Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 05-29-2007, 11:02 PM   #1
austinp02
Member#: 149247
2018 STI
Question help finding connector for fuel pump relay!!
hey, i need to change my fuel filter but i dont know where the connector for the fuel pump relay is. i need to disconnect it so i can relieve the fuel pressure. any help would be great. real pics would be even better! thanks in advance.
austinp02 is offline   Reply With Quote
Old 05-29-2007, 11:16 PM   #2
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
I just did this I had the car set over night and then I did it. It leaked a little but not much
SUBYS R US is offline   Reply With Quote
Old 05-29-2007, 11:16 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Look under the passenger side dash by the kick panel. There is a relay with a green connector, that is the fuel pump relay.
Old 05-29-2007, 11:18 PM   #4
1SicRex
Member#: 81979
2010 WRX
well i found the connector up under the dash on the right side, at the kick panel. the green plug up in there... here this is from turbo xs website .....
Depressurize the fuel system:
1. Remove the 3 plastic screws securing the passenger side carpeting against the floorboard and expose the factory ecu.
2. Pull the plastic trim panel on the right side to expose the two electrical connectors shown below
3. Unplug the green connector shown below to disable the fuel pump.
4. Start the engine and run until it stalls.
5. Crank the engine over for 5 more seconds.
1SicRex is offline   Reply With Quote
Old 05-29-2007, 11:22 PM   #5
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
http://www56.homepage.villanova.edu/.../fuel_pump.htm
This is kinda the same thing, it will get rid of all pressure
Old 05-30-2007, 01:34 AM   #6
austinp02
Member#: 149247
2018 STI
yea i found it but thanks guys. it is really easy to get too, just not where you would think to look. got her all changed and only got squirted a little
Old 05-30-2007, 09:20 AM   #7
Metallrulz
Member#: 100148
2003 WRX Wagon
If you're used to working on Japanese cars and destroying your hands fitting them in small places, you can get to that connector without pulling any of the trim pieces away.
Metallrulz is offline   Reply With Quote
Old 05-30-2007, 09:43 AM   #8
r0n
Member#: 91839
or you can just open your gas tank over night... if you have a garage
r0n is offline   Reply With Quote
need fuel pump and fuel pump relay 4/18/10 raceckr MWSOC Private Classifieds 1 04-18-2010 03:05 AM
EJ22 Swap - No Spark... no ground for fuel pump relay?? Subarutex Subaru Conversions 5 01-22-2007 12:14 PM
haltech E6K fuel pump relay help inpreza kid Engine Management & Tuning 0 08-15-2003 08:43 PM
help, does anyone know where the fuel pump relay is? TaiChih Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-14-2002 12:53 AM
HelP, Where's the fuel pump relay? subachad Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-15-2001 04:45 PM
