on the boost and fuel.
Dyno Video
Engine Bay
Old 01-12-2018, 05:28 PM   #2
flat4lover
Member#: 181867
2016 gtx35r sti
red
How do you like the maperformance header? just bought mine but haven't got it on yet
flat4lover is offline   Reply With Quote
Old 01-12-2018, 05:47 PM   #3
toph
Member#: 78640
14 LTZ 6.2
Why didn't you have NF tune this one? Going to keep power at this level?
toph is offline   Reply With Quote
Old 01-12-2018, 07:51 PM   #4
DavC825
Member#: 201736
12 IS-F..its white
Slowest 07 STi
what gen 6466?
DavC825 is offline   Reply With Quote
Old 01-13-2018, 12:30 AM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It fit great and it seems to be working well. Honestly didn't really seem to add much on the stock turbo setup, but I may have been limited by intake or TMIC. But on this setup it is really holding the top end well. Power is flat all the way to redline with no drop off.
NF is no longer tuning cars. JM is only a few miles from me, specializes in Subaru's, and has an AWD dyno. It's a good match and they've been good to work with so far. Power will stay at this point. The parts were all sized for this level (pumps, injectors, turbo, etc). Trying to avoid breaking driveline parts, but it will probably happen anyways.
Originally Posted by DavC825 View Post
what gen 6466?
Gen 2. The 6466 was only ever offered with the Gen 2 configuration.
Old 01-13-2018, 12:32 AM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Tried to make a speedo video, but it wouldn't hook. Need to get some warmer weather.
Old 01-13-2018, 12:33 AM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Photos from today.
Old 01-13-2018, 11:35 AM   #8
taxkourel
Member#: 333315
Looks like a complete build! Do you feel the injector size is pushing its limits or are the IDCs reasonable (you have a bunch of other fueling mods). This is very cool! Damn that power curve is so flat. In your opinion is this because of the rotated setup or cams mostly?
taxkourel is offline   Reply With Quote
Old 01-14-2018, 09:30 AM   #9
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Gheesh looks good and reliable.
Old 01-14-2018, 07:25 PM   #10
Gnagel
Member#: 469484
Hot damn I need to make more money haha
Gnagel is offline   Reply With Quote
Old Yesterday, 12:15 PM   #11
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Geeeeeeezzzzz, and those numbers on snow tires, so they'll only go up!
Shoot me an email, I got something for you. [email protected] you know where.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old Today, 12:32 AM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Looking good! I need to go for a ride!
