Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 11-05-2002, 04:12 PM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default do you believe in coatings?
I do! But, I'm curious of actual charted gains of these mysterious anti-friction and heat coatings. Ever gone over a turbo kit completely with them? Pipes (int/ex.), intercooler. Curious about this. It seems like the coatings aren't the trick, but the tuning potential they offer is the real cream in the twinkie.
HamFist is offline   Reply With Quote
Old 11-05-2002, 07:47 PM   #2
Gravel-Fun
Member#: 18751
2000 Impreza RS
"Cream in the twinkie"???????
You want to be kicked off this board for that kind of language? [lol]
I would like to coat myself with Britney Spears!!!!
Sorry, I had nothing productive to add, but I thought I might get the ball rolling.
Gravel
Gravel-Fun is offline   Reply With Quote
Old 11-05-2002, 07:58 PM   #3
N/A
Member#: 133
TBA TBA
TBA
Well it is true that the hotter the gases the faster they move which makes the turbo spool faster. Also it helps keep the heat inside the exhaust and not let it out into the engine bay to add to the heat soak. Its just hard to find a shop that will cheaply do the ceramic coating. Its alot easier to just get exhaust wrap.
N/A is offline   Reply With Quote
Old 11-05-2002, 10:04 PM   #4
Turbo GC4
Member#: 28555
Hey, I heard Exhaust wrap is expensive... Is there any material that does the same job? I work at Home Depot and I asked around, everyone says to go look at a fireplace shop. Which makes sense because they probably use some wrap for fire place chimneys and whatnot. Anyways im going to check there. Anyone else got ideas?
Turbo GC4 is offline   Reply With Quote
Old 11-05-2002, 10:44 PM   #5
smacksube
Member#: 4067
01 2.5 rs
it's like $2 a yard IIRC, however it's sold in 30 yard chunks....$60 ain't bad though.....I've always heard it was kinad bad for the piping though, keeping the heat in causes crappy piping to crack and stuff...this is all what I've heard from old school VW's that came from the factory with exhaust wrap.
smacksube is offline   Reply With Quote
Old 11-06-2002, 12:02 AM   #6
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I've got nothing productive to add either...just looking for charts of gains if they're around. I wonder what any of this stuff could do in the tranny.
Old 11-06-2002, 05:26 PM   #7
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Talking
I like twinkies & Britney
On a serious note :
I'm planning on coating almost everything on my car. I got an estimate on how much would it cost by item:
-Manifolds $85.95
-Headers $99.95
-Down Pipes $80.95
-Intakes $75.95
-Calipers $60.95 (a pair)
It's guaranteed to lower temps by 20%, not to corrode & can be coated in metallic, black, blue and/or white
saludos,
Mariano
Mariano is offline   Reply With Quote
Old 11-06-2002, 06:49 PM   #8
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Jethot coated stock headers.
I had pics of the uppipe, downpipe, and midpipe around somewhere...
Revision is offline   Reply With Quote
Old 11-08-2002, 10:34 AM   #9
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Cool! I'm curious if that's the heat retention coating. Hope so. I had planned on htat in the exhaust, and radiant heat coating for the intake stuff. Jet Hot's prettier .
Do you believe in aliens? scuzzy Off-Topic 21 12-10-2003 11:41 PM
Do you believe in conspiracies? cwb124 Off-Topic 39 10-25-2003 04:33 AM
Do you believe in ESP, sťances, and 'teh other side'? Stroke Off-Topic 20 10-20-2003 04:17 PM
Do you believe in ghosts? HalfBaked Off-Topic 12 08-14-2003 03:19 PM
Freaky Ghost Pictures...Do You Believe In Them??? xfactor834 Off-Topic 17 05-06-2003 03:49 AM
