Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-29-2013, 02:08 AM   #551
chet24
Member#: 315018
01 2.5RS & 04 FXT
STM/AW
I had ziptie do a compression test on a lgt at like 65k miles, I was between 105 and 115 on all 4, said it was perfectly normal and nothing to worry about.
And I think from the factory, Subaru says it should be like 140, zip tie has never seen one above 130. 160 sounds really off.
chet24 is offline   Reply With Quote
Old 08-29-2013, 10:09 AM   #552
kanga-ru-45
Member#: 356484
2006 Wrx Limited
thats a relief thank you
kanga-ru-45 is offline   Reply With Quote
Old 08-31-2013, 02:47 PM   #553
kanga-ru-45
Member#: 356484
2006 Wrx Limited
Originally Posted by kanga-ru-45 View Post
hey guys, well I just decided to take it in to an ACDelco shop, ive had luck with them in the past.
car came back from the shop and the mech said all the fuss with intermittant misfiring in cylinder 4 and whatnot was allllll because of an autolite spark plug....?
He said you need ngk. All the plugs were ngk aside from the misfiring cylinder. He put an NGK in and bam...misfire gone.
Ok so thats effing sweet (i feel stupid, but i wasnt the one who put that plug in)
My NEW QUESTION IS, what are you guys getting for compression here at elevation in salt lake? I was at 160-170 at sea level but the mechanic said i was at 100psi on all cylinders (not sure if this was hot or cold) here in salt lake
Misfire is back......I....F#$%ing .....Hate......This......Car.......
So im tired of all this guess and check bullsh#$%. I want it taken care of and done with. Should I just take it to mark miller subaru or despain or solid auto works. I am tired of this F#$% thing
Old 08-31-2013, 10:47 PM   #554
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Solid. Is it on the same cylinder? Might be a bad coil pack. Try swapping coil packs and see if it follows.
car_cursed is online now   Reply With Quote
Old 08-31-2013, 10:51 PM   #555
P3rsia
Member#: 367089
2013 BRZ
Default Threw a rod bearing..
Im pretty sure i threw a rod bearing and from what all the mechanics that have listened to it try and start they say the same. I called Rallysportdirect and talked to a guy there for a little.
Im pretty sure ill have to replace the engine i was thinking of going with the 2.5 sti engine. The guy at rallysport said every thing should all work if i just buy the 2.5 short block, get the pistions re machined, a retune for the ECU and a new oil pump.
Any ideas? or advice as far as everything goes with this?
P3rsia is offline   Reply With Quote
Old 08-31-2013, 10:59 PM   #556
godfather2112
Papi Chulo
Member#: 53794
... White Magic
Jesus Underwear
Search "hybrid motor". Should yield you the results you want.
godfather2112 is offline   Reply With Quote
Old 08-31-2013, 11:06 PM   #557
kanga-ru-45
Member#: 356484
2006 Wrx Limited
Yep i did that, and so did the shop i took it to. Didnt change anything. I have a bad feeling it is something more serious because now my check engine light has switched from solid and flashing cruise, to blinking check engine...
From reading I have a feeling it is a valve issue? it is just so frustrating that it goes away and drives fine then comes bac randomly.
Either way I will call solid on monday if they are open.
Old 09-01-2013, 09:50 AM   #558
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
I had the same issue. I changed my plugs to 1 step colder and made sure the gap was good and it went away.
SUBYS R US is offline   Reply With Quote
Old 09-01-2013, 01:59 PM   #559
kanga-ru-45
Member#: 356484
2006 Wrx Limited
Really? Even if it is only on one cylinder?
Old 09-01-2013, 02:17 PM   #560
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Solid is closed on Monday. Do a leak down test. Burnt valves on subarus are not un-common.
bhhamblin is offline   Reply With Quote
Old 09-01-2013, 02:33 PM   #561
kanga-ru-45
Member#: 356484
2006 Wrx Limited
Darn. Guess ill wait till tuesday.
I just moved to Salt Lake. I dont have much of anything to work on my car. Just got a wrench set and a car jack but...thats about it.
Anyone have a ballpark idea of what it would cost to fix something like that?
Old 09-01-2013, 03:44 PM   #562
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
If it is valves i'm guessing the 1500+ ball park. Going to have to do the timing belt, pull the motor and fix it all.
907Bum is offline   Reply With Quote
Old 09-04-2013, 12:26 AM   #563
P3rsia
Member#: 367089
2013 BRZ
ok, so i have done alot of research into a hybrid motor. However they dont seem very reliable. Does anyone know anything else about this? I plan on calling solid and metric motor tomorrow but im not quite sure if this hybrid motor would be a good route to take.
My 04 Wrx is my daily driver and she is currently out of commission due to what i believe is a broken rod bearing. I've been looking into costs and stuff this week and i plan on diving into it by the end of this week or even beginning of next week. Any ideas on courses of action?
Old 09-04-2013, 12:52 AM   #564
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Take it down to either Solid or Despain and get an idea of what your looking at for pricing.
Old 09-04-2013, 01:03 AM   #565
P3rsia
Member#: 367089
2013 BRZ
ya i was gonna give them a call or head down their tomorrow. i have to figure out pricing a little before i tow it somewhere though.
Old 09-07-2013, 11:56 AM   #566
N. Motta
Member#: 306347
AW
Default godfasha
Dan the man! Seeing as how you are a VW owner, which VW forum have you found to be the most informative and useful in terms of researching the different GTI and Golf R models?
I've been casually reading a few threads here in the rumor section and want to start diggin a little deeper.
N. Motta is offline   Reply With Quote
Old 09-07-2013, 09:07 PM   #567
N. Motta
Member#: 306347
AW
Kirill, is this your kin?
Ukranian beauty Marina Petlay
Old 09-07-2013, 09:19 PM   #568
RB06
Member#: 264863
I'm not Dan the man but I have owned 4 vw's and currently have one as well and the best spots for golf r and gti info is vwvortex.com and golfmk6.com
Hope that helps man.
RB06 is offline   Reply With Quote
Old 09-08-2013, 12:11 PM   #569
N. Motta
Member#: 306347
AW
For sure, thanks man.
Old 09-08-2013, 01:12 PM   #570
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
careful on vortex, you might end up with a rusted looking hood, roof racks with useless crap on them and 205 tires on a 10" wheel poking out the fenders.
Old 09-08-2013, 09:31 PM   #571
N. Motta
Member#: 306347
AW
Well that's great, that's what I'm going for.
Now, what is the best recommendations for used gypsy clothes and tattoo parlors that specialize in chest pieces?
I'm not buying anytime soon. I just kind of want to start reading up, I may consider one or two models, 5-6 years down the road.
Old 09-08-2013, 09:47 PM   #572
godfather2112
Papi Chulo
Member#: 53794
... White Magic
Jesus Underwear
Eh, the VW forums are pretty horrible. What are you wanting to know about them? The new R looks ****ing awesome. 296hp and leaps and bounds better than a subaru in terms of refinement. While my MKVI gti is slower than a new wrx, im still willing to bet it will out handle stock for stock. The interior finish is awesome, its a quiet ride and the factory sound system doesnt block ****. Honestly, my GTI has been the most enjoyable vehicle I have owned thus far. I really dont see me owning a subaru again (possible but unlikely).
Old 09-08-2013, 10:35 PM   #573
N. Motta
Member#: 306347
AW
My first interest would be whether or not the VW brand has found the ability to be reliable to an owner for the long haul, if cared for and treated properly. If I ever consider buying a new or near new car again, I'd like to know the car has the potential to have a long life expectancy, with good reliability. My 05 fozzy is nearing 100k and has been stellar so far.
But as you mentioned, the gti's and r's have a lot of refinements and style that really catch my eye. Even though I'm just casually reading, those are the only two cars that I would consider getting into down the road. Maybe a nice accord.
Old 09-09-2013, 11:19 AM   #574
godfather2112
Papi Chulo
Member#: 53794
... White Magic
Jesus Underwear
From what I have seen and read, the gti and R would be the only models worth considering. From what I've seen, both of these models have been reliable... The other vw's not so much. Not sure if its because the gti and R models are the only ones still made in Germany while
The others are made in Mexico, or if they just put more attention into them. I've owned my car barely over a year now with 23xxx miles. So far, not one issue. I plan on keeping this car for at least 3 years. Maybe 5. Depending on where I end up living when I go to purchase my next car, if heavily consider a R, possibly in dsg.
Old 09-09-2013, 01:01 PM   #575
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
DSG, you sissy poofter. At least you'll be able to take out the tampon with your free hand.
